Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Mitsubishi
Eclipse/Talon/Laser
> Engine, Transmission and Drivetrain
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
Gm Maf
Need Help! Timing Belt Tensioner Tool Broke Off
1.8L to 2.0L head Mystery!
front mount intercooler
Oil feed lines
What should I do...
Cleaning engine block
Seafoam through vacuum line?
Coilover Question
Running an open downpipe?
My compression readings
oil filter housing
4g63 boost
Revs not falling fast??
path to take with gauges..
Apexi N1 exhaust
6 bolt in 2g
big 16g turbo
3" cat back exhaust
Shaft play
Megan downpipe for less!
Anyone with Prothane mounts...1G
420a Rebuild - Ongoing Advice
intake
E85 Anyone using it yet ?
e316g ported and ready to go!
I'm back :)
Leaking Oil!!
TD05H 34mm or oem 28mm?
300awhp, stock tranny, upgraded clutch?
wat basic mod should i do
02 sensor
oil filter housing
fuel pump
Found this information on turbos
what to do next?
What Motors/Trans fit in 1997 Talon?
exhaust
420A Motor
Oil Catch Tank
anti lock light on
solid tensioner?
is there anyone that has done the 6bolt swap into 96 talon
Just did a compression test on the talon
test pipe fitment??
Fuel pump
replacing timing belt
oil catch cans...
headers
Tranny Trouble?
Need a manifold to use with external W/G
Can Someone Help Me!!!!!!!!!
a Good Ecu Chip?
New Here...Any1 Sugest Lowering Kit
Southbend?
stock crankshaft- 420a
Rim Question
Exhmanifold question?
Fuel Kit
98 eagle esi 4g63 swap!
98 eagle talon 4g63 swap?
Cam sensor
Who rebuilds PTE turbos?
will a 6bolt 4g63t engine go into a 96 talon
Water/Methanol Injection
Tranny, center diff strength
1g bov flange same as evo flange?????
Engine rebuild
stock valves vs. aftermarket
What would you do with $600?
turbo question?
Do I need a Fluidampr?
Sneaky nitrous
Vacuum Line Removal
Pulley ?
Sbr Fmic
Little Disapointing...
AEM V2 Intake
What kind of spring?
Turbo Eclipse Upgrades
Head
need good website that list restrictions i can take off
Valve Stems
topline pistions
Strut Bar
Head Rebuild
Plans for next spring
Oil
New Engine
Non turbo 1g head
how do i crush a BOV????
ESi TSi chip swap?
Do Aftermarket Springs come with Alignment Specs??
boost gauge wiring 2g
Suspension Question
Big 16g
Porting the bitch!
Turbo kits?
nitrated valves
Performance upgrades
Pocket Logger
Plug Wire Question
Install Cam shaft
Cheap engine mods?
Ebay Intercooler Mistake?
Tubular Exhaust Mani
i need help please
i need help
Fu*king intercooler pipes...
eclipse...or trans am?
Boost creep and DSMlink questions
Need Some Help w/ Shocks & Springs
turbo kits for gst/gsx
94 talon 1.8 wanting to do a swap
Finally removed the tranny and look what i found
T28 turbo and other upgrades
timing belt woes :(
what to do first??
Datalogger..
whats the easiest way to remove the head?
Eclipse drift kit is too low to the ground.
2g 5spd gst and 2g auto gst
Topline pistons vs. Nippon racing JDM (e-bay)
Looking to buy a used turbo for a civic, not sure which to go with
laser AWD conversion need help
Stroker, High reving, spooling...
Top End
Rebuild questions
Tranny questions on a 95
Turbo a 420A... I Want Your 2Cents
Megan Racing Headers
Vacuum Leak help
MSD ignition boxes
ECU's
95 Tsi turbo
need some guidance please
1g BOV modding question
up and running LINK
Brand of timing belt?
6 bolt swap?
New engine and re-build engine kits sites?
Crankwalk!
building a head
Fixing a vaccuum leak??
lol Max Boost?
96 eclipse spyder gs 4g64 swap?
Spray?
wont start!
1st Gen pistons
Water/alchohol injection on a N/T
Over Bore Question
What happens when you run lean ?
Rebuild Heads?
2.3 stroker and turbos
Fuel Line and Fittings... again
Need a little help, please
firing order on Linked '99
Bought a new turbo
Tranny and transfer case life
will it fit???
I Need T3/T4 INFO
Short Shifter
hm tune time and pump
I Need Opinions...
Tial 38mm Vs. Synapse 40mm
Evo engine swap into a 99 eclipse?
conquest fmic??
speed chip?
Tire Size vs. Performance (More Info?)
Motor Interchange
Intercooler Plumbing
16g turbo intercooler
More Power
shock and springs
Megan Racing full exhaust system
tune....
difference between MBC's
Chrysler sebring or gst??
Cam Gear Info
Oil Catch Can
Buying a turbo...need advice
Need A Little Help - Pistons
injector size and tune
Injector difference HELP!
Best manual boost controller?
safe?
130 from a GST??
egr block plate help
non-turbo to turbo
What is boost?
1.8 ring replacement
difference between gsx and gst
ummm
Bored Throttle Bodies & ECU.....
turbo- piston compression realation 420a
EGT Probe Wiring
auto to manual parts list
What should be my next mod????!
taking the motor and tranny out of my 95 eclispe gs
Changing out Header/ Any Suggestions or Tips?
Engine swap
slave cylinder
420A neon with auto trans to 420A eclipse M/T swap?
CEL for emissions
Throttle body?
Posible?
GST to GSTAWD help
Where do I plug in my tach????
Short shifter?
How many PSI safely on a 1 gen 4g63t stock motor?
I finally did it!
Braided Fuel Lines
Intake and throttle body 90-94
SAFC, RPM Question... Rich?
Best EGT location
Is the 1G intake manifold the same for turbo and non turbo ?
what Exhaust manifold?
PTE 50 trim or 56 trim?
99 eclipse gsx
Need help upgrading my 95 talon tsi AWD
upgrade help on 95 talon tsi awd
Natural VS Synthetic
Another problem on eclipse rs
engine or crank for 96 talon
getting bigger turbo?
crank swaps
Oil from muffler?
Anyone use the G-Tech Pro SS?
Anyone use an OBX Fuel Pressure reg ?
1g/2g Transmission help!!!!
Question with transmission, 93 talon
afc neo tuning for injectors
need a new clutch!
ESi -vs- GSX brakes
Swapping rocker arms
exhaust manifolds
valve stem seals
Dual Exhaust/ Compression and HP loss??
Turbo Exhaust on a Non-Turbo
Slim Line Fan Performance
heat shield
Greddy/Denso injectors or FIC injectors
new suspension - rattling
new 92 eagle talon tsi awd w/cyclone
Rebuild: 420a (input)
Rear Strut Bar??
Getting my T-belt replaced on Thursday...few questions
Honeycomb for EVO 8 MAF.....help
1g dsm suspension??
New Engine HELP!!
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
