View Full Version : Cherokee
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. wierd idle
  2. 4.0L engine component name needed
  3. door lock
  4. Back window seal
  5. Knocking noise
  6. clicking noise while driving
  7. Total exhaust replacement
  8. 1989 Transmission? Problem
  9. HELP!!! My XJ is dying!!
  10. '95 4.0 knocking noise
  11. cleaning power steering fluid from front end
  12. Check Engine Light in 95 Jeep Cherokee Sport
  13. Econo carb 360 ci '78 Cherokee
  14. knocking/clicking noise under acceleration
  15. fuel injectors?
  16. 96 Cherokee wont start - weird cause
  17. 97 no hot air
  18. 88 Jeep Cherokee Bad MPG
  19. 84 cherokee rough idle, rough while driving
  20. 2001 Cherokee - Full Size Spare?
  21. 1993 Jeep Windshield Wiper Not Working
  22. key broken in driver door
  23. Shameless pics of my newly lifted XJ.
  24. Some people don't deserve a jeep
  25. A/C troubleshooting question
  26. 89 cherokee laredo wont start
  27. Parking Lights
  28. new parts still no start
  29. Biggest tires on Factory Jeep?
  30. Thank god for jeep owners!
  31. Need seatbelts for 95 Cherokee
  32. 2001 Cherokee Engine Surge
  33. Lift Kit Questions
  34. Thanks!
  35. shiftin problems
  36. transmission slip question
  37. suspension help--how to get the smoothest ride?
  38. rear heat output low
  39. Muffler / Exhaust
  40. 1993 4.0 Oil Leak at Oil Filter
  41. Loss Of Power
  42. new parts no start
  43. 95 Jeep - How Do I Use 4 Wheel Drive?
  44. Starting Problems 1991 Cherokee
  45. electrical sadness
  46. knocking noise
  47. power steering leak
  48. 1992 Jeep Cherokee sometimes has no power to starter
  49. 94 cherokee front diff swap
  50. Best lift kit
  51. '091 no start 4.0
  52. Suspension lift
  53. fuse diagram of 97 jeep cherokee
  54. 2001 Cherokee "cricket"
  55. engine for 2001 cherokee sport
  56. No Gap Spark plugs, are they worth it?
  57. Is there supposed to be a light behind the heater controls?
  58. Front End
  59. Cherokee Sport/WEIRD overheating problem
  60. Body Lift
  61. 96 xj 4.0 200k when do you R/R engine
  62. 91 Cherokee fuel pump buzzing.
  63. clutch help
  64. 99 Jeep Cherokee Sport won't start
  65. Shiftlinkage for 4X4?
  66. 4 wheel drive
  67. 92 xj coil replacements
  68. Electrical Problem in 87 Jeep Cherokee?
  69. 89 Jeep Cherokee 4.0 4wd oil pump
  70. 2004 7/70 Powertrain warranty question
  71. '96 Jeep Cherokee sport won't start
  72. 1993 Jeep Cherokee
  73. Cherokee starts but then dies...
  74. Jeep cuts off
  75. looking at a 2000 Cherokee
  76. 91 Jeep Cherokee wont stay running
  77. 4x4 light on?
  78. Trans fluid change stumped question??
  79. No heat in seats
  80. pinpointing front axel trouble
  81. Does anybody know...
  82. 4wd wont work hubs not lockin need help
  83. help please
  84. Broken bit nightmare
  85. wont' start nor turn over, ahhhh
  86. Replacing rocker panels 1996 Cherokee sport
  87. Misc Jeep Transfer Cases FYI
  88. 85 Cherokee not starting
  89. Heater blower resistor location
  90. A few problems on a 96 Cherokee Ltd
  91. shock
  92. full time 4low
  93. reverse lights
  94. 94 cherokee back up light switch
  95. Airbag light on, no gages- 98' Cherokee
  96. No Overdrive, delayed shift 98' Cherokee 4.0L
  97. Starting Problem: B+ Latch relay not the culprit.
  98. Uncommanded 4-3 downshift
  99. Transfer case won't go into 4 wheel low
  100. What is a "B+ latch relay"?
  101. Need a part
  102. Question about transmission fluid change
  103. 94 cherokee tranny
  104. 1996 jeep cherokee sport headlights "?"
  105. 1987 Cherokee Pioneer MPI injector issues
  106. Won't shift into overdrive
  107. Broken/Bent pushrods
  108. 350 News
  109. 1995 jeep cherokee part time 4wd light
  110. Starting problems, different this time
  111. 96 xj 4.0 How many 02Sensors?
  112. 1996 Jeep Cherokee door handle (rear)
  113. Heater Problem
  114. 1990 Jeep Cherokee Larado-Heater problem
  115. Bypassing Ignition/Neutral switches
  116. Gas Leak Dash Lights
  117. 1996 Jeep CHerokee oil pan
  118. 95 Cherokee Sport Running Like Crap
  119. On XJ Overheating
  120. 88 Cherokee will not stay started
  121. Coil Mount Broken
  122. 89 jeep charokee
  123. Hang Transmission Shifting Cherokee Sport
  124. 88 Cherokee stalling fixed
  125. 87 cherokee problem
  126. 96 Cherokee 4.0 Liter- High Idel/low Idel- And Electrical "growl"
  127. Water Kills
  128. Mystery noise
  129. map senso issues
  130. 1987 Jeep Cherokee Pioneer lock cylinder
  131. 4.0 noise
  132. back passenger window install...... :(
  133. front axel question.
