View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22
  1. carb wont come off
  2. to much gas in the carb
  3. Jeep GC Liftgate Wont open
  4. Brake Light Problem
  5. Carb?
  6. 1988 Cherokee Wagoneer LTD Gremlins
  7. 1989 cherokee abs conversion
  8. Both Directional Indicators come on w/Parking Light Switch
  9. 92 Jeep redo Comfortride Shifting problem
  10. shifting problelms
  11. 4.0 problem when Accelerating
  12. help Help HELP
  13. what comes with my jeep
  14. throttle....
  15. [MOVIE] |0lllllll0|
  16. Power steering
  17. One simple question
  18. no start 93 jeep grand cherokee
  19. Heater blowing cold. HELP!!!
  20. No cruise control
  21. 92 cherokee clutch problem, need help please
  22. Is their a docter in the house?
  23. Need help on this one
  24. 87 4X4 Kicks out of reverse!
  25. whinning sound while running and cracking
  26. 2000 Cherokee 6 cyl
  27. Cherokee name differences?
  28. electrical
  29. Reverse
  30. 02 Cherokee not blowing hot air
  31. rear window glass and gasket for sale
  32. Differential humming
  33. I just bought a 94 Cherokee, please help
  34. lockers for 94 Cherokee
  35. Back gate vibrating, how do I adjust?
  36. Blow-By problems
  37. Rough Idle
  38. 99 Cherokee Power Windows.....
  39. Remote Locks/Keyless Entry
  40. Lights
  41. 2000 Cherokee Valves
  42. 6" to 8"
  43. not shifting to first. overdrive problems fixed
  44. Rocker Panel Rust
  45. 89 cherokee, everything runs without key
  46. bypass the nss
  47. newer seats older XJ
  48. 90 Cherokee 4.0 rough when warmed up
  49. 1985 Jeep Cherokee; 2.8L V6; NP228 T=Case.
  50. new tires for 1994 Jeep Cherokee 4.0l 5sp
  51. Oil Leak from oil filter adapter
  52. Got Milk?
  53. good bones, no mucle(overheating)
  54. Radiator-What´s the catch?
  55. 90 jeep cherokee limited4x4 with auto trans
  56. Stearing column
  57. Rear main seal
  58. better performance
  59. Vaccum diagrams for the transfer case on a 88 XJ?
  60. 94 XJ cold start screeching noise
  61. 90' slow start, any advise would be great
  62. I'm thinking about a lift...but how high?
  63. 1990 Jeep Cherokee - Turns over, but won't start - Please help
  64. better performance
  65. `89 cherokee code scanner
  66. 95 Cherokee 2.5L missing at speed w/ O2 indication from OBD
  67. 88 rear axle swap
  68. 01 cherokee 4.0 tranny slippage?
  69. 93 cherokee running rough
  70. Cherokee Rims
  71. 98 cheorkee automatic tran. fluid
  72. Piss Poor gas mileage
  73. Transmission Indicator Light not working
  74. 94 cherokee: need help deciding what i should do about transfer case
  75. 2000 Cherokee scraping from rear wheels
  76. crackling noise from steering colum on 95
  77. Adding rear shoulder belts to older XJs
  78. 87 4.0 Would Like It To Start Faster!
  79. Gibson exhaust on '96 Cherokee
  80. 1990 slow start
  81. 91 cherokee abs
  82. Blower only works on high ??
  83. replacement airbags for 1998 Cherokee
  84. 88 Overheating/head gasket
  85. Brakes act funny on rainy days?
  86. Head work?
  87. 96 jeep keyless remote
  88. Spark Plug Gaping
  89. Weak or no spark on 89' with 4.0
  90. 92 4.0 Very Rough Idle
  91. Aftermarket temp
  92. How to add back seat headrests? (1996)
  93. 1996 Jeep Cherokee Sport
  94. sound on engine
  95. bad fuel consumption the danm thing drains the fuel tank too fast
  96. Noise from Oil Pan
  97. 2001 jeep cherokee
  98. Blower is not working???
  99. braking problems
  100. 88 Cherokee heater fan does not blow.
  101. Loud squeal when ac is turned on
  102. 97 Door panel Removal
  103. 90 Cherokee won't idle...
  104. 97 Cherokee radio light replacement
  105. 1985 Hard Start Cherokee HELP!!
  106. bumper
  107. towing
  108. 89 4.0L Missing/Backfire when above 900 rpm
  109. stalling
  110. illustration for speedometer
  111. HELP!!!***1989 4.0 Jeep Cherokee idles fine, runs rough with any gas***
  112. Heater/AC blows thru defroster vents, not floor
  113. Heater core replacement
  114. 02 sensor
  115. 91 cherokee oh god please help
  116. push bar/ grille guard!!
