View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. 1988 Cherokee Pioneer Project
  2. Lots to do tommorow!
  3. transmission oil in differential
  4. Automatic Transmission Fluid
  5. 95 Cherokee rod torque and clearance
  6. 96 Cherokee Sport Noise
  7. wiring speakers rear hatch
  8. 1994 Cherokee Rough Acceleration
  9. parts breakdown
  10. Gas tank leak?
  11. how to put the fan belt on
  12. 1999 Jeep Power Steering Pump
  13. Help - Flood Damage
  14. Re: 88 cherokee transmission issue
  15. Thud when stopping or accelerating
  16. Fuel Pump
  17. Jeep randomly won't start
  18. Procomp 3" Lift kit ?
  19. Good Write Up On 4x4 Gearing Types
  20. Climbing Hills 2000 xj command trac trans.
  21. 88 Cherokee Pioneer...CAN YOU GUESS WHAT THIS STUFF IS FOR...???
  22. 1996 Cherokee 4.0 liter Dies after running very rough for 20 seconds
  23. 1999 4.0 with code P0455
  24. Estimated cost of repairs?
  25. Axle U-Joints 2000 Jep Cherokee Sport
  26. Lurker turned poster looking for a referral
  27. 96 xl popping noise
  28. Project 89 XJ
  29. Turn signal switch
  30. New Trans @ 177K
  31. 96 cherokee Noise
  32. Jerky Wipers 2000 Jeep Cherokee Sport
  33. 2000 sport electrical problems
  34. '87 transmission
  35. Twisted end off lower shock mount - GRRR!
  36. Transmission problem...???
  37. Renix Tb Spacer Or Not?
  38. New Fan Motor is possible Solution to no low or medium air blowing.
  39. conversion
  40. Engine cooling fan will not run
  41. Odd Electrical Problems
  42. 1999 cherokee cold starting problem
  43. Sonny Boy's '94 6 Cyl Oil Filter Adapter Leak fixed
  44. engine oil smells like gas
  45. cant find belt to fit 92 cherokee
  46. 2006 jeep grand cherokee 4x4 IS THE 4x4 always on
  47. major problem
  48. 97 XJ Power Lock Trouble
  49. 1999 Rear Main Deal
  50. 96 XJ hub replacement
  51. Jeep Jamboree in Snowshoe, WV
  52. Vibration only under heavy acceleration?
  53. Intermittent Ignition Trouble
  54. 99 Cherokee Problems..please give me some ideas
  55. Jeep Gone Bad
  56. 2001 front end noise?
  57. Trail rig!
  58. intermitten knocking
  59. 97 Jeep Cherokee Directional Auto Shut Off
  60. rear diff question
  61. key stuck in "on position." can't get key in off postion
  62. Jeep Hood Vent Question
  63. 1999 Jeep GCL P1494 Issue
  64. Sqeaky Breaks...Need Help
  65. Starting problems - '95 Cherokee
  66. Coolent system Leak
  67. Clunking on start when cold
  68. 1989 Jeep - Question that needs answered!!!
  69. 1987 Jeep Cherokee not starting, intermittent
  70. Jeep Cherokee electrical problem
  71. 1987 Cherokee= 4 cyl. vs. 6 cyl.???
  72. 94 Jeep Cherokee
  73. door panel removal?
  74. OH CONS fuse blows randomly
  75. best and worst years
  76. Cannot engage 4 wheel drive
  77. Rear lights out!
  78. check Guages light
  79. NP231 vs. NP242
  80. Transmission Rear Seal Leak
  81. towing capabilities
  82. Rear leafs finished, brakes dead, help please!
  83. Code 12 Won't start
  84. 2001 Jeep Cherokee Wiring Diagrams?
  85. Hissing sound
  86. mirror problems
  87. 1997 Cherokee-Doesn't like to work at Post Office
  88. Another no bus gage panel code HELP!!!
  89. Please confirm this is a CPS issue
  90. rebuilding transfer case...
  91. Buck at 65MPH, battery output of 17 AMPS
  92. Buck at 65MPH, battery output of 17 AMPS
  93. Towing Jeep
  94. A/C Compressor Readings?
  95. I NEED HELP ANYONE PLEASE....1989 sputtering rattling hesitates is a manual
  96. 98 cherokee,key stuck in ignition...
  97. Operating temp
  98. 1988 no power to AC compressor
  99. 99 cherokee sport hesitation under acceleration
  100. Leather seats available anyone?
  101. 2001 Jeep Grand Cherokee OBD code P1494
  102. Dramatic Power Steering Failure
  103. u-joint
  104. No lights -in the dark
  105. 94 Seat Help
  106. NO BUS message on dash gauge, dead gauge PLEASE HELP!
  107. 95 won't start
  108. toggle switch for what?
  109. Help Fuel Tank Leak O-ring problems
  110. Would a CPS problem cause these issues?
  111. Right side front axle shaft removal
  112. Rpm Idle Read 2000 Jeep Cherokee Sport
  113. problems with radiator removal
  114. Additives for 4 liter/6 mtr.
  115. 2000 cherokee sport starter problems
  116. Another heating question
  117. Trouble with '89 Cherokee Trouble Codes...
  118. 89' XJ Brake question
  119. 1999 Sport - Rear Brake problem
  120. AdvanceAutoParts or AutoZone?
  121. Heat exchanger help 94 cherokee country
  122. 93 Jeep Cherokee Temp.
