View Full Version : Engine, Transmission and Drivetrain
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13
  1. Bolt size?
  2. recirculating hose replacement???
  3. Logger question with o2 and knok
  4. Dsmlink
  5. 14B questions.
  6. Ron Shearer's new gt42r manifold
  7. Anyone ever use E-85?
  8. Thicker head gasket to lower compression?
  9. My official parts list for the 6-bolt swap
  10. Home made SMIM
  11. Timing belt change questions
  12. varaible boost controller
  13. HKS 280 Cams....
  14. Tranny Rebuild?
  15. 2.3 or 2.4?
  16. turbo Decision
  17. engine swaps
  18. So I have a big 16g.... now what?
  19. Question about a possible transmission swap
  20. transmission questions
  21. HORRIBLY burned cluch! Damnit
  22. Wastegate Cotter Pins
  23. xtd clutch
  24. obx
  25. 90 GSX head bolt torque specs
  26. intakes
  27. BEP 50 trim vs 57 trim
  28. gst and gsx difference
  29. Mbc
  30. Fittings....Oil feed line...
  31. Clutch & Flywheel
  32. Oil pump = Owned
  33. Tire sizes
  34. boost on T25
  35. 2g radiator into a 1g?
  36. 1990 Talon Tsi Performance Suggestions?
  37. Drilled Rotors???
  38. atomatic to manual conversion
  39. tranny help quick
  40. Head rebuild opinions
  41. compression? pistons or head?
  42. Is this a good logger?
  43. Difference of engines?
  44. Dyno results in!!
  45. Cause of crankwalk.......
  46. Fmic installed few problems... but looking nice
  47. more bang for a buck...
  48. How much HP with head work?
  49. Awesome deal. 4G637 1G to 2G Swap Question
  50. I Need a recirc adapter
  51. Quick Header Question..
  52. safe boost level T28 50 trim
  53. greddy auto timer
  54. Tips on porting?
  55. A friendly reminder to change your spark plugs folks.
  56. changing rod bearings?
  57. Final say on my Head gasket
  58. About the arp head studs!!
  59. 97 eclipse gs can i put a turbo in it
  60. Clutch suggestions
  61. HKS Mega Flow Intake Cleaning??
  62. best engine to swap in a 99gs?
  63. 30k mile maintenence?
  64. royal purple syncromesh??
  65. looking for a downpipe..
  66. Big brake options...
  67. Stroker Vs. Destroker
  68. Rebuilding my motor
  69. To rebuild or not to rebuild...thats the question...
  70. please help asap suspension question
  71. e-brake light
  72. difference between turbos
  73. Change of transmission?
  74. lowering car need help
  75. ECU question
  76. What kind of OIL?
  77. Megan Racing Fuel pressure regulator
  78. boost spiking to 20 psi
  79. My eclipse is faster than yours-revised
  80. Relocating and eliminating lots of little things...
  81. 420a worth building up? Look.
  82. Oil cooler?
  83. Turbo opinions, help guys!
  84. how much hp?
  85. MBC in or out?
  86. Since it takes forever for someone to look at in Performance!
  87. Good Idea/Bad Idea?
  88. external dump
  89. Fly wheel and Clutch Questions
  90. 1997 stock wing?
  91. Check these cams out DKS(HKS)
  92. Fuel
  93. N-tercooler fmic spray kit
  94. Oil... what kind?
  95. wbo2 question
  96. 1000hp fuel setup. (56k WARN)
  97. turbo's and heat
  98. Buying FPR, which is better?
  99. Upper strut tower bar?
  100. Stuck in an alright position...
  101. destroker kits
  102. SS autochrome FMIC (GB)
  103. FP2/Comp 101200 Cams... idle? streetability?
  104. Fixing my DSM... head gasket, timing/bs belt, b, and tranny fluid/oil questions
  105. Fuel Pump Rewire?
  106. Anyone use these?
  107. Fpr
  108. O-ring head, OR block?
  109. what kind of engine?
  110. SAFC and FPR
  111. Need help routing my FMIC
  112. OK, I have finally decided what to do.....4G64T
  113. socketing ecu
  114. crash bar
  115. Megan Racing Short Throw Shifter Install...
  116. Motor Mounts
  117. AWD drivetrain compatibility
  118. Ebay FMIC
  119. 1g rods....
  120. 1g or 2g head gasket?
