View Full Version : Off-Topic
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50 51 52 53
  1. Wut do i need to turbo my 96 GS w/o...
  2. i am young which should i get
  3. got a question
  4. FS: Brembo cross-drilled/slotted rotors BRAND NEW!
  5. Misfires Under boost
  6. Engine swap?
  7. who's the fastest 1/4?
  8. help me!
  9. Help Fast buying 99 Eclipse GS
  10. How much horsepower is the 420A Capable of with the right stuff?
  11. need help on some N1 installation
  12. guys i need info on gst's pls
  13. Wanted 4 Bolt Rear
  14. gtech
  15. Help! Need window cranks!
  16. friends new car
  17. resonator
  18. Question about 97 eclipse gs
  19. Wanted 4 Bolt Rear
  20. engine light code - how to get it
  21. t.t. vr4 motor into 2nd. gen?
  22. Dyno results.
  23. Performance Camshaft on 96 nonturbo
  24. Is it Possible to Swaps a 4G63 2.0L turbo motor into a Gen3 Eclipse
  25. my decision
  26. The new eclipses
  27. Did the dreaded CRANKWALK just happen to me..?
  28. the curse of the eclipse?
  29. what do i need before i get a bov
  30. Need proof that Mitsubishi doesnt "Fall apart"
  31. bossted stock t25 1/4 times
  32. ccut it out or leave it
  33. is there a cheap way to get more boost
  34. hi/lo impediance
  35. hi/lo impediance
  36. Eclipse Aftermarkets
  37. 10 sec. eclipse
  38. 96 talon tsi
  39. RRE's Down Pipe
  40. Gsx Vs Gst
  41. smoke after oil change when idling
  42. 96 talon tsi headlights
  43. Dashboard Speakers
  44. gs turbo mods
  45. Eclipses Suck!
  46. redline
  47. turbo laser
  48. Where can I get 97-99 backup lights?
  49. eclipse
  50. body kits and parts???
  51. Advice on buying eclipse
  52. turbo help?
  53. 46g3 vs 420a
  54. Help on Lowering 2003 GTS
  55. It always happens (broke car)
  56. N1 exhaust characteristics
  57. i need a valve cover
  58. crashed gsx
  59. exhaust/bodykit
  60. advice on 97 gst
  61. 1991 Eclispe GS Turbo Problems
  62. exhaust systems
  63. Gsx
  64. GSX eclipse
  65. about to buy 2003 eclipse GTS?
  66. MY car (trouble) HELP
  67. Some Car Troubles.
  68. exhaust questions
  69. wanted: a rebuildable 95 & ^ eclipse
  70. anyone interested?
  71. stock blow off valve?
  72. Import Tuner's Talon/Eclipse!!
  73. 2g Dyno?
  74. eclipse motor oil
  75. turbo problem
  76. College...on a budget...you've heard this before
  77. Understanding the 4G63
  78. eclipse vr-4?
  79. o2 Housings
  80. 4g64 motors
  81. 99 GSX Weaknesses...
  82. 95 eclipse gsx, open door without key
  83. I need a transmission
  84. About to buy 97 Eclipse GST
  85. no sparka couple weaks ago i changed the head gasket on my 91 talon tsi awd. before i
  86. difference
  87. I NEED A TRANSMISSIONS FOR A 1991 Eclipse
  88. no spark
  89. help with speedometer, tranny, engine light
  90. Spark Plugs
  91. gs mods!
  92. Looking to aquire side skirts for my 2g talon
  93. 1995-98 Talon ESI parts for sale
  94. I Need A Car!!!!
  95. Used Eclipse Performance Parts for Sale
  96. gsx
  97. Can anyone tell me who makes these ?
  98. Installing Power M3 mirrors with turn signal?
  99. 2004 Show/Racing Events
  100. Infiniti Stereo Code Lock Problem
  101. 99 Eclipse GS Non-Turbo Auto DOHC need help any would be helpful....PLEASE
  102. NEED FAST ADVICE - Bent Rod
  103. water pump/ power steering belt coming off
  104. Removing headlights or getting access inside?
  105. 1994 Eagle Talon Dl Partingout Or Whole
  106. JDM parts?
  107. 1999 Eclipse Spyder GTS or Honda?
  108. Eclipse or no Eclipse?
  109. Stereo System Question...
  110. Help! Wheels locked up?
  111. Serious Turbo Question
  112. Fun with Crankwalk
  113. buying a MITSUBISHI??????
  114. AF Introduction, some DSM buying questions
  115. offset
  116. is this possible: a evo engine in a eclipse
  117. Help replacing rear rotors on a 1997 GSX
  118. My Plan to get a DSM?
  119. High and eratic Idle
  120. FS: blitz, bws, buddy club full kits
  121. stock turbo
  122. eclispe gsx and gst
  123. Surging Idle
  124. exhaust question
  125. Anybody install indiglo gauges?
  126. 99 eclipse motor mounts!
