View Full Version : Off-Topic
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
  1. Look what i got for the garage :)
  2. Foglights are out?
  3. Check this Out !!!!
  4. gas mileage
  5. head gasket ??
  6. Very dumb question
  7. How to make cig lighter a switch for neons?
  8. Carbon Fiber Trunk for a 2G
  9. Why? ... Just Why?!
  10. Power steering rack and pinion replacement?
  11. What color is tranny fluid suppposed to be when drained?
  12. Does this clutch look bad to you? Replace or re-use??
  13. cruise control removal
  14. Possibly new car
  15. I'm back....
  16. 1g tb
  17. About that exhaust...
  18. Temp Gauge not working (unit position)
  19. 1g dsm stuff for sale and parting out 1g
  20. Mitsubishi MUT-I Dealer Diagnostic Scanner
  21. datalogger
  22. Mechanicccss suck. clutch question
  23. Ok guys i decided to take my motor out t6his winter!!
  24. Which other cars share the 5x114.3 Pattern?
  25. hey guys, another clutch question
  26. 91 or 92 trans in my 90... help
  27. Car insurance is a scam?
  28. I GOT A TURBO WHOOO HOOOO!!!!!!! pics*
  29. How to flush radiator
  30. Downstream O2 sensor bypass
  31. whats the difference between an afc and an afc2?
  32. OK basic stupid questions
  33. Tranny Fluid Change at Dealer?
  34. Oil Filter
  35. Mainly RWD GSX, Stupid Question, yet Interesting.
  36. After Rear Main Seal - Car won't move in gear
  37. Front Windshield Takes forever to defrost...Vents Clogged?
  38. Lots of DSM parts for sale... NEED TO BE GONE!
  39. IS this weird?
  40. To have an antenna, or not to have an antenna...
  41. Spark plugs wires..Wich is the best?
  42. Chattering starter...
  43. For those who drive or driven in Toronto
  44. Replace Turbocharger in 95 talon
  45. Biggest Injectors a 190 can support?
  46. K&N Intake system for laser,Talon,eclipse
  47. GSX wont start
  48. Radiator Replacement? Should I?
  49. Snow In Syracuse!!! Omg
  50. troble with a 97 talon
  51. MINT 97 GS-T for $3,000..... 92Kmiles?
  52. 450cc Injectors
  53. What's a Good Second Car?
  54. 97' Eagle Talon ESI Fuel Filter
  55. Sparky altenator???
  56. What is the deal with MOBILE 1 Oil
  57. Boost Leak or what?
  58. any1 from Philly/berks county metro got 1g knowledge?
  59. 1st Gen into '96 GST vacuum nightmare!
  60. Bearings!
  61. Need advice about '95 Eclipse GST
  62. E-Prom and eveything needed...
  63. Kinda in a bind
  64. a tranny
  65. Wow, read this, my story :)
  66. Are Eclipse GS crap
  67. any1 from southeastern Penn?
  68. How much do you guy paying for front wheel alignment ?
  69. entering theftlock code procedure
  70. Home Depot Intake, tubes on the intake, HELP!
  71. 95 eclipse RS ECU
  72. Brake lights don't work right...
  73. balance shaft removal
  74. Tranny problems
  75. MEDECO KILL SWITCH IN MY 92 GS.... ANYONE KNOW ABOUT THESE . -BERKS Co- Pennsylvania
  76. Brake Qurstions
  77. Exhaust manifold
  78. Definition of a Ricer.............
  79. Check Engine
  80. Greddy Intercooler options
  81. i need a tranny
  82. want opinion on ebay car w/2.4L
  83. installing new turbo ?
  84. 1.8L Rear Main Seal Install - Which Gasket?
  85. CEL Codes(What do they mean?)
  86. '97 GST motor swap into a 97 GS
  87. Motor SWAP GST into a GS???
  88. 92 talon tsi
  89. Can i put a 6Bolt 92 n/t in my turbo and change the cams?
  90. engine
  91. stock turbo injector size
  92. Turbo Question!!!!
  93. fuel pump
  94. Best Carl Alarm Setup
  95. sport compact pro?
  96. Im I ricer ?
  97. fill me in on what happend...
  98. selling my Eclipse GS 1996
  99. Haven't posted in a while, couple updates...
  100. Wastegate or turbo boost?
  101. Help!!!
  102. s-afc or profec b spec II
  103. Building a motor
  104. Parts for sell
  105. My friend just sold his 96 GS-T and got THIS...
  106. End of race season
  107. Intake help, not sure what to do
  108. Highest N/A HP on stock motor
  109. CV Shaft problem #2
  110. oil leek on start up
  111. Tranny Fluid
  112. Crankwalkk
  113. Cleaning ceiling
  114. Finally Changed Fuel Filter
  115. EclipseForum.com
  116. bov recirculation clarification
  117. New Sunroof for My ES
  118. i think i got it this time,,,,92 GS
  119. 92 gs starting problem
  120. Too Low
  121. Stalls while driving. Any Suggestions?
  122. Link: Turbine Jet Powered 3G? What the...
  123. 95 Gst
  124. Oh damn, tranny issue ?!?!
  125. My new Lazer...
  126. F.i.c
  127. anyone rallycross their dsm?
