View Full Version : Off-Topic
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
  1. which muffler to get
  2. Alternator or some other problem?
  3. ECU repair
  4. GSX for sale! Must GO!
  5. 6bolt block non-turbo
  6. BodyKIts
  7. What Kinda eclipse should I get??
  8. knock sensor?
  9. Gsx Vs Gst
  10. A quick turbo question
  11. Great News Everybody
  12. 1994 eagle talon stereo install
  13. **Spark Plug INFO**
  14. boost gauge tube
  15. AWD and FWD shocks,
  16. Knocking Problem
  17. plugs
  18. Spark Plugs
  19. Need help with camber adjusting.
  20. selling DSM for cobalt?
  21. Lifter Tick
  22. No longer a DSM'er
  23. How to find ??
  24. Spyder Roof Coating
  25. Big Turbo Shaft PLay??
  26. Rear strut bars for a Spyder?
  27. clutches
  28. Car trouble
  29. RIP car
  30. Big question with the 420a RS-T!!!!
  31. Quick Question
  32. alternator removal on 2g tsi?
  33. DSM3D - Pics Needed
  34. 95 vs 96 and up 420A
  35. 4G63 Engine For Sale...How Much can i sell it?
  36. R.i.p.
  37. Keyless Entry
  38. anyone know where I can find the screw bit to remove the foglights?
  39. time for 6 bolt?
  40. Need A 95-99 Eclipse Gsx!!!
  41. Need some feedback
  42. Scm 50 Failed:shit Turbo!
  43. What to add next?
  44. Help me spend my money
  45. Slotted/Drilled rotors
  46. Air Bag Question
  47. Is there suppose to be...?
  48. 1g bov flange
  49. Evo Viii turbo???
  50. turbo question
  51. This is a must see for people: 92 Eagle talon and 96 sea-doo xp TOGETHER!!
  52. is this a common no start prob.
  53. mint seats
  54. The Ultimate DSM CD Guide, Anyone Ever Cop this?
  55. o2 housing
  56. Poor Gas Mileage...causes?
  57. 92 Laser won't start when cold
  58. Locked Transfer Case
  59. Head/fog Light Bulb Replacement?, What Size and...
  60. Oil leak question
  61. Easiest Way To Remove Mitsubishi Sticker Emblem?
  62. If it sounds to good to be ture, It prob is...
  63. 1st Gear Broken
  64. car ignition
  65. White Smoke / leaking Oil
  66. Heads up on bad Vaccum lines not uncommon
  67. More help with my first eclipse...
  68. Aftermarket Radio Install: Need help now
  69. Fogged Headlamp.
  70. G1 speaker question-installation
  71. Tranny swap now starter grinds
  72. *Video* 5k6k Killer! MUST WATCH!!!! Wicked
  73. Cold Idle Surge!!
  74. Boost Controller Spikes
  75. whats a strut tower brace?
  76. Just thought I'd add this...
  77. suspension
  78. Finally
  79. Need some turbo opinions
  80. Looking for TB parts
  81. looking for PCM for a 96'
  82. 1994 ealge talon horsepower help
  83. Intercooler Question
  84. Short advice about rear differential fluid
  85. Advice for my custom swaybar brackets?
  86. buying eclipse
  87. Ticking noise plus CEL came on?
  88. Lifter Tick or something worse??!
  89. 2005 NHRA Rulebook
  90. How Do You Remove The Signal Light On Bumper?
  91. FS: 7" In-Dash DVD Player
  92. opinion
  93. Clutch problem
  94. A/C droppin the rpms like a mofo
  95. Replacing timing belt
  96. CV shaft question...
  97. Anyone know what a Input or Output Sensor is?
  98. 1992 Eclipse GS Turbo for sale
  99. Hoop spoiler
  100. O2 sensor and CEL Question?!?!? Huh?
  101. need opinion on this gs turbo 95 on ebay
  102. Silencer Removal
  103. How to stop fuel cut???
  104. performance
  105. got a new digital camra today
  106. *Pics* exhaust done! NEEDS MORE POWER!
  107. 14b finally in!
  108. Speed Sensor or Tranny?
  109. the new eclipse
  110. How to connect tweeter's on aftermarket Head Unit?
  111. 18x8 Rims w/ 1.3" Drop, will it rub?
  112. speaker size
  113. What does this mean? (Dash Light)
  114. buy and build or buy and drive?
  115. Boost problems please help!!!
  116. custom headers for 1.8
  117. intercooler question
  118. Help fast!
  119. auto to manual switch
  120. Tranny over fill ?? PLEASE HELP !!!
  121. Hks Mushroom Filter Fs:
  122. 14b question
  123. Need 1990 AWD Fuel Filler hose
  124. Correct Way To Clean Convertable Top?
  125. Tein or Eibach Springs, Which is Better?
  126. first time changing trany fluid any tips ?
