View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22
  1. Desert Heat
  2. 92 jeep cherokee
  3. Please Help!!
  4. Rear differential
  5. running over ricers
  6. dynamic dampener
  7. Problem with A/C, blinkers, radio and windshield wipers
  8. 89 cher ltd right signal arrow getting stuck
  9. Leakage
  10. Purge solenoid ticking
  11. Speedometer Intermittent / Dead
  12. Emiss maint Light
  13. new starter, won't start
  14. Gap bridging on spark plugs
  15. Crank shaft replacment
  16. "low wiper fluid light always ON!"
  17. Brakes just wont work tried everything
  18. Parking Lights
  19. Need Adive on Cherokee add-ons
  20. Engine Mods?
  21. 2000 jeep cherokee sport blower fan switch
  22. Help--Heating issue
  23. 1988 cherokee 4.0
  24. Heater core replacement
  25. Whining noise above 35
  26. wont start
  27. Battery gauge dropping
  28. driving lights question
  29. trouble code retreival
  30. Looking for advice on 1995 Sport
  31. 88 jeep cherokee std trans shifter prob.
  32. whats the best performance mod.-4.0
  33. Hesitation & Stalling
  34. looking for leaks
  35. 95 Cherokee high NOX
  36. code reader for xj 90 and before
  37. 89xj rear left door will not open from driver control armrest
  38. rear disc brakes
  39. Should I Sue In Small Claims?
  40. jeep cherokee damaged computer
  41. 96 jeep cherokee = fried computer - HELP
  42. Cold Air Intake Question!!!!!
  43. having problems when turning tothe right shuts off
  44. 89xjlimited no status light on dash--HELP!
  45. where to look for oil leaks
  46. No More OVERHEATING!!!! YEAH! Biggie UP for BC BLues
  47. question about fog lights on jeep
  48. 160000-too many miles on a cherokee?
  49. Help, no power!!
  50. More weird electrical problems
  51. 89 xj limited horn does not work
  52. Weird electical/starter problems in '90 Cherokee
  53. Parking Brake Button 98 Cherokee
  54. Clank Clank Clank
  55. Fuel gauge goes crazy
  56. 89 fuel pump or pressure regulator?
  57. rear main seal
  58. Bump...Stop (running that is)
  59. 94 Cherokee EGR
  60. Eng Ctrl fuse blowout.
  61. 88 cherokee transmission issue
  62. jeep cherokee sport
  63. jeep 2000 electrical questions
  64. 99 jeep cherokee rumbles
  65. 93 cherokee not starting
  66. 2000 Cherokee liftgate problem
  67. MAINT REQD Light
  68. fuses
  69. passenger manual window wont roll up
  70. rpms fluctuating
  71. broken firewall
  72. Brake Lights on 1989 Jeep Cherokee wiring
  73. No spark
  74. need lift for my 90' limited
  75. liberty wheels fit cherokee?
  76. 700 & 705 Codes
  77. Ignition Switch
  78. 2000 Cherokee Sport
  79. somethings not right Part II....
  80. turn off Check engine light
  81. Leaf Springs
  82. flowmaster exhaust on a cherokee?
  83. Eng Ctrl fuse blowout.
  84. Jeep Cherokee headlights
  85. Jeep Wont Start
  86. What is this hose out of my firewall
  87. debris in clutch fluid
  88. Having gauge problems? heres the answer
  89. UP COUNTRY Suspension?
  90. stearing collum was pealed
  91. will any other leaf springs work on 89 xj lift?
  92. clutch problem
  93. help
  94. overheating ?
  95. 1999 jeep just quit
  96. Jeep thumping
  97. Cherokee Cold Air Intake ?
  98. Door stuck closed & locked.
  99. 95 jeep troubles
  100. Starter turns but engine doesn't crank
  101. 1999 Jeep Grand Cherokee - Need advice on replacing a blown dash speaker.
  102. V-8 swap
  103. somethings not right...
  104. 1989 Cherokee Backfires
  105. Shifter I.d.
  106. intermittent short circuit
  107. 89 4.0 that wont stay running
  108. Jeep Cherokee DASH
  109. Differential Fluid Additive?
  110. 1996 Jeep transmission problems
  111. Front hub/axle removal
  112. Clunking and tranny whine
  113. alternator or what
  114. Clutch Problems
  115. Spark plugs?
  116. leafsprings
  117. Jeep Cherokee Sport Door Speakers
  118. fuel injectors
  119. Jeep Cherokee Bench Seat
  120. remove and install radio 1992 jeep cherokee
  121. No Heat, HELP!!!!
  122. Hard Starting
  123. 85 cherokee slave cylinder
  124. Jeep won't start
  125. O2 Sensor Heater Trouble
  126. Groaning Noise
  127. overheating question
  128. 89 cherokee transmission problem
  129. 89 cherokee fuel injecting no 12 v power
  130. Cherokee Side Moldings Anyone?
  131. Chrankshaft Position sensor removal
  132. 89 cherokee hatch area leaking
  133. 89 limited leaking sunroof
  134. '92 Cherokee headlamp switch malfunctioning
  135. 1993 Jeep Cherokee Speedometer and Gas gauge out!
