View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. AC recharged,working. now over heats. Fan Clutch?
  2. 4.0 liter --> V8 Engine swap
  3. NO FIRE all of a sudden?? please help me..
  4. 2000 Jeep Grand Cherokee Transfer Case; Types And Fluids
  5. 1999 Cherokee AC/Blower Issues
  6. 2000 laredo speed sensor question.. help!!
  7. 97 Cherokee Issues
  8. 91 cherokee a/c question
  9. 1989 Cherokee cooling system
  10. 1989 cherokee overheat issues *help*
  11. Back Door Lock buzzing
  12. 2000 cherokee cranking but not starting till second crank
  13. Brake Booster problems, I think!!!!! PLEASE HELP ME
  14. steering coulmn
  15. Starting/Stalling Problem - Bad CPS???
  16. 89 cherokee ball joints
  17. 01 xj clicking felt on evaporative system
  18. balancer gone bad?
  19. For those who think you know Jeeps, Try to figure this out...
  20. Welding the rear differential?? Help
  21. 97 Cherokee Country 4x4
  22. 97 Cherokee Problems
  23. 97 Cherokee Problems
  24. Oil leaks only when engine running
  25. Driveline/Slip Yoke Eliminator Questions...
  26. Need opinion on Bendix rotors and pads
  27. I think I just killed my Jeep!
  28. crankshaft position sensor
  29. major coolant leak
  30. 92 Jeep Cherokee overheats at idle...
  31. 92 Jeep Ch still over heating at idle after work
  32. Jeep Camp 2006
  33. 99 fog light switch
  34. Confused about 4wd
  35. Rear captain seats/throttle body
  36. electric fan running
  37. '89 Repair/Shop Manual
  38. Distributor Wobble
  39. 1988 Jeep Cheerokee
  40. 98 jeep gas mileage
  41. new purchase
  42. Oxygen sensor disconnected
  43. Track Bar removal
  44. 1999 Cherokee Sport signal/flasher problem
  45. 91 Engine Stalling
  46. lift kit for sale
  47. Who makes this tire rack?
  48. Replaced head gasket Now low compression.
  49. Cherokee limited signal lights not working.
  50. Signal lights on cherokee limited not working
  51. 1994 Cherokee SE - Hi Idle Speed
  52. Grinding noise in park or neutral
  53. Older cherokee - Hard starting, high oil pressure
  54. Auto to Manual?
  55. Brake and Dash lights
  56. Wont Start
  57. '96 air-con control panel lights
  58. New Front Bumper
  59. Distributor Problem
  60. Compatible seat belts for 1995 Cherokee
  61. thanks guys
  62. Jeep trans issue - please help
  63. Engine Power Loss
  64. Woah
  65. 96 Jeep xj problems please read
  66. Are all Jeeps 4x4?
  67. Sonny Boy's 94 Cherokee Has Marginal A/C
  68. 200,000 miles +
  69. Moving on over
  70. Fog light madness
  71. 92 cherokee bucking while passing
  72. pontiac 350 in cherokee
  73. 93' Cherokee Radio Fuse
  74. Tie Rod End Question
  75. Unknown Warning Light Bus 5
  76. Help - unidentified warning signal on dash
  77. 2000 Sport multiple cylinder misfire
  78. 1987 Cherokee Sat for awhile now won't start cranks !!
  79. clicking in the stearing????
  80. '93 Cherokee I need ideas on what code 11 could be
  81. 97 cherokee running around 1500 rpms.What should I do?
  82. low oil pressure & chatter
  83. Back Up Lights / Keyless Entry
  84. Help! Sonny Boy has broken Leaf Spring and Oil Leak on '94
  85. 93 cherokee motor i6
  86. JEEP seat belts
  87. 1992 Cherokee "Clanging" from Below
  88. 95 cherokee motor
  89. Fluid Question
  90. 94 Grand Cherokee V8 fuel problem
  91. I-6 to V8?
  92. Oem Radio Question
  93. Tranny slams into gear and gas peddle sticks after hard turn. need help plz.
  94. Help forJeep 99 Cherokee Sport Acceleration
  95. Rusted Wheel Question
  96. 01 Cherokee Gauge Failure - Please Help!
  97. 86 Cherokee 4wd clutch slave problem
  98. leaking 4 auto
  99. Does Death Wobble only happen On Lifted Jeeps?
  100. Death wobble?
  101. Looking to buy a jeep
  102. Door locks on 1990 2dr
  103. Poo on my trans....
  104. electric cooling fan wont come on 4.0L
  105. Tranny Problems?
  106. Stalling !!!!
  107. Possible condensation in gas tank causes car to shut off?
  108. Next step
  109. Auxilary/electric fan problems 4.0L
  110. auxilary/electric fan problems 4.0
  111. Suspension...Death or doable?
  112. 99 Cherokee Sport - A/C question
  113. Loud POP when turning left
  114. Tire size advice
  115. Need More Power!!!
  116. what's the difference?