  127. YAY, mani bolt out :)
  128. Car Runnin Like Shit
  129. New Stage1 Bolt-on turbo kit from conceptillusions, good deal?...
  130. headers
  131. help with these CEL codes
  132. safc1 tuning on a pte 50 trim
  133. high rpms!!!!
  134. 1G turbo for sale
  135. car problem again
  136. Car Alarm
  137. Clutch Problems...
  138. Noise at boost?
  139. Two Cable's Behind Stock Radio?
  140. boost leak :(
  141. turbo questions 96 talon
  142. Need Help!!!
  143. trouble with a 16g turbo
  144. 99 Gst 4 Sale $9000 Nevada
  145. Who Knows Clutch?
  146. starter question...
  147. CF Hoods near LA
  148. How Do You Put On The Convertible Boot?
  149. whats the problem??????
  150. Torque specs on fuel rail
  151. Where's the CD Changer On A Spyder?
  152. *Video* Little red devil Owned Cars
  153. Spark plugs?
  154. Belt problem
  155. Headlight difference
  156. fs: remote control lambo kit!!
  157. Finally finished Rebuild!
  158. Screamin Demon Ignition Coil?
  159. Convertable Link's?
  160. Fog Light Lens Replacement?
  161. just take out my pipe today !!
  162. 3000gt for sale
  163. ball bearing turbos
  164. 95 eclipse gsx
  165. Turbo Guys: Boost Leak Test Your Car!
  166. can i put the 92 body kit on my 91 talon?
  167. Monza HKS styled BOV?
  168. what should i do??
  169. what should i do??
  170. dsmpowered.com
  171. DSM Talk chat room
  172. Fluid specification table
  173. I want Magnaflow on my RS..tell me what you think (sound clips)
  174. '92 Eclipse GSX Info?
  175. NEW:TMO LOG 50 TRIM 650"S 22 PSI
  176. Side motor mounts and their rubbery badness... no press available
  177. Good news :)
  178. Urethane front lip fianlly installed!! ***PICS*** 56K murder
  179. Blow Off Valve for 98 eclipse GS-T
  180. help me out with with my options
  181. For Sale: 1997 Spyder GST
  182. exhaust
  183. All I have to say is HA HA :)
  184. fuel filter replacment on RS
  185. Broken axle!!!
  186. Precision Scm 50 Trim:please Read!
  187. Aftermarket Tails
  188. Fluctuating idle
  189. need a lil help
  190. heading out to the Salvage Yard. Got a Qestion
  191. stock cat converter wanted
  192. Motor Swaps and Trouble shooting
  193. PTE scm50
  194. Car Alarm
  195. taking off side mirrors??
  196. car is sputtering
  197. quick question about oil
  198. ECU upgrades
  199. automatic transaxle fluid type
  200. 1995 Eclipse For Sell
  201. What's Next?
  202. Final plea for help, long post please read!! Post any suggestions!! THANKS!!
  203. Some information please!
  204. boost drop???
  205. toyota paseo?
  206. My mitsibishi dealer is gone !!
  207. Please help me pick my fuel kit
  208. These cops are out of control!!!!
  209. Denso Fuel pump ?
  210. important. need help
  211. aftermarket shift knob
  212. What is this called? Sorry...
  213. 120,000 mile maintenace costs $
  214. Anyone knows? removing stians from CAI?
  215. Project 50 Trim Completed!
  216. Need some advice
  217. New Books
  218. Motor inserts installed
  219. Big problem with mani bolt
  220. What would be a better choice?
  221. 4 bolt axles on a 3 bolt rear?
  222. Oh god no...No no no!
  223. Yay
  224. Way Too Fricken Loudd!!!!!!!!
  225. fuel pressure regulator question.
  226. pistion rings on my eclipse
  227. is all gas station had the same kind of gas ??
  228. Fuel Delivery Questions
  229. Car Price
  230. Turbo? Intake? Belts? Leak?
  231. installing coilovers
  232. Need some help
  233. Need files hosted?
  234. Fuel pump question...
  235. GSX lower?
  236. Center of Gravity
  237. My money pit
  238. 95 GST WONT START>PLEASE HELP!!!!!!!!
  239. Horrible Luck...
  240. More help with my eclipse lol.
  241. Difference between 1G & 2G trannys?
  242. Clutch Question
  243. Your opinion on this package???
  244. Turbo has taken a turn for the worst....
  245. EVO III 16g turbo !!!!!!! buying quick quest
  246. mach1 car accessories?
  247. car problems
  248. Audio questions
  249. Turbo Boost To High
  250. cruise control seems off
