View Full Version : Off-Topic
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
  1. 97-99 bumper on a 95?
  2. Lowering Help
  3. Any GST or GSX owners around Sacramento?
  4. Nitrous
  5. which model eclipse was awd
  6. 463a or turbo
  7. Changing Engines
  8. Rebuilt a turbo
  9. Lambo doors??
  10. Engine losing rpms
  11. 16x7.5 rims .. can I put stock 96 GST tires over these?
  12. belt
  13. My Eclipse paraphernelia (pics) . Eclipses rock [56K destruction]
  14. Well it happened...
  15. Oil leak
  16. ? about swaping a 2g motor into 1g
  17. GS-X Issue... Need some advice.
  18. The legend of speed
  19. buying a gsx or gst
  20. v-afc??? will it still work as an SAFC??
  21. engine question
  22. What Damage have i caused ?
  23. how do I remove sunroof liner?
  24. this car does not age well, more problems, plz help
  25. Check this $#1+ out ! Car ice
  26. Blind Spot
  27. WANTED: Oil Cooler.
  28. convertible
  29. evo rims
  30. Question Identifying
  31. Need stock rims from a GSX
  32. lucky ?? tire repair and tire rotation
  33. 2g eclipse tranny problems?
  34. Cant get BOV off!
  35. Aftermarket links
  36. please tell me this is bullshit
  37. more F**king trouble!
  38. Brake Problem
  39. need tranny fluid specs
  40. looking for 2g door panels
  41. Looking for
  42. bcs restrictor mod?
  43. How can I pull off a stylish look, but NOT RICEY!
  44. Just a few questions
  45. Block questions
  46. clutch got even worse, help!!
  47. Bought A New Talon
  48. how do i make my head lights brighter?
  49. Eclipse vs Celica
  50. questions about the talon
  51. Having engine issues
  52. Is there a stronger engine I can swap out my 420a with?
  53. Does Anyone Have One Of These Sitting Around?
  54. turbo kits
  55. talon worth it
  56. sunroof and powered mirrors wont work
  57. gs and gsx/gst
  58. clutch is slipping what to do now?
  59. modifiying stock 2G hood. inserting louvers.
  60. Rear 5x7 Speakers
  61. GS or GSX
  62. Throttle Bodies and Intake Manifolds???
  63. 4G63 p.s.i
  64. Sorry race stories
  65. can turbo heat crack CF hoods?
  66. new T-belt
  67. poll
  68. police scanner mounting
  69. new car looks
  70. Transmission Question.
  71. Shock Selection
  72. Bad night of drifting...
  73. Warming up
  74. Bad plug wire
  75. not a swap a problem
  76. The C word
  77. Wanted TPS for 90 GSX
  78. Radio Install Help
  79. Rims/tires packages
  80. Interior carpet
  81. noob!!! need help
  82. New Project:93 Gsx For $1300.00
  83. WTB: TALON TSi or ECLIPSE GSX shell
  84. ESi Cold Air Intakes
  85. 94 laser keeps dying
  86. Nex Suspension coilovers???
  87. Horrible gas mileage and no power
  88. Turbo intake. Good couplers?
  89. head swaps
  90. buying an eclipse
  91. My happy 30th birthday
  92. Just installed S pipe. Now a problem occurs.
  93. Heater doesn't work... IT'S FREEZING!!
  94. 97 Eclipse Spyder top leaking when it rains
  95. Need New Struts...
  96. 95 no start
  97. Still knocking!! WHAT CAN IT BE!!??!!
  98. po134 code..
  99. quick bodykit question...
  100. looking for a 95-96 cas
  101. What Flywheel to buy?
  102. more clutch problems help!
  103. Engines
  104. Brakes swap from an RS to a GS
  105. cat-back useless without downpipe?
  106. re: turbo to non-turbo
  107. Exedy Vs. ACT clutch
  108. FS: 99 Eclipse RS
  109. Head Question
  110. 6a12?????
  111. Akward Acceleration Experience
  112. My first solo flight!
  113. 4G63 Question
  114. repaint my back bumper or not ?
  115. major leaking problem help fast!!
  116. Body Kits
  117. bov!!!!!!
  118. What is the #s on a M/t 95-96
  119. front bumper repair?
  120. Garrett T61 Turbo
  121. Header glowing red
  122. 1g bov vs greddy type s bov
  123. bov
  124. FS modded Eclipse GST
  125. Should my weather stripping look like this? *Pics*
  126. Rims
  127. all black 2gs, lets see what rims your workin with
  128. Big T28
  129. Blow Off Valve!!!!!!!!!
  130. act 2600 6 puck streetable?
