View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22
  1. '89 Cherokee - Spongy pushrods/runs poorly
  2. A/C Clutch Wiring
  3. 1993 radiator replacement
  4. 98 cherokee starting hard
  5. Overheating
  6. 92 wipers
  7. new to the threads
  8. 1987 cherokee air filter soaked w/ motor oil
  9. stuck in 4 wd
  10. 732K Miles ....... !!!! Need HELP !!!!
  11. Common Reason Why 87 - 92 Cherokee Won't Start
  12. Trans clunk
  13. Radiator replacement 97 Cherokee
  14. Throttle Body Spacers
  15. AC water in floorboard in of Jeep
  16. Simota Air Filter Setup... should I buy this?!
  17. 89 power window
  18. smoke out the back
  19. 91 Cherokee Fog Light Malfunction
  20. Blower motor runs on high speed only
  21. Transmission Fluid Flash???
  22. How many miles...
  23. Front U-jionts
  24. Cruise Control broken?
  25. 84 cherokee 2.5L, engine swap?
  26. 91 Jeep won't start
  27. Air Conditioning
  28. A/c
  29. Blown fuse?!?!?!
  30. Another water leak!!
  31. 1990 Cherokee will not turn over
  32. Fuel pump, or what?!!??!
  33. Unknown popping (clunk)
  34. 89 cherokee not starting
  35. new to forum
  36. 96 Cherokee stalled and will not start agian
  37. 89 cherokee- idle hight until i play with gas
  38. 96 jeep cherokee cranks not starting not the coil!!!
  39. Speedometer not working
  40. 94 XJ VERY slow cranking
  41. Water leaks into rear left panel
  42. 87 Jeep Cherokee w/ Horrid Jerking over 1500 RPM !?!
  43. interior lights linked to break light switch problem, any one had this happen
  44. knocking sound at idle
  45. Fuel sending unit
  46. No power to fuel pump
  47. A/C Problems !!!!!!
  48. 88 Cherokee Pioneer Help
  49. wiper problems
  50. hard steering
  51. Roller Rockers
  52. Idle stepper motor
  53. 89 cherokee - e-brake light on constantly
  54. 85 Jeep, drains battery overnight.
  55. 99 cherokee sport fuel gauge and pwr windows
  56. Cherokee Factory Accessories
  57. Service manual
  58. left front grinding noise
  59. tranny noise
  60. No power to AC clutch
  61. Solenoid, starter or ignition
  62. 92 running hot
  63. wont start
  64. How to Gain more HP??
  65. 96 Cherokee - Cranks, doesn't run...
  66. My door was falling off!
  67. Transfer case rebuild
  68. f150 coils?
  69. 95 Jeep Cherokee
  70. She does not blow...
  71. cps question?
  72. Major Engine Problems
  73. 87cherokee electrical problem
  74. Yet Another Starting Issue
  75. Do they make one?
  76. Doesn't accelerate well
  77. Turn Signal Wiring Problem
  78. needle valve in throttle body help?
  79. Upgrade injectors?
  80. 88 cherokee lack of power
  81. 1989 Cherokee shifts funny.
  82. trailer hitch
  83. HELP!4WDproblems(I think)
  84. K & N KIT
  85. Shaking
  86. I6 4.0 Serp belt squeek. Tried 2 brands.
  87. Front axle shaft seals
  88. recommended lift kits
  89. 89 cherokee hesitation
  90. loose steering
  91. Water leaking from floor heat vent 1999 Cherokee
  92. 1987 jeep cherokee oveheats
  93. 96 cherokee won't start PLEASE HELP!
  94. got a problem with my heep
  95. Move to NAXJA.
  96. Evaporative Control System
  97. pinion crush washer change giving me trouble
  98. 98 is starting sluggishly
  99. Any tips on refilling "closed" coolant system?
  100. Takes a while to start
  101. screaming rear end
  102. 89 Cherokee Shaking/Vibrating Please Help
  103. slow battery problem
  104. 1998 Cherokee electrical
  105. TPS or CPS?
  106. Jeep Cherokee Limited 1999
  107. jeep flooding
  108. check gauges light
  109. idle problems with 1997 Cherokee
  110. clunking in rear cherokee
  111. water pump
  112. dash bezel removal in 87 laredo
  113. How about this one?
  114. Fuel Pump ? - Cherokee
  115. high idel
  116. exhaust manifold
  117. Air conditioning conversion kits
  118. 4.0 Litre that knocks. I need your suggestions!!!
  119. PAINTING ISSUES .. maaco?
  120. 1994 Cherokee Sport
  121. swapping gas tank
  122. Getting off Factory Exhaust
  123. Change timing gears ?
  124. Intake for 1990 Cherokee
  125. Q on leaf spring bolts during lift kit install
  126. Rough Idle with A/C
  127. 1987 Jeep Cherokee Won't Turn to Start
  128. 1987 Jeep Cherokee Win't Turn or Start
  129. 2001 Cherokee P/s Noises
  130. Power Steering pump
  131. XJ Door compatability
  132. Performance Exhaust Installation
  133. Electrical Problem with 4.0L 89 Jeep Cherokee 2WD
  134. 1988 Cherokee FRONT WIPERS
  135. 1988 Cherokee REAR WIPER DOESN'T WORK
  136. What's wrong with this !@#$% thing?
  137. 1989 Cherokee Laredo; fuel problem
  138. frontend noise
  139. installing automatic locks ??
