Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Mitsubishi
Eclipse/Talon/Laser
> Engine, Transmission and Drivetrain
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
What
WTB: 16g turbo
surgeing
flywheel torque??
flywheel torque?
Turbo
safc2/boost question
injen cold air intake
No Airfilter/intake
4g63t selling, buying and shipping?
bad o2 or pcv?
Air Box
Parting out 1g Eclipse GS
primium fuel
Control arms: lowering the car, and stress and strain
spark plugs of right heat range
putting my turbo in an imprezza
gsx?
6-bolt SBR swap complete, ready to roll ***PICS!!***
new injectors on 420a with a turbo
dsm link
Exhaust System-failed smog test
salty roads, cold cold weather!!!!?????
greddy turbo timer
Winter Preperation
LUCAS oil stabilizer
1995 talon esi engine swap
exhaust
eclipse & talon compatability
97 tsi proformance part selection
Stock temperature gauge... is it oil or water temp?
parting out a 95-99 eclipse
some help with turbo selection
I am new to brakes help me!
Brake Pad Replacement Question
turbo...gt3076r(dual ball bearing)
Bosche Nightmare(WARNING)
eclipse gsx i need help bad
hhm...interesting 420a swap thought
2g Sportstronic?
Need reference from 2G GSX owners, please
Evo VIII into a Talon TSI???
Cams and noise levels...any cure?
car specs
bov question
Considering a 1995-99 gst/gsx, few questions
Removing the BCS restrictor
6-bolt swap, test drive, some issues, please read:
Cheap Oil Catch Can?
Goin awd to rwd...?!
4G63 engines
perfect 1st gear pull
1.8 accessories?
Looking for a 6 bolt
What other cars have the 420A motor?
What size injectors should I get?
to stroke or not to stroke
1991 eagle talon transmission upgrades
External Wastegate Questions
Polished pistons
Who knows auto 95 GSX trannys
98 GSX or GST
wheres a good place to buy aftermarket turbo's?
Clutch and trany problems
turbo
3 inch mandrel bent exhaust for sale
Slip over coilovers or full struts or what?
vaccum is this my problem
GST vs. GSX 1/4 mile
Can a lighter underdrive pulley cause bad vibes?
Strut tower bar
What clutch to get?
I need a loud BOV!!!
Combustion chamber cleaning
JE pistons and rods any good for a stroker?
95 gsx vs 97-99 gsx
EVO III 16g turbo
Computer in dash
Clutch Problems
3000GT engine swap help
Best Pump gas turbo
What the hell is in my vacuum tube!?
2.0 bolt right up to 1.8 tranny?
Nice BOV!!
1g 4g63 vs 2g 4g63
headers
AUTRONIC ECU is it any good?
GReddy piping with a 16G
6 bolt question
90 Eclipse problems
6 bolt/7 bolt hybrid?
nitrus on a stock talon tsi
1996-99 Mitsubishi Eclipse
Do you have to move the batt to have a Magnus intake?
Light wheels
Filter Placement?
Wiseco Standard Sized Pistons
2G elbow on 1G throttle body?
auto rs
4g63 6 bolt swap
Tube and fin or Bar and plate Intercooler?
Serious Help Please
Help me identify this turbo...Please?
1g bov diagram?(How BOV works inside)
Exhaust
NEED engines need
2003 GT Mods
Head Porting
Never buy OBX gauges
broken timming belt
Turbo for a 2.4
Will a cat back for a hardtop GS fit my spyder GS?
Aany Good DSM TUNERS in Orange County
New Car mods
GS--> GST Info
What does this hose do?
Ignorant Question, replacing Sparks Plugs
Buy or not?
4g63 gsx
95 99 eclipse talon wheels
GST to GSX conversion?
Mbc
Intake Question
4g64 performance questions.. PLEASE HELP!!
Hahn turbo kit install in 2g nt
Muffler
lt1 aftermarket maf sensor
Exhaust install question
Electrical/Alternator problems PLEASE HELP!
1995 Eagle Talon Tsi
exhaust for sale
Great deal for a 420a turbo kit...
Depressing =(
compression ratios
Need help ASAP!
New Engine...
talon to eclipse
1g turbo motor into 2g none turbo car
exhaust question
1990 laser turbo manuel trans for sale
Max HP on stock motor
parted out 2nd gen...left over performance parts
1g trans into 2g car
best turbo back exhaust????gst
Greddy Type S BOV from a VW
Stock BOV question
Bov question
TurboXS Dual Stage Boost Controller Tuning
How To Change Automatic Transmission fluid and Filter??
engine mounts???
3" exhaust question low end vs high end
motor swap
aftermarket muffler can't fit?
93 eclipse upgradables?
99 Eclipse Rs For Sale
good lord where to begin....
Shady Shot Nitrous?
Easy to install mods
4g63T turbo engine
Resistor Chip ?
turbo...trim...?
Clutch or Tranny Problem
afc closed loop questions
tranny
bigger not always better or is it
Vaccum lose Question.
2.3
Dont Think Its Covered In The Faq
7 bolt 6 bolt?
Where should i get......PLEASE HELP
5 spd conversion
Are ECLIPSE and TALON parts the same??
WOW, its like impossible
Center Differential For Sale
Ci
SAFC II problems
how to get more horsepower
Opinions wanted for this BoV 1g from ebay
Exhaust manifold bolt missing...
Rules and Regulations: Follow Them
Rules and Regulations on this Forum
Profec B SpecII vs Profec B Type-S
Suspension question if I may
cams and wastgate
6" JRC intercooler or Supra SMIC?
nitrous
Talon Turbo Into My 95 Eclipse Gs
squeeking noise on a 96 GS
2G Eclipse RS Drum to Disk Brake Conversion
Do it yourself, Lifter replacement
Raise the Redline for a 420A
420A upgrades. how much hp?
Exhaust Question??
Manuals to rebuild an engine
boost in an rs...need specifics
RS vs. GS, & (mods to start)
DSMlink and EPROM. ECU recognized as a 95, not 97 on receiving end?
brakes
Turning up the boost.
Manual Transmition
EvoIII 16g Makes 400hp+ AGAIN
turbo gs, low fuel pressure need help
GSX purchase
Rebuilding 95 eclispe RS engine
What can the 420A crank take?
RS*R springs good?
Best Clutch For a 420A?
boring a 420a .30 over?
28 lb/min on the Evo16g? Did I reinstall my T25 by accident?
ebay fraud, watch out!!
E-85 gas
Swaping Engines RS to GS
Exhaust Cutout?
engine question
boost heads
Are these good mods to start with?
JohnnyRacecar FMIC Installed
Part info for Eagle Talons
Strut Recommendations
420a motor with NOS
best street/strip tires
16g install tips
6 bolt time bitches.....
SSQV Question
Very Stupid Bov Question....
Tuning a dual stage turbo setup
Stock BoV
i am running to rich
Can I put a 2nd gen 4g63-t in my 97rs eclipse
Forced Proformance 18G CHRA (56kdeath:big pics)
Question about the upgrade paths
Throttle Body Spacer Install
IAC and Alternator...
homedepot intake question...
91 tsi exhaust
420a and srt-4 swap
high boost on 420a motor
who says we cant rev past 9,000rpms.....
AFC with stock injectors?
Running rich
420a Going all out
WTB Engine for 95 Eclipse
Compression Ratio
Greddy Type RS
Bov
My Baby Is Dead
engine problems
Eclipse GS Performance
98 NT parts for sale
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