  134. XJ Electrical Problems
  135. Ignition Key Problem
  136. twisted diff on axle housing
  137. Killing Batteries
  138. Didn't.....
  139. 95 jeep cherokee country
  140. Trans shifting to Fast, No down shft
  141. Front Driveshaft
  142. horn resistor
  143. 1990 Cherokee Power Steering Pump
  144. Anti Wrap
  145. where is fuel pump relay?
  146. 1990 Cherokee overheating need help
  147. Need help for my 1996 Jeep Cherokee...
  148. No can idle cold
  149. Strange clunking in front end
  150. wiring color code 89 limited
  151. High Oil Pressure
  152. 1999 Jeep Cherokee Check Engine Light
  153. slow shifting
  154. 1998 Cherokee Clunk In Front End
  155. 1999 Jeep Cherokee fuel rail
  156. Cherokee Limited Overhead Console problem
  157. Knocking when turning, please help
  158. 1999 Jeep Cherokee
  159. '93 Cherokee Stalling...PLEASE HELP!
  160. 1990 jeep
  161. Jeeps Unlimited
  162. Fuse Box Passenger Compartment & Power Dist Box
  163. ABS Fuse Location 1996 Jeep Cherokee Country
  164. Crankshaft pulley / harmonic balancer
  165. front shock mount
  166. Location of Headlight Relay 1994 Cherokee?
  167. Toubleshooting a 3.5" Rubicon Express Lift
  168. vacume diagram 88 jeep pioneer please
  169. 1999 Jeep Cherokee Classic - Ignition?
  170. 99 cherokee classic problems.
  171. 98 cherokee sport suv
  172. 98 cherokee sport
  173. cherokee won't start when it's humid/rainy
  174. Steel Seal Head Gasket Fix
  175. 98 Jeep Head Gasket Fix
  176. 96 jeep cherokee(not for sale)
  177. Backfiring?!?
  178. Part name needed
  179. Overheat? In this weather??
  180. Fuel pressure tests
  181. 88 Cherokee EGR Valve Removal
  182. MyJeepSpace.com
  183. 96 jeep cherokee towing package lights not working
  184. 96 cherokee problems
  185. Just to help Forum users get answers
  186. New to Forum...Need help/info on '86 jeep Cherokee Chief V6 2.5liter
  187. HELP! Airbag light came on, all gauges went off!
  188. Think I need a new engine wiring harness....
  189. Need help with Temp Gauge sensor
  190. XJ Parts
  191. '92 4 wheel drive
  192. How to bypass neutral safety switch
  193. Leaf spring replacement?
  194. 93 Cherokee Fan Clutch help needed
  195. 1990 Fuel Injectors Please Help
  196. Got Links?
  197. Crappy Thread Content
  198. Engine noise, possible idler pully serp belt?
  199. Engine outline light on dash
  200. Jeep stalling problem
  201. 1992 Cherokee not accelerating rough idle getting worse
  202. 1995 Cherokee Sport loses power above 3000 rpm
  203. Need a hand with trac bar info
  204. Need help with my Jeep!!!
  205. 1996 Jeep cherokee rocker panel
  206. 96 Cherookee SE 2 dr 5 speed manual
  207. ADS fuse 2000 Cherokee
  208. Speed Sensor - 2nd time + Fuel Filter
  209. Repairing More Flood Damage
  210. 97 radiator fan keeps running...
  211. Starting problems
  212. Remote Starter Info
  213. Proper torque for 96 XJ
  214. cruise control fuse/mirrors
  215. Downshifting at highway speeds
  216. Running Lights not working
  217. 9 mpg! *kicks Jeep again*
  218. installing a factory chrysler nav. system
  219. help installing ignition lock cylinder please in a 1996 jeep cherokee
  220. Serpantine Belt Tensioner????
  221. smells like burnt rubber
  222. What is the gear ratio?
  223. Harness wiring diagram
  224. stalling jerking
  225. Rear Axle
  226. 1996 Jeep cherokee steering problem Still
  227. Air locks and guess work - help needed
  228. Planin For Moab
  229. Rear main.... *kicks jeep*
  230. Help soon - Washington State Requires Information
  231. diagnosis help: loud fan-like noise behind glove compartment
  232. Miss at cruise !!!
  233. 95 XJ What is this?
  234. Whinning/rattleing in 97 country 4wd 4.0
  235. Clutch help!
  236. 1991 cherokee runs rough sometimes dies backfires,hestitates ect.
  237. 2001 cherokee sport
  238. Wobble, shaking
  239. speaker wiring in rear hatch
  240. Jeep Cherokee knocking during idle
  241. Thermostat gauge fluctuating
  242. 96 XJ Flushing the Motor??
  243. noise?
  244. Brakes!!
  245. 97 Cherokee country 4.0 4wd
  246. Liftgate will not open
  247. coil, distributer, cps???
  248. 99 Grand Cheeroke Radio Fuse
  249. 95 Cherokee random knock
  250. 87 Cherokee dies when turning a corner