  127. eclipse spyder performance enhancements
  128. 96 Eclipse unfindable problem
  129. Sponsors
  130. 2003 Eclipse GS Fuel Pump Relay HELP!
  131. transmission conversion
  132. Installing an Autometer 5" Tach 95 ESI
  133. Very funny
  134. 20"
  135. 3G forced induction?
  136. aftermarket Shogun Style RW W/LED spoiler 4 sale
  137. i need a head gasket
  138. air lift suspension
  139. stock wing 4 sale
  140. exhaust with 5" tip
  141. no start, no check eng light
  142. Intake question 1993 gs
  143. Whats faster the gs-t enginee or sr20det (s13)
  144. ZEX Nitrous system
  145. FS!!modded 1995 GSX
  146. 03 Infinity Cd Needs Rca Plugs
  147. Electrical problems plz help
  148. strange coolant lose...
  149. OEM body parts not painted????
  150. 92 Eclipse info needed
  151. Ok I am thinking of getting a GSX
  152. bolt pattern...
  153. I need help.
  154. shaky steering wheel
  155. suspension setups
  156. What do you think about my interior?
  157. Used eclipse
  158. turbo/nitrous question
  159. intake question
  160. newb questions
  161. couple of questions about 95 gs
  162. Custom exhaust
  163. 18x8 rims with tires off a 2003 eclipse
  164. Shift linkage
  165. is 95 eclipse ecu compatible with talon?
  166. big brake kit or quality pads
  167. Another Chance?
  168. crankwalk?
  169. Apexi TT Harness
  170. Pacesetter
  171. For Sale:twisted Spoke Rims
  172. Engine sound
  173. Pressure Drop????
  174. The impossible......I know but.....
  175. 00 Eclipse GT. Noise at 4500+ RPM, Please look
  176. alternator/power steering belt!
  177. FS: Axxis Metal Master brake pads for Talon
  178. FS: Axxis Metal Master brake pads for Eclipse
  179. 14b at 16 psi
  180. 87 octane?
  181. Buying a Tsi, input please.
  182. Well.....
  183. custom exhaust?
  184. OK, serious engine swap question(s)!
  185. parts for sale
  186. t25 needed
  187. Body Kit 4 Sale
  188. 92 Eclipse 1.8 turbo?
  189. Free Mods
  190. question for some people
  191. exhuast help
  192. center piece
  193. who has the most miles?
  194. sub box
  195. lowering
  196. Wheels
  197. FS: 16" aftermarket wheels/tires that'll fit Talons
  198. FS: 16" aftermarket wheels/tires that'll fit the Eclipse
  199. Help with a 91 Eclipse
  200. Pilot bearing
  201. Moderator
  202. ok i need some help your pros!
  203. '93 Gsx
  204. how to launch a 2nd gen turbo eclipse?
  205. think this is for real?
  206. venom super cool fuel pump for 2.4 sohc
  207. 300 hp in stock GST?
  208. 98 RS upgrade suggestions?
  209. home depot intake for a t-25
  210. data loggers
  211. lazer key ignitions
  212. Mitsubishi clock
  213. Eclipse Ignition Wiring
  214. Missouri DSM'ers
  215. Parting out
  216. Td05h-18g
  217. 4g63t turbo engine / 1.8l tranny?
  218. Do I need a Rising Rate FMU?
  219. fwd to awd conversion
  220. converting GSX to RWD
  221. Question
  222. Which intake for GST??
  223. how hard is it?
  224. Electrical Problem??
  225. eclipse gsx&eagle talon
  226. Infinity CD player in 2003 Eclipse
  227. 93 eclipse gs - a few questions
  228. what kinds of rims for a Talon?
  229. 6-bolt and 7-bolt
  230. 96 Eclipse is dying on me...
  231. 95 talon 2.0 no turbo FWD
  232. '95 Talon 2.0 no turbo FWD no start
  233. 97 spyder...top
  234. 95 talon esi bad fuel pump
  235. AWD Question
  236. gsx or tsi awd
  237. Talon cruise contol
  238. running amp wire
  239. sneaky pete on a 94
  240. numero uno fmic
  241. Problem with my 97 GS HELP!!!
  242. Eagle Talon Shifting Problems 1st gone 2nd gone 3rd 4th 5th ok ???
  243. did the 95 rs have just one ecu box under the hood?
  244. no spark..why?
  245. Ahhhh!!!
  246. AWD burnout pics
  247. Plymouth Laser = Eclipse?
  248. Radio Code!!!
  249. how many miles is a 1997 motor good for?
  250. how long is a 1997 eclipse motor good for?
