suggestions on getting the crank pully off
brianeclipse98
02-16-2005, 02:17 PM
just as the title says. im trying to get the crank pully bolt ogg and its a pain in my ass. suggestions?
gthompson97
02-16-2005, 02:38 PM
get a puller and a longer crank bolt. that always works for me, just don't use an air wrentch on the puller cause it ruins the threads.
kjewer1
02-17-2005, 02:38 AM
An easy but risky way is to put a breaker bar on the bolt, wedged against the floor, and bump the starter. BUt the motor has to be assembled (timing belt etc) since you will be turning it over, and its risky. Dont break a leg and blame me. Otherwise, a real strong impact gun will do nicely. In the absense of that, put the car in gear so the motor cant turn, and get a looong breaker bar/pipe to bust it loose. If the motor is on a stand wedge something in the crank counterweights if the pan is off, or install two flywheel bolts and wedge a bar between then to hold the carnk. I already posted all this a little while back, it would have taken you less time to search for it than it took me to retype it all, now that I think about it :)
brianeclipse98
02-17-2005, 10:45 AM
that is true i will do a little more searching next time. anyways i now no impact gun and the timing belt is off, soooo ill just try option 3 and hope 4 the best. ill let you know the results. thanks
brianeclipse98
02-17-2005, 11:54 AM
SOB!!!!that bolt is a lil bitch. it didnt work. is there any way i can bump the engine w/o the timing belt on w/o bending the valves? thats really the last thing i can think of that would require me having it towed to a shop wiht an impact gun.
david-b
02-17-2005, 04:29 PM
Take it to the shop. Thats what I did. It's not worth it. Have a professional do it. Then it's not your fault
northriverflames
02-17-2005, 04:52 PM
alright, im not sure if your trying to get the bolts loose or pull the pully off......i just got up so im not completely awake...but if your tryin to get the bolts loose, the the car in gear...reverse i think(manual tranny)...then put your foot on the breaks while someone comes onto the bolts with a half inch power bar or big pipe............if your trying to get the pully off, usually a good puller will work, but im not sure how else to do it. I hope this helps, but as i said, im half asleep and im not exactly sure what your trying to do, so if this is completely off topic or wrong, then im sorry, anyways....hope that i could help....
kjewer1
02-17-2005, 11:36 PM
If you have to pull the pulley off with anything more than your hands, something has gone very wrong ;) If the pulley is really that stuck to the crank sprocket, it just pulls it off the crank. I've had that happen, so let that be a warning for anyone trying to remove that pulley with the timing belt installed. You should be able to leave the main center bolt installed though and just remove the 4 12mm bolts, but some people just take them all out. That would end up making you do a full tbelt setup again pretty much.
brianeclipse98
02-17-2005, 11:57 PM
nah im just trying to get the dam nut off. ive tried EVERYTHING that ive read in the fourm and its not even budging. so im getting a trailer tommrow and hauling it to my buddies shop. impact gun, lift and all the goodies. if that wont get it off then i dont know what ill do.thats the last thing i can think so. ill let you guys know the results. thanks for all the help guys.
kjewer1
02-17-2005, 11:59 PM
A good impact gun will always get it. Good luck.
gthompson97
02-18-2005, 12:00 AM
just make sure you DO NOT STRIP THE THREADS OUT OF IT......then you will be shit outa luck.
kjewer1
02-18-2005, 12:02 AM
Not much you can do about that. The threads are way up inside the crank, on the other side of that crank sprocket. If it pulls out the threads something was done wrong on install.
Remember to torque that bolt to 80 ft-lbs when you reassemble.
brianeclipse98
02-18-2005, 11:41 AM
ohhh wouldnt that be my luck to strip the threads. reassembly...lol im not even thinking about that right now. while im in there im doin the whole 9 so i dont have to do it again in the neat future. water pump, all the belts, cas, ect, ect. thanks for the heads up.
bighauns
02-19-2005, 10:50 AM
When I was disassembling my old engine to part out all I did was stick a breaker bar in the opposite end, sprayed the bolt with WD-40, and put a socket wrench on it........Then I kicked the socket wrench and it came off. I didnt care if it wrecked anything as it was never going back in a car. I don't think it realy could, but just like you I tried everything else, so finally I got mad and tried that...AND IT WORKED :-)
good luck!
kjewer1
02-19-2005, 04:07 PM
I have several techniques as well that would make Jet Li proud. Do whatever it takes :D
brianeclipse98
02-21-2005, 09:32 PM
I GOT THE SON OF BITCH OFF!!!!!!! it took me all day, a uhaul trailer and an impact wrinch but i got it. towed it down to my buddies garage and he hit it with the impact wrinch and came right off. i can tell you it was a BITCH gettin the car on the trailer tho. but none the less i got it. now i have to fix everything and but it all back together.thanks for all the help guys and i hope this helps people in the future.