  128. buying an eclipse?
  129. Looking to buy a $400 '93 Talon DL (Should I?)
  130. Turbine Eclipse?
  131. Banned from POSDSM
  132. EverStart Batterys they are junk?
  133. lookin for tranny
  134. part number
  135. sweet god...
  136. Electric VS Mechanical and home made MBC
  137. instrument dimmer
  138. car wont start 92 gs,, some questions
  139. OBX Racing blow off valve
  140. funny video
  141. A basketball hoop pole, a saws-all, and an idea
  142. Exhaust Dump at WOT... How could you do this?
  143. Totald
  144. interesting... if you like to blow your car up
  145. Bottom end
  146. 92 GS with 4g63 motor im putting in new clutch and got some questions,,,
  147. clutch!
  148. engine blown great!!!!!!!!!!
  149. Spyder Category Archive Section???
  150. Ignition Wires For A 2.4 Engine 99 Spyder GS??
  151. Mitsubishi eclipse 97-99
  152. Bout time i ordered this..
  153. what kinda engine is in my car?
  154. dumb question but I just wonder ?
  155. Sulfur smell
  156. T-25
  157. eclipse car jumping problem
  158. 1g tb swap
  159. Turbo oil circulator? Anyone seen it?
  160. New INtake.. Loss of boost.. Maybe??
  161. ball joint removal and install
  162. DSMTrader is down. Is there another DSM site dedicated exclusively to parts trading?
  163. Need help with sensor
  164. Camber kit Install
  165. Postive or Negative switched headlight system?
  166. Good deal??
  167. Turbos
  168. Fuse for Instrument Panel lights?
  169. New tires = loads of money
  170. Very Funny story
  171. how much is this worth
  172. test pipe.
  173. Bro just got an RSX Type-S
  174. Mesh Grille
  175. OBX Helical LSD
  176. car problem wont start help please
  177. AC Removal
  178. TB Porting... 55 or 60?
  179. Local shop cheap selling Evo 16g
  180. air to refrigerant intercooler
  181. engine swap 4g63
  182. no spark??????
  183. Quick Question
  184. 1990 tsi awd vs jetta 1.8T
  185. Thought you guys would get a kick outta this lol
  186. 92 ECLIPSE GS NOT STARTING I tHINK ITS A ALARM ISSUE HELLLP!
  187. 91 front end to 92 front end.
  188. Heater blower broken
  189. Questions regarding Spyder
  190. Which wheels
  191. IWC Version 2.0
  192. face lift....honest opinion
  193. 92 talon intermittent no start no codes help
  194. water temp gauge
  195. Fuel Injector Pressure Regulator
  196. BOV Opinions
  197. FS- cleaning out shop, lots of parts look !
  198. proper way to test for boost leaks
  199. BATTERY QUESTIONS For 2.0 Non-Turbo Eclipse GS... SOME ONE WITH THE SAME CAR...
  200. came back from the track
  201. quiet exhaust
  202. FPR regulation question?
  203. Misplaced line=EVAP
  204. painting valve covers is there anything bad about it?
  205. Oil Question
  206. Yeah... that ruined it
  207. Door handle
  208. Stupid Ca Cops!
  209. Problem starting - Cold Weather
  210. lowering springs
  211. Just Turned The Big 9 5 !!!!!
  212. stofck head lights and tail lights
  213. ECU's
  214. Goofy idle
  215. Carbon on cylinder
  216. A Bad day at the track!!!!
  217. SUPER FUN AWESOME POLL: How many leaks does your DSM have?
  218. Swap
  219. 92 talon tsi.....
  220. Someone please respond to this...
  221. Ignition wires for 1g in 2g?
  222. logger
  223. 92 eclipse GS INTERIOR Sucks!!! what other cars can i grab parts off of?
  224. NEW DSMer
  225. will not start please any ideas?
  226. Looking for 1st gen w/no motor in Northern PA
  227. best way to get more torque
  228. Tricked out ebay car, would you buy?
  229. Boost leak or not?
  230. U Flow It Car Dos Not Respond
  231. new clutch and flywheel question
  232. How much for my t25?
  233. Blown headgasket I dont think so!
  234. fuel trim, fuel pump
  235. What are these called ?
  236. Opinions On These Wheels 1g?
  237. What do you guys think about these?
  238. When is knock expected?
  239. which fluid
  240. just realized something
  241. what to port and polish ?
  242. Turbo DSM Question
  243. COOL VIDEO SITE!! Stree fire
  244. Every DSMer needs this
  245. Parts melting?!?!?
  246. How much would it cost to do a motor swap ?
  247. Anyone Looking For 1g Parts, Heres A Few For Sale!!!!!!!!
  248. (title removed by mod)
  249. what the heck?
  250. Basic questions about DSM
