View Full Version : Off-Topic
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
  1. Idle problems..again..
  2. GSX or GT
  3. New personal best.
  4. Eagle Talon mods...
  5. ticking noise
  6. car won't idle HELP
  7. boost problem
  8. running rich
  9. 2 gen bov?
  10. a quick tranny question
  11. 1gen BOV Question
  12. valve seals
  13. Lowering a RS
  14. oil pressure gauge
  15. GSX wing
  16. eibach pro kit
  17. what kind of hp increase is to be expected
  18. Trick to coils?
  19. Another bodykit Q
  20. 93 eagle talon dl need turbo help
  21. car wont start
  22. tricky lil nitrous kit
  23. UDP upgrade
  24. shift cable adjustment
  25. Body kits, good deal or no?
  26. oil in my water ? what could it be
  27. Maunal Transmission
  28. Exhaust
  29. Bodykits.com
  30. Clutch and Flywheel
  31. air fuel????
  32. headlights??
  33. wont stay running when gets warmed up
  34. Blown Turbo? Smoking!!!!
  35. holy rice alert, Batman!!!!!
  36. Body kits
  37. Spraying stuff in your intake manifold!
  38. Best engine mods...
  39. I think its broken...
  40. What is good to clean glass to show quality?
  41. cutting stock springs VS lowering springs
  42. Going faster in a non-turbo car?
  43. 1997 Eagle Talon Engine
  44. Sensor help
  45. Gees, Any Suggestions
  46. anyone selling a 97-99 eclipse gst????
  47. 91 Talon TSI F/S
  48. pcv disable w/ catchcan
  49. installing o2 housing and turbo back exhaust on 97 gst
  50. whats the difference?
  51. front bumper ?? racerwheel??
  52. tubes for BC
  53. rebuild or buy
  54. my eclipse isn't getting any power to the fuel pump
  55. 99 GS Headlight bulb replacement
  56. Car wont stay started
  57. 1997 Mits. Eclipse Gs-T for sale in so. cal.
  58. who went to the shootout?
  59. 1gen fuel pump..broke the fuel line! what should i replace it with?
  60. How do u take off the dashboard in a 97 RS?
  61. Need a Car?!
  62. ngk sparkplug gapping
  63. Tilting car for oil change.
  64. Starting difficulty
  65. Sellin 12sec. TSI
  66. boost gauge
  67. Air Ride systems. Do they screw up you cars camber etc?
  68. Phantom Grip or Quaife America LSD
  69. Sealing The crank case and torque patterns
  70. some new toys
  71. Trade: $11K built SCCA Rally car for DSM
  72. just got a 95 gst want to know stock hp at wheels and at motor
  73. i love my Eclipse
  74. my new clutch
  75. Check This Fat Ride
  76. Takon Fails Emission test
  77. Short Ram Sucking Hot Radiator Air.
  78. IMPORTANT: tachometer on 97 eclipse
  79. Dejon UICP
  80. '92 Talon - Slight Vibration
  81. Clutch
  82. Oil Pressure: Reaching Dangerous Levels
  83. Thinking about selling my Eclipse!
  84. PSHHH sound on a stock turbo ?
  85. My first Log!!!!
  86. what u guys think..
  87. WTF! My Engine IS FU*KED
  88. I need help with a video
  89. Wheels bouncing on launch.
  90. Anyone know the price range for a good catalytic converter for a 96 Eclipse GS-T?
  91. Weight Reduction Tips
  92. Quaife LSD or AWD?
  93. dealership fix lifters??
  94. A few 1g Free Mods
  95. 91 wont start
  96. Apex'i Downpipe.... who wants it?
  97. vacuum system messed up...
  98. eclipse with high mileage?
  99. yesterdays uicp install
  100. will the Fog come off of the headlights...?
  101. Turnbull Canyon Road
  102. Parts for the eclipse
  103. 1997 Eclipse front bumper..
  104. Need CV axle help fast
  105. DFW meet
  106. Disabling Cylinders
  107. engine type
  108. 4g63 Motors
  109. Difference between 90-91 & 92-94
  110. Metal Shift Track?
  111. Exhaust system.
  112. u guys will love this
  113. idle surge when warm
  114. Ignition Wires jfor 1.8
  115. Made a bad mod, bad interior paint job, HELP!
  116. lancer parts in laser rs
  117. new wheels...
  118. got an eclipse
  119. 90 To 02 Front End Conversion
  120. where is the classified section?
  121. Porting & Polishing heads
  122. 95 AWD Runs on one coil only
  123. Voltmeter in 1g
  124. Should RST keep moderating
  125. Sell me your car!
  126. Headers.
  127. 92 eclispe- what should I do first?