  123. Lots of problems help!
  124. simple tune up turns into $1000 PCM??!!?
  125. 96 Jeep Cherokee ...... how to increase MPG
  126. Is a $1,000 for my Power Steering Sound right?
  127. 1988 Cherokee Pioneer Catalytic Converter?
  128. fender removal XJ
  129. Headlight Bulbs Help
  130. Sparkplug question
  131. 99 Cherokee Black Smoke
  132. radio removal
  133. carpet removal 96 xj
  134. 1990 Cherokee Front Differential Replace/Rebuild
  135. Need More Power
  136. 97 fender flares ona 96
  137. Newbie Here Command-Trac Question
  138. just installed 4.5 inch lift and now wheels toe in towards top
  139. 3rd Times a charm (start problems)
  140. Throttle body spacer
  141. 1996 Jeep Cherokee sport 4.0 liter steering
  142. Death Wobble Problems
  143. Worth keeping?
  144. door lock wiring driving me insane
  145. cracked block diagnosis
  146. Beginner Question Command-trac
  147. Fuel Pump?
  148. 2001 jeep cherokee sport blower motor
  149. really high idle
  150. 93 jeep cherokee i6 hard start in mornings
  151. Beginner,s OFF/ROAD website
  152. Paint hood nicks
  153. 01 Cherokee Sport, Dash flashing Code
  154. No drilling....No welding.....
  155. blower motor
  156. Quick Question about Steering parts/trouble
  157. Grill question.....
  158. Wheel Vibration at Varying speeds
  159. power steering box leak, how do i remove??
  160. '98 throwing code P0306 after being submerged in water, rough idle and hesitiation
  161. brakes locked up ?
  162. Need some advice? Reality Check!!
  163. 1999 Cherokee Sport Steering Trouble
  164. What kind of tranny fluid to use?
  165. 1992 cher ltd i6 4.0 - HUGE MPG Swing
  166. budget boost
  167. Engine cooling problem, questions and theories abound
  168. Ball Joints
  169. Alternator Woes
  170. Tranny problem?
  171. ac problem
  172. 2000 Cherokee power problem
  173. running too cold?
  174. 2000 Cherokee Crank Sensor?????
  175. 1995 Cherokee Sport I-6 PCM Problems?
  176. 1993 Jeep Cherokee engine stall-surge
  177. 1993 Jeep Cherokee engine stall-surge
  178. lack of power
  179. low idle speed
  180. part time 4wd=locked diffs?
  181. 95 cherokee
  182. 98 Cherokee Sport-Problem with Gauges
  183. 1988 Cherokee Pioneer lift kits?
  184. 1988 Cherokee Pioneer
  185. No Power Sometimes
  186. Driveline noise when decelerating down hill
  187. 96 has no spark at coil
  188. 2000 jeep won't start HELP!
  189. timing cherokee
  190. detroit track-lock
  191. what does it weigh?
  192. Overdrive Band
  193. Grand Cherokee History
  194. Towing capacity of 1992 cherokee larado?
  195. Another fog light question
  196. 96 SE coolant leak!!!HELP!!!
  197. Recharging A/C
  198. Power Window Controls Driver Side 2000 model
  199. fog lights
  200. need help, with jeep wiring
  201. 4wd clunks under pressure...
  202. tire noise
  203. Rear leaf spring question
  204. 97 Cherokee ignition key won't turn
  205. ABS on a 1992 cherokee Larado?
  206. starting problem
  207. Liftgate lock malfunction
  208. power loss during acceleration
  209. What might be causing this?
  210. engine cleaning
  211. 96 cherokee tranny fluid
  212. 1990 Xj seat problem......
  213. 96 sport fuel filter and cs install
  214. 96 jeep cherookee sport question
  215. 1987 Cherokee Pioneer front axle
  216. Questions about differentials, gearing ect
  217. Fuel Pump...or CPS??
  218. '95 Cherokee Sport A/c
  219. Gas In Oil????
  220. 1992 4.0 6cyl. - Won't start & no power
  221. 1984 cherokee 2.5L
  222. 98 Cherokee overheat after many fixes
  223. Serpentine Belt Broke
  224. 1992 cherokee problems
  225. 90 JC, Shifting problem! PLEASE HELP!
  226. Seems like an unrelated problem
  227. Gas milage in the city
  228. 95 Cherokee Stalling
  229. Suspension problems...
  230. overheating
  231. 1500 RPM & no more
  232. 97 Cherokee Country I6 4WD
  233. 95 Cherokee Country
  234. 89 inline six water pump pulley?
  235. dead jeep
  236. 2000 Jeep Cherokee Sport overheating
  237. 1997 Cherokee, fuel filter location?
  238. h.o. head on non h.o. engine?
  239. 96 power door locks
  240. engine swap
  241. Instrument display
  242. Door Locking Problems
  243. Cherokee HELL-P!!
  244. My jeep only has defrost
  245. 96 Jeep Cherokee Help
  246. Serious Brake Promblems
  247. engine problems
  248. Got a stumper for ya'll
  249. 89 jeep with messed up vaccum lines. 4.0 cherokee 4x4
  250. Good Or Bad?