  121. Water Injection...
  122. Eclipse... hmmmmmmm is there a rear wheel drive version ?
  123. Pulling my Trans!!!
  124. Just installed Greddy Profec-B SpecII EBC, absolutely amazing.
  125. Turbo Experts
  126. Valve Job on 2.0 nonturbo eclipse 1995
  127. Fuel pump questions
  128. What should I expect?
  129. Recieved my XS/ssautochrome fmic today
  130. How do you hook the cam sensor up on a 1g head to a 2g car?
  131. best suspension again...
  132. ebay clutch
  133. Questions on valve seals
  134. Tranny difference???
  135. My Spyder project plan has become murky.....need help making decisions
  136. Will I be ok??/
  137. performance suspension
  138. SBR G50- 50 trim vs MHI Evo III
  139. 2g Knock Sensor??
  140. big t-28
  141. valve cover remove,instructions
  142. ebay hks sponge air filter
  143. easiest way to change piston rings on 96 eclipse???
  144. Octane boosters?
  145. What head gasket to use?
  146. Best Launching RPMs
  147. Whats the best website to get a thicker head gasket
  148. Stock fuel pump
  149. Choose my Boost
  150. Why do some cars make more power on smaller injectors?
  151. fuel system
  152. Slowboy FMIC
  153. Buying head for rebuild
  154. T. Timer basics
  155. Need help with some eclipse potential questions
  156. Filter Size On Gsx
  157. 96 Eclipse not starting
  158. ECU, Turbo
  159. h.p gain !!!!!!
  160. overheating problem?
  161. Installed SAFC
  162. flow rate
  163. suspension question
  164. Cat converter and o2 sensor
  165. Megan Racing Coilovers.
  166. Pulleys
  167. how complicated are turbo's?
  168. Opinions on exhaust setup
  169. budget stroker vs 4g63
  170. Rebuilding 4g63 non-turbo Engine
  171. Im pretty sure KEVIN said this about injectors
  172. feul pressure
  173. 1g short route
  174. turbo blown, time for an upgrade?
  175. Ebay Product *need opinions*
  176. 1g intercooler piping
  177. Pulleys
  178. tsi fwd v. tsi awd
  179. buying 272/272 cams (101 202?????)
  180. DSM lingo ?
  181. Buying illuminas or HP
  182. Mitsu/Garrett T28 turbo
  183. PVC IC piping?
  184. Ebay...to good to be true?
  185. Things to do when swapping to a 1g intake manifold?
  186. 1G AWD conversion
  187. question
  188. Carbon Fiber Driveshaft
  189. MSD with Coil on Plug
  190. How to tell the diference between a small 16g, big 16g, and an evo III?
  191. SBR fmic...opinions?
  192. Questions about when i get my DSMLINK?
  193. ??? for SAFC guys.
  194. 1997-1999 Eclipse Exhaust Question!
  195. opinions?
  196. Air Suspension
  197. what made the gen1 1.8 so peppy?
  198. eclipse in distress
  199. Turbo Help
  200. eBay parts
  201. Apexi turbo timer question
  202. My plan for next mods; I could use advice
  203. $1500 to spend so tell me what to buy!
  204. Finally The Eclipse Is Given A 4g63 Again!
  205. Lower Springs
  206. Turbo MAF, NT MAF
  207. opinions on a slow boy racing 50 trim
  208. whats thebiggest FMIC you can go with in stock front
  209. Turbo shopping...
  210. AFPR install??
  211. new v. old
  212. possible to add a 6th gear?
  213. How to Clean TB N/T
  214. 1997 eclipse turbo skimatics
  215. Cams and head
  216. power distribution
  217. what would give me more power?
  218. Anyone need a Modified Jeep TB for 95-99 NT?
  219. 95 awd conversion"need professional answers and thoughts"
  220. Fuel filter
  221. valve breather
  222. More powers
  223. Mass Air Flow Sensor For 1G GST
  224. turbo charging
  225. stock internals
  226. Would I ...
  227. how much
  228. how reliable is it
  229. High reving 2.0 or torquy 2.3?
  230. Evo2 Engine Swap Into 95 Talon Awd
  231. Freewheel or interfearince motor
  232. What can i do?
  233. DSM electronics
  234. i need a wing!
  235. 4g63T Swap
  236. t3 50 trim
  237. yet another header post...please dont ignore though
  238. Engine Swap (this ones different!)
  239. Stroker
  240. Anyone ever put a torque spliter in the GSX / Tsi AWDs?
  241. Port the 2G head, or go with the 1G?
  242. exhaust question...in need of a quick response
  243. 4g63na and 4g63t downpipes the same ?
  244. Hey O
  245. Pulleys
  246. Venom 400
  247. my turbo?
  248. engine sizes
  249. Oil
  250. selling/trading 4g63t 1g!