  136. 89 blowing black smoke, idling rough, etc
  137. 1998 Cherokee problems
  138. Stubborn Rear Main Seal
  139. Intake manifold swap
  140. I'm thinking timing belt . . .
  141. 89 comanche starts but won't run
  142. Rear "rumble" type noise when stopped in DRIVE |
  143. air intake system on 98 sport
  144. 94 jeep Cherokee SE Lo Beam Problems
  145. car won't idle
  146. blinkers not working
  147. keyless entry conversion??
  148. If you were to lift your XJ 3" what would you buy?
  149. buying 1990 cherokee
  150. 94 sport won't start
  151. ignition lock
  152. buying a cherokee
  153. Smells like gas?
  154. 2000 Cherokee Sport
  155. radio problems
  156. Fuel Pump????
  157. Bull Bar
  158. trouble starting
  159. 92 Cherokee E-Brake light stayong on
  160. 1987 Cherokee Laredo
  161. Headlight stay on!
  162. Spark plug prob
  163. 92 Jeep Starting Issue
  164. Loud clunking in 4WD
  165. 99 cherokee rad. fan short cycling
  166. 86 Jeep Cherokee, 2.8L, "PHOTO" needed to identify Vacuum components
  167. Throttle cable stuck on 90 Cherokee
  168. 86 Jeep Cherokee, 2.8L, Vacuum Hose PHOTO needed
  169. 89' Jeep Cherokee aircare/stalling problem
  170. hose from valve cover to air cleaner.
  171. newbie with radio problem on 88 cherokee
  172. frame brackets??
  173. Kill switch on 98 Cherokee
  174. 1998 Jeep
  175. Jeep doesnt run PLEASE HELP
  176. Engine knocking
  177. Push Button Start
  178. 1994 jeep cherokee SE serpentine belt
  179. 92 Cherokee Starting Issues
  180. starter button
  181. replacing rear seal on transmission
  182. Fuel Pump Problem?
  183. electrical problem
  184. 98 jeep cherokee transmission sensors
  185. Jeep runs in start position and dies in run position.
  186. 1995 Sport Cherokee Won't Start - Not Coil
  187. Friends 90 Jeep Cherokee
  188. 89 stalls/dies after warming up
  189. Death Wobble?
  190. How do I calculate speed with Bigger tires?
  191. Suspension question
  192. brake lights
  193. Heater hack 89 xj
  194. 89 Cherokee help
  195. Axle upgrade
  196. 87 w/ whine...what did I do?
  197. Windshield wiper problems
  198. Meet & Greet in Pinellas County
  199. Fuel Injectors
  200. Transmission doesnt shift right
  201. 5-Speed makes noise under load, maybe bearings?
  202. Loud knock in 4Low
  203. Axles?
  204. over heating
  205. Cherokee new stereo
  206. 88 Jeep Experts Help...Lock/Unlock Relays
  207. lifters questions
  208. 95 Cherokee starting problems
  209. Tires
  210. Can't remove transmission hose from radiator
  211. relay
  212. Loud shacky noise when running
  213. Confused...temp sender in rad + another in lower rad hose?
  214. runs and then doesn't
  215. need help!!!!!! jeep screwed!!!
  216. auto into manual
  217. Wiring Question - CD Player & Dome Lights
  218. 93 Cherokee fuse box layout query
  219. Won't go into gear
  220. 98 cherokee trans range sensor malfunction
  221. Best Intake
  222. suspension spacers
  223. jeeps not starting well & won't run for more than 3 seconds
  224. Idle Air Controller giving me fits
  225. RHD Vs. LHD
  226. 90 Cherokee stalls when in neutral rolling to a stop after freeway speeds.
  227. Aftermarket temp guage/burping recommendations?
  228. HELP Jeep wont stay running
  229. 1989 cherokee hard starting
  230. Looking for a few jeep cherokee parts!
  231. Turn Signal Issue
  232. when Ball joints go bad
  233. jeeps are not bear resistant
  234. key stuck in ignition
  235. V6 exchange for I6???? will it work
  236. HELP! Diesel in my cherokee!!
  237. electrical problems on a 1998 cherokee
  238. 1999 Jeep Cherokee No Bus/guages drop out
  239. 1991 cherokee limited?
  240. mild shifting problem
  241. 86 Cherokee w/ 2.8L Where do I connect to diagnostics?
  242. Really funky electrical problems
  243. header question..
  244. 87 pioneer hissing from reservoir cap???
  245. 1988 Jeep Cheroke
  246. 1989 XJ newbie cooling issue : What to do 1st?
  247. ABS brakes
  248. 89 cherokee lost all lights/radio/AC
  249. Slippery!? Or is it just me!?
  250. broken window regulator.