  131. Help with Racing report?!
  132. 1g motor into a 2g car
  133. Motor Mount Installed, now new problem
  134. suggestions on getting the crank pully off
  135. full soop job
  136. New POS daily driver
  137. Parts for a 92' Talon
  138. What Now?
  139. Wiring or ECU problem
  140. Ontario Street Races (Saturday Night)
  141. various mods.
  142. Main bearing?
  143. Catalytic Converter on Ebay??
  144. New brakes
  145. Air, Fuel, & Spark - Still Doesn't Run??
  146. mmmmmm...wheres my CAS??
  147. power steering pump and alternator need change ??
  148. Evo VIII steering wheel to 96 eclipse?
  149. TMO Datalogger cable diagram?
  150. Poll:
  151. extra coolant lines?
  152. launching
  153. 2000 posts suckas!!!
  154. FS AWD Rolling Chassie with Extras
  155. Car making New sound
  156. What turbo and what do i need
  157. boost leak probs??
  158. Strange Problem.
  159. double clutching
  160. oil pressure gauage
  161. My electrical problems...
  162. big16g shaft spin????
  163. Uber excited about my GSX!
  164. Funny/Sad story, Read It!
  165. 2nd o2 sensor
  166. 6/7bolt
  167. SRS Light On
  168. Will a bad TPS couse misfire?
  169. cash or 1g gsx
  170. How much is it to rebuild a head?
  171. 1g datalogger
  172. engine not firing...hmmmmm??
  173. How to remove valve springs. Please Help.
  174. Where I can buy a belt tensioner?
  175. freaking battery
  176. Convertible hard top...any custom shops out there?
  177. Ooooh myyyy god!
  178. FOR SALE! ~ ~ ~ 85 Very Clean
  179. normal oil psi?
  180. throtte cable out of whack
  181. huge oil level problem need help now
  182. How Do I Take The Water Pump Off!!! Help!!!!
  183. CEL on again. Please read
  184. Turbo going bad, need help.
  185. Muahha awsome race question
  186. clutch problems yall
  187. supercharger problems
  188. Venom 400 Control Module
  189. mpg
  190. Now what do I do with it????
  191. Radiator question: Is this normal?
  192. 1gb to 1ga conversion
  193. Some problems solved
  194. FMIC 1g For Sale
  195. I was driving around in Riverside CA and guess what I saw....
  196. Is this something i should consider?
  197. Engine Mount Inserts... Again
  198. Kevin:palm 505 Usb To Serial?
  199. T25 Boost?
  200. best exhaust manifold for my set up
  201. Valve Seals?
  202. Out: Tail, Reverse, Instrument Lights - Short?
  203. cheap strut bars.
  204. throttle cable
  205. How much boost should I be able to push? A few other questions too
  206. downpipe question
  207. Anyone From NC?
  208. New Mobile 1 oil !!
  209. oil pressure question
  210. Looking for some body/engine parts
  211. When is it needed ???
  212. gonna get killed for asking this........
  213. Getting S pipe and intake pipe.. any warnings?
  214. Should I use synthetic oil?
  215. thinking to buy these
  216. Anyone From Virginia??
  217. Another Won Ebay Idem:
  218. fuel presure regulator
  219. Help RST!!...
  220. 95 eclipse transmission oil
  221. Injector Question
  222. Ignition Problems I Think
  223. Squealing Belts!!!
  224. gsx good in the snow?
  225. PW onto a RS..???
  226. sellin my car...
  227. Test Autometer accuracy?
  228. South-Eastern DSM Meet...
  229. esi convertion to tsi
  230. Arceo brand rims???
  231. Should I buy 1g bov & RRE uicp from dsmtrader?
  232. o2 sensor question
  233. Insurance On Eclipse???
  234. speedometer not working wheres the fuse at?
  235. speedchip?
  236. Gimme some help right quick!!!!!!!!
  237. Ignition Problems
  238. high rev after carb cleaner
  239. Talon Electrical Problems. . .Please Help!
  240. Turbo Model Information
  241. When does CEL come on again?
  242. oh no spam
  243. o2 *housing location*
  244. No Spark to my spark plug.... =(
  245. 95 Talon Staring Problems
  246. genral estimate
  247. Alternator brace
  248. FS: 98 GS-T Eclipse
  249. On the way home
  250. left signal blink problem ?
