Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Mitsubishi
Eclipse/Talon/Laser
> Engine, Transmission and Drivetrain
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
what to do
BOV with an 95 Auto Talon
gsx brake up grade
turbo conversion?
Turboing a '95 Talon ESI
Stock Eclipse GS-X 165 MPH plus?
buying a GSX
My new catback
97 motor defect
4G63 Any alternatives
4g63 '98 ECLIPSE GST ENG. 4 SALE. 9K MILES
Tranny Cooler
1995 Eagle Talon ESi Vs. 2005 Honda Accord Coupe i4
External WasteGate
DSMlink, 1G version
wires, coil, and plugs!
shifter kit
gutting car and need advise, srs and rollcage
Great plugs at a cheap price
Q Octane
Hard Pipes And Greddy Bov Gone Extremly Wrong
Tokico Illumina Suspension Kit.
turbo... help
Stroker Kit for 4g63-T
Opinion on this turbo, I found used.
Need tranny help
engine sawp
Reccomendations for my Spyder...
Parts On Order...
B&M short shifter
RRE GReddy upgrade lower U-pipe.
Looking To Buy
has anyone ever seen this!?!
Intake?
How to install a udp?
4g63 non turbo cams?
Help
if i did this could i beat this
Which Turbo should I Get?
I'm looking for an AWD eclipse......WHAT TO DO???
gatorback
Engine swap
What do you think about these items?
n/a top HP.
guage replacement
consequences of venting
How does a large FMIC affect air flow to radiator?
Hopefully last question so I can get my car going.
***FAQ*** Read this BEFORE you ask a question.
4G63 cyclone swap
For everyone interested in TURBOING AN RS/GS OR TALON ESI!!!
Can You........?
::Eclipse Spyder HP::
Turbocharger Compatability
Installing a t3 turbo on a 420a motor
Performance Throttle Bodies.
Transmission Strength?
'91 Eclipse 1.8 SOHC engine swaps?
How can i make my eclipse faster with out a new engine?
v-6 swap in 2g eclipse?
Get the engine running?
What to do to this engine?
rally tires for 1g
coilovers or air struts/bags?
1995 GS-T...Reliable? Thrust bearing problem?
Boost controller and Boost gauge
exhaust for my GS-T
exhaust
crank walk
turbo??
bad trannys?
Evo engine in the 95-99 GSX
performance work
Mivec
Crankwalk theorist
question for a friend about engine swap
engine making vibrating noise in lower end
which turbocharger should i get
headers and exhaust
Stupid Engine Question
bypass valve?
4g63 / 4g64
Eclipse Engine Question
Lifter Tick?
Swap or Turbo
92 Eclipse Head
gs engine, i need more power helllpppp
crank walk?
spark plug gapping
Head Gasket Blown?
6 bolt, 7 bolt?
Skunk2
Racing Engine
99 eclipse shifting problem
1995 Eclipse RS rear brake conversion
4g63t specs
Power loss
AEM filter
Crankwalk!!!!!
changing oil and locating fuel and oil filter
horsepower of a 1990 eclipse awd turbo
Turbo for 1990 Toyota Supra
turbo timer
OBX NT headers
EFI systems PMS
Turbo Timer
VR4 Engine Swap
Engin problem!
Engines?
adjusting the psi on a t-25
Turbo Swap?
Apex'i Muffler
Brake Calipers
project turbo
Crankwalk and such...
Blueprints
clutch
suspension ? please help
Rebuilding the Engine
Suggestions.................
1996 Eclipse Engine swap?
HELP when did your clutch go out?
turbo upgrade
engine swap for the 1996 gst
wheel offset
Header Install
Modifying a 95 GSX?
Porting
Lancer Engine
Which Exhaust do you have?
Greddy & Skunk2 Exhaust Question! Please Answer!!!
turbo exhaust size please help
hydraulic or cable transmission
Blow Off Vale
exhaust system
20G supporting mods
Suspension Suggestions
Eclipse GST
how much HP can a eclipse handle?
auto to manual??
Horsepower # from CAI/H/C/E 2nd Gen...
how much hp can u get from a greddy evolution exhaust system(60mm piping and 115mm ti
engine swaps...
brand intakes
Suspension
exhausts
4g63 in a Gs/Rs
evo engine into eclipse
Coilover height problem?
ihi turbo install
Turbo??
general ?'s
Tire Size???
Supercharging
RS or GS to a GTX
whats wrong with my fourth???
repairing the ECU
Custom Apexi SAFC and Install Ideas WISH LIST
engine swap?
can i change my auto to a stick?
supercharged/vertical door conversion
Exhaust
Stock turbo.....
Eclipses Have Engine Problems?
mod advice
Exhaust? Please Read!
Torque split
Which turbo?
Help with TSI AWD build up.
gs-t conversion
Turbo ?'s
Exhasut Questions
Problem: red hot cat
Apexi Exhaust ?'s
Muffler
4G64T DOHC Hybrid Engine
Nitrous?
crank walk
auto to 5sp swap need help
1g horsepower
Crankwalk
Upgrades?
HELP w/ Greddy Profec boost controller
eclipse internals
all motor
turbo???
Crankwalk....Evo motor?
90 trans in a 91 eclipse, will it work?
Adding a turbo to a non-turbo engine....
twin turbo eclipse??
govenor
breathing better
Best sounding muffler for Eclipse?
non-turbo to turbo
fully built engine?
Trannie Swap? HELP PLEASE
exhaust info
Bolt Patterns?????
speed
speed!!!
NOS And Turbosystem
T25 vs. 14b fitting
engine mods
bought my first turbo
just bought a 95 eclispe gs-t..any ideas on mods?
Coffee Can Exhaust... TOO LOUD
where can i get ecu upgrade
Clutch
Dual Exhaust/Mufflers for 96 Eclipse
apex front mounted intercooler...how is it?
anyways to increase top end power?
Stock 95 GST boost?
transmission
slap shifter??
22lbs psi! oh my god!
blu engine in my 93gs but the bodys perfect is a gst engine the best answer
White smoke
91 talon intercooler
Help on parts specification
ct-26 turbo?
want is this "CRANKWALK?"
intake convertion quesztion
95 Eclipse fatf?Muffler?
What is the difference in 1st gen gsx/gst engines and 2nd gen
Engine Question 95-99 eclipse
Crankwalk
HRC O2 Housing
air filter?
4g63t
rs/gs
DSM injectors on honda b-series motor
engine swap
eclipse to 1992 mirage engine swaps
3000gt part swaps into eclipse input wanted
Isn't the GST rear wheel drive??
3000GT twin turbo in 93 eclipse
turbocharger question
APEX-i N1 exhaust system question
how to launch
Exhaust help
fans not working...(urgent!!!!)
Engine idle loops
Engine Blocks??????????
500hp
Cat back exhaust
crankwalk worries
super afc
Awd
Starting engine mods--where do I start?
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