  117. 99 Cherokee Sport - Driver Side Seat Belt
  118. fog light rewiring...dangerous
  119. Suspension issue...I think
  120. 97 manual cherokee sport wont start
  121. High Idle Madness!
  122. Help With Tranny Pls ! ! !
  123. Anybody ever done this
  124. Power steering WTF issue....
  125. AX-15 Manual Tranny help needed
  126. Articles on how to replcae crankshaft sensor?
  127. Articles on how to replcae crankshaft sensor?
  128. Articles on how to replcae crankshaft sensor?
  129. It's a SMOKER!
  130. Lift kits
  131. screwed up my crankshaft
  132. Amp wire through firewall
  133. Grand cherokee seats in a Cherokee sport..Possible?
  134. 99 center console rattle while idling
  135. Towing my eclipse with my 01 jeep cherokee sport help!!!!
  136. Water in center console
  137. 15 yr old son Needs 94 Cherokee Drivers Door, etc
  138. Violent jerking and vibes
  139. 2000 Jeep Cherokee, no brake lights.
  140. Burnout in Cherokee
  141. Fuel Tank Replacement
  142. '85 Cherokee starter installation
  143. i have fuel pressure and spark still wont start
  144. 92 cherokee wont start
  145. 4.0 and 4.0 HO, whats the difference?
  146. frustrating fuel filter
  147. Jeep Wheels?
  148. busted transfer case ?????
  149. stumbles and hesitates
  150. knocking underneath
  151. 2000 shuts off at low speeds or idle
  152. 4wd won't engage
  153. Rebuild or Replace
  154. 96 xj acceleration chatter
  155. Oil leak in the strange place
  156. 87 Jeep Cherokee Inline 6, REALLY bad blow by
  157. 4wd intermitant
  158. need some help
  159. neutral column switch
  160. 2000 Cherokee Sport Brakes
  161. Show Me Your Bumpers!
  162. 96 xj Wont start HELP!!!
  163. 96 xj Wont start HELP!!!
  164. Remove Head on 4.0 HO
  165. 1996 Jeep Cherokee squeaks while turning
  166. A/C Comp just kicks on... Why? 01 XJ
  167. howdy
  168. 98 xj On-board air
  169. Need Cherokee buying advice
  170. Tick tick tick tick tick grrrrrr
  171. Really dumb question...
  172. 93 Cherokee Sport Wiring Harness
  173. 95 Cherokee, wipers, radio, A/C
  174. 87 Cherokee 2.5ltr constant stalling
  175. aw4 jeep cherokee tranny problems
  176. Repair theft damage?
  177. 93 4.0 HO swap to a 88 4.0 non high output questions
  178. Need help replacing alternator!!!
  179. 98 remote starter question
  180. Stupid Transfer Case question......
  181. Installing a Car Stereo.
  182. Cherokee Sport Question
  183. 1989 Jeep Cherokee Hard or no start in rain
  184. 98 xj console
  185. Not so grand Cherokee
  186. Whats the difference?
  187. Removing carbon deposits inside intake manifold
  188. 1987 Cherokee inline 6 starter
  189. Brake Light Problem
  190. 96 xj tie rod install
  191. NEED FLOOR PANS! for my 92 XJ
  192. Transmission problems?
  193. 2000 Jeep Cherokee Classic Stalling Problem
  194. Bought a 93 XJ
  195. 1988 Jeep Cherokee shakes violently
  196. Jeep Cherokee heating driving me mad!
  197. 89 jeep cherokee oil in aire filter I know what your thinking replace the hoses etc
  198. 87 Jeep key switch problems
  199. 96 cherokee overheating all ofa sudden!
  200. heater core
  201. is my a/c condenser squeeking?
  202. after driving 93 wont restart
  203. starter
  204. 4wd part time and full time?
  205. 96 Cherokee electrical gremlins
  206. Help. My interior lights won't shut off
  207. opinions please
  208. 97 XJ Intermittent Start
  209. Ignition lock problem
  210. Ignition lock problem
  211. Buying 2002 Jeep Cherokee
  212. Stumbling at Idle and accelleration
  213. lift kits
  214. Starter Spin
  215. 99 jeep trouble shooting question!
  216. dashboard swap
  217. Rear seatbelt retractor
  218. Cherokee 2.5 stumble at cruising & 1/8 throttle
  219. Dome light/ CD player problems
  220. Seeking 1991 carburetor for 2.5 litre gas Cherokee
  221. 87 Cherokee replaced column and lost tail lights
  222. Ignition Removal
  223. Leaking Tranny Cooler
  224. New Suspension Lift
  225. Yoke installation on Pinion Gear
  226. engine swap
  227. 2000 cherokee ride height
  228. Changed Blower Motor & Fuse - Still not working
  229. 200,000 miles on original engine
  230. No Pvc????
  231. gas gauge trouble and more
  232. transmission??? PLEASE HELP
  233. 90 laredo P windows + wipers & locks
  234. 1996 Cherokee SE 4.0 6Cyl Blower Mtr Blew
  235. Number 2 cylinder has sporatic misfire??
  236. Number 2 cylinder has sporatic misfire??
  237. Cherokee fuel mileage
  238. crank no start inter.
  239. cranking/ flooding problems
  240. tail lights, too
  241. Brrr it's cold
  242. Replacing 04 Cherokee Headlight Bulbs
  243. Humming/Buzzing Noise At Speeds 20-40 MPH
  244. Water on floor board
  245. front differential
  246. Possible Oil Pressure Prob?
  247. 90 Cherokee Laredo gas smell
  248. 1987 jeep cherokee 6cyl 4.0 4x4
  249. 1987 Jeep Cherokee - Running lights / Instrument lights
  250. 96 Cherokee transfer case exploded