  128. '97 Talon Conversion
  129. Putting engine back in tips
  130. Spark plug
  131. Oil catch can... when it gets dirty:
  132. best bov location
  133. new TV show about racing for pink slips!
  134. For Sale
  135. *Look pictures*BadAss 96 Eclipse POS
  136. Anyone mess with widebody flares? *pictures*
  137. Videos
  138. 95 Eagle Talon Esi
  139. 97 eclipse rs check engine code 31 and 12
  140. It won't Satart (even after I change starter)
  141. Car still down
  142. 95 gs manual tranny fluid check problem
  143. rebuild a 16g
  144. sorry guys but another idenify turbo question...
  145. Pothole from hell!!!
  146. i got a 95 gs looking for mods
  147. Changing my gas filter, is it hard for eclipses?
  148. Bov Leak?
  149. machv update?
  150. motors
  151. transmission swap
  152. eclipse exhaust manifold
  153. Jake!~
  154. Is this to much for paint???
  155. Good deal?
  156. Make my car fast till I buy a faster one...
  157. Electric seat belt Q's part 2
  158. How can i get the calcium buildup off my car?
  159. replacing the front cv's got a ?
  160. what is the psi for pump gas
  161. Won't Start
  162. Timing belt being changed, might as well change...what else in that area?
  163. DSM tuners & talk
  164. Ordering dsmlink some ?
  165. Resonators? better or worse?
  166. Taillight Conversion!
  167. WaNT TO make my car look pretty again!!
  168. Passing smog
  169. update
  170. Is it worh it?
  171. Anything i can do to a 95 RS motor? swap???
  172. SAFC-II Mount
  173. Top Speed?
  174. Fuel Trim malfunction check engine light
  175. Installing Headers
  176. Electric Seat Belt Help
  177. stock gs-t muffler
  178. Tryong to sell my 2nd gen GS-T
  179. Tire Pressure
  180. CAI Question
  181. EclipseRST
  182. vac lines size?
  183. Idling problem, 95 GS
  184. ard performance store
  185. Head gasket or valve cover?
  186. crushing 1g bov
  187. Threads ?
  188. Eclipses have defective head gaskets???
  189. You've got see this! (and I mean GOT)
  190. Weird new clutch slipping problem
  191. 91 talon tsi for sale (parts car)
  192. Electric Cutout
  193. Greddy type S - is this normal
  194. questions on intake
  195. should be joking
  196. Great Cars
  197. Nitrous
  198. mitsu brakeswaps
  199. Custom Coolant Lines...Need Feedback
  200. 95 talon esi mods
  201. GS-T Vs. Saleen S281
  202. Funny Problem
  203. Auto Trans Question
  204. vacuum leak
  205. Drop Top Problems
  206. Tps Quick Help!
  207. Whistle sound when shifting (non-turbo)
  208. Eclipse's insurance is high because of it image
  209. whats the stock boost on a 95 tsi?
  210. completly stock 95 tsi what should i do first for big gain?
  211. rs to gst or gsx
  212. First Post and I've got a couple questions
  213. Pacesetter Catback Exhaust?
  214. Ignition Boxes-are they worth the money?
  215. 1990-1993 Bodykit?
  216. Talon headlights, plz help!!
  217. Older Greddy TT speed single wire.
  218. Downpipe
  219. 95 esi talon question
  220. P1296 Injector Multiple Faults - Bank 2
  221. AIR Intake.
  222. I have the worst luck...
  223. Quick Question
  224. are these the best price/performance parts I can get???
  225. Need help pimpin out the car with neons, but eclipses are different
  226. spoiler -- turbo or nonT
  227. Coil Overs
  228. Runing rich, help!
  229. Wheel well neons
  230. 2 tone leather
  231. Attn Problem Solvers
  232. Price Checkkkk
  233. I Need an oil return line!!!!
  234. parting out 92 eclipse
  235. Engine Checking.
  236. 6 bolt swap
  237. Svt Nightmare
  238. Question about Eclipse
  239. Need help on interior painting
  240. more problems!
  241. Lol!!!!!!!! Everyone Look At This!!!!!
  242. Greddy T88 in an Eclipse?
  243. car has spark some times
  244. G2 Interior paint
  245. Need help with wiring my NEONS through my door pins
  246. The MOF0ing tb cover!
  247. Talon Spoiler?
  248. Stereo Help
  249. Check out the eclipse in the Players Run! =D
  250. disconnect batteries VS check engine light