  140. Problem Fixed
  141. Need Help On A Idle Problem!
  142. EAZ-E-LIFT Trailer Hitch FOR SALE !!!!!!
  143. 96 Cherokee - CV Joint????
  144. 99 Cherokee AC Cycling Problem
  145. Idle 'miss' - 88 Cherokee
  146. high idlel
  147. 1990 Jeep Cherokee takes forever to start
  148. EAZ-E-LIFT V5 Trailer Hitch FOR SALE !!!!
  149. Steering/track bar problem?
  150. 1988 Cherokee BUZZER WON'T SHUT OFF
  151. Electrical Problem on AC compressor
  152. Front End Problems
  153. Thermostat with or without Jiggle Valve!?
  154. f/s 01 jeep cherokee limited
  155. Fuse Diagram for 00' cherokee
  156. Steering
  157. Help Headlights
  158. What is that thing above rear view mirror?
  159. 97 doors on a 96
  160. What Degree of shims do I need?
  161. speedometer not working
  162. Which Spark Plug to Buy!?
  163. Cracked exhaust manifold - 1986 2.5L
  164. Sputtering,Stalling,Slow accel. 1986 2.5L
  165. Air Conditioning Cherokee
  166. Steering Issues
  167. Left Turn Signal Rapid Blink
  168. Drum To disc conversion
  169. Transmission / Modulator Valve Problem in '89 Pioneer
  170. Crankshaft Position Sensor?
  171. Jeep Cherokee Code.
  172. 1994 cherokee key lock cylinder
  173. 4WD No Longer Engages
  174. Cooling Fan Relay
  175. clunking noise
  176. fuel
  177. Dana Identification
  178. 1991 Jeep Cherokee 4.0L 4WD Thermostat problem?!?
  179. 1992 Cherokee Ltd, 105k , wont stay started, alarm prob?
  180. Starts, Stall Quickly.......
  181. clicking noise in tranny
  182. VERY STRANGE electrical probs, 98 sport
  183. Info on Jeep Cherokee...
  184. 2000 Cherokee Trailer Brake Wiring
  185. I am in need of a little bit of help !!!!!!
  186. Low Clutch
  187. 4.0 Engine Rebuild for 89
  188. What is it worth?
  189. 98 Jeep Cherokee Leaking Oil
  190. Urgent help needed with injector problem
  191. inertia switch 90' laredo
  192. engine parts vendors???
  193. check engine codes
  194. 92 cherokee cruise control
  195. 92 cherokee speedometer failure
  196. '90 jeep cherokee lerado won't start
  197. Another TPS question (1995 Cherokee)
  198. 88 Laredo Dies When Hot
  199. Transmission cooler hose leaking '97 Sport
  200. Cruise control never used now its coming on and using and abusing me!
  201. 1988 jeep cherokee cutting out
  202. good buy?
  203. Heater Problem - Resistor for Blower motor overheating
  204. FS: 2002 Jeep Grand Cherokee 17" alloys
  205. Crankshaft position sensor ? 94 Cherokee
  206. I still cant figure out the problem?
  207. 93GC Problems ANYONE?
  208. Cherokee tranny problems
  209. Lincon locker
  210. Late model Jeep rims on older Cherokee?
  211. 1996 cherokee sport radio removal
  212. Electrical problems (99 Cherokee)
  213. 5.0 ford conversions in cherokees anyone?
  214. ABS sensor
  215. Fuel Injector Leaks
  216. Bad ABS sensor?????
  217. Got some wiring done on overhead console but need help!!!!
  218. bearing(?) noise & rebuild question
  219. Upgrading wires and grounds on 1990 Cherokee.
  220. jeep wont break 2500-3000 rpms
  221. Acceleration?
  222. Jeep Shakes at highway speeds
  223. Replacing crankshaft positioning censor
  224. 1988 XJ heating/AC vents not working
  225. 96 Cherokee water pump
  226. Power Steering Leak
  227. Cluster Question and Directions for Oil Pump Installation... HELP
  228. Battery keeps draining
  229. Component Location
  230. My Jeep Want Start 1990 Cherokee
  231. ((...95 JEEP Cherokee Radiator/Gasket/Engine problem...))
  232. Need Help Fast !!!
  233. Wiring up overhead console
  234. anyone know how to hotwire a 1990 jeep cherokee
  235. Keyless entry/ key fob for
  236. 1990 jeep cherokee ignition is locked
  237. Help! I need points ignition for my 2.5
  238. Big Bucks on '89 Cherokee?
  239. 5.0 ford conversions
  240. left side running lights
  241. bucking problem with 96' cherokee
  242. wiring diagrams for Cherokee
  243. 91 --> 96 4.0L HO Swap
  244. 2000 XJ - MIL, heated seat, cruise control
  245. Successful driver seat repair?
  246. how do I test the a/c clutch relay?
  247. 1988 Jeep Cherokee Coolant leaks
  248. Alarm/Door Lock Problem - 91 Cherokee
  249. rear hatch
  250. 99 Cherokee Tranny Noise
