a Good Ecu Chip?
95Talipse
11-28-2007, 10:59 PM
just woundering what a good brand of ecu chip is for a 95 talon esi. Thanks
david-b
None... Easy as that. There is nothing available for it.
SilvrEclipse
11-29-2007, 02:15 PM
Nothin for the 95s. Howell makes an afx ecu for the 97s. Not to sure why they only did that year. Search around some, there are other things you can do to your car to make it a bit quicker.
kittay
12-03-2007, 12:26 PM
95s came with Eproms.. so why wouldn't there be anything available?
Make sure that your ECU is Eprom. If you are not sure if it is, look for this:
http://i15.ebayimg.com/05/i/000/c9/4c/e563_12.JPG
here's one place to check for chips:
http://www.moates.net/index.php?cPath=26
MazdaX
12-03-2007, 12:42 PM
Most EPROMS are custom hacks and not really cross compatible to compensate for modifications unless preprogramed to. Chips = crap get a custom ECU or SAFC and upgrade your bolt ons.
kittay
12-03-2007, 12:46 PM
I'm running stock ECU that's chipped. I'm about 350hp and running low 12s.
SilvrEclipse
12-03-2007, 01:19 PM
Kittay is correct - There are available chip for the EPROM ECU's.
However, the original question was pertaining to the 420a ECU which can not be chipped.
steviek
12-03-2007, 04:01 PM
ya man 420a motor here not dsm chip
be careful when you give advice cause if its wrong you do a lot more harm then saying nothing
kittay
12-03-2007, 05:30 PM
Oh.. totally missed to ESi on the first post.. oops
