shock and springs
Gsst98
09-16-2007, 05:39 PM
I was thinking about gettin this tokico shock and spring package http://www.machv.com/tokshocpac.html (http://www.machv.com/tokshocpac.html)
can anybody tell me if this is a good combo id be getting the lllumina package. Or would gettting sway bars make a bigger differnece?
Black99GST
09-16-2007, 06:20 PM
its good... a little high $$$... but its a good set up!
SilvrEclipse
09-16-2007, 11:24 PM
I got that same set up with the illumina struts. Its a good set up, the car rides pretty smooth and handles great.
NOFX0617
09-17-2007, 12:51 AM
I got mine and I love them. They have a really good stiff feel to them but still a comfortable ride. It does scrape on stuff if you go too fast but is really managble. You can also get them much cheaper on E-bay. I think i got mine for like $475 for that same package.
JoeShmoe
09-20-2007, 07:11 AM
I heard that if you get a set of coilovers, you can adjust the camber without haveing to buy a camber kit. Is that true? Anyway, aren't the coilovers a bit better, those will probably be my next purchase.
SilvrEclipse
09-20-2007, 07:56 AM
No, you will need a camber kit to adjust your camber. Unless you put washers behind the bolts on the upper control arm.
vanilla gorilla
09-20-2007, 12:18 PM
Some full coilovers, (the expensive full strut kind, not the do-do slip over kind) have pillowball upper mounts and if I'm not mistaken the pillowball mounts allow you to adjust camber.