  117. push bar/ grille guard!!
  118. 97 Jeep speaker wiring
  119. Crank - No Start
  120. Overheating 90 cherokee
  121. hazard/ brake lights not working
  122. Passenger side window only work from drivers side.
  123. Airbag light always on. 98 cherokee sport
  124. Thinking of buying 97 Cherokee Sport 4x4
  125. 1998 Jeep Cherokee overhead console
  126. 96 Cherokee Transmision dipstick tube removal
  127. Heater control
  128. shifter ?
  129. Clutch bleed
  130. Doem Light Short - t-shoot guidelines
  131. Weird noise associated with bumps
  132. 2000 JGC HVAC blower resister
  133. 99 cherokee steering / turning trouble
  134. 88 cherokee starts with HIGH RPM's????????
  135. TGISSEL...question on seat-belts.
  136. LED XJ tail lights
  137. Fuse Diagram!!!
  138. These Cherokee threads are awesome!
  139. Transmission Leak
  140. getting rear bumper off
  141. Problems getting it started
  142. rear door
  143. Replace or rebuild?
  144. HELP! Rear End Clunk after shifting & removing foot from clutch
  145. clutch adjustment
  146. thanks
  147. transmission flush?
  148. WTB: Fuel Injectors for '89 4.0L
  149. Rear Leaf Spring Replacement
  150. blinkers
  151. Leakage problem
  152. Would you buy it?
  153. 96 Cherokee Country 4.0 Automatic Ignition problem
  154. regular maintenance
  155. manual shifting noise
  156. Tranny filter replacement question
  157. 93 jeep starter problem? ...yes another thread
  158. 96 cherokee classic 2wd
  159. To buy or not to buy?value of 91 cherokee sport
  160. '88 Cherokee radio problem
  161. transmissoin fluid replacement
  162. 89 auto trans problem
  163. Closed or open??
  164. What fits?!
  165. Has anyone installed air bag helper springs?
  166. problem with my 4X4 transfer case
  167. 93 Cherokee tries to stall, but never stalls out completey.
  168. 99 cherokee helppp!! (I have dynamite ready)
  169. performance
  170. Speedometer doesn't work
  171. Crazy Starting 91 Cherokee Need Help
  172. Broken power window cable
  173. 88 cherokke 4.0 hard to start
  174. Stuck in Part Time 4WD
  175. So about that crushed spot in the exhaust?
  176. Tow hooks
  177. what is the biggest tire i could fit on a 87 cherokee
  178. 2000 Cherokee tire size
  179. I need advice on TIRE sizes.
  180. stalling and more, need help for fellow jeeper.
  181. Can you get brake pad spacers...?
  182. '87 Cherokee running problem
  183. Jeep Cherokee Window Fuse
  184. 1996 Cherokee se whinning sound during acceleration
  185. 1994 Jeep Cherokee Sport Overheating issue
  186. starter or electrical problem??
  187. 1990 4.0, transmission "hunts"
  188. More MPG for a Jeep?
  189. NSS overhaul for '88 Cherokee
  190. Theres alot of play in my steering.
  191. Idle vibration
  192. dana 30 Front diff
  193. Clean Catalytic Converter?
  194. "Honk" lock confirmation not sounding?
  195. '93 dead - CPS? Help I am stuck at school on Friday
  196. No inst. pnl. lites (Still)
  197. trouble code
  198. HELP! Cracking sound in front axle!
  199. wants to stall
  200. vibration (not death wobble)
  201. Grinding noise during hard accelaration - 87 4.0L 4x4
  202. hood latch cherokee
  203. Distributor
  204. 99 Cherokee Dash Removal Question
  205. Horn Keeps Beeping in 94 Cherokee
  206. suddenly it stalls while driving
  207. Brakes?!
  208. 90 cherokee limited 4x4 won't start
  209. clutch or throwout bearing?
  210. Adding rear sholder belts to a pre-91 Cherokee
  211. Tranny Noise ???
  212. 87 4.0L Whining / Poor Gas Mileage / Cruse Control
  213. '97 steering stabilizer replacement
  214. 93 cherokee parts for sale
  215. Cooling Fan Relay: Location
  216. 1992 Cherokee blower motor
  217. Stuck!
  218. XJ Running HOT? Change your Stat!
  219. NSS on a '88?
  220. '88 Jeep radio schematic
  221. 95 cherokee 2 wheel conversion to 4x4
  222. Fuel pump sounding noisy on 90 cherokee
  223. 90 xj abs pump...
  224. help
  225. 1997 Cherokee Electrical Problem
  226. 87 4x4 manual transmission how can i tell what model
  227. 91 4.0 Too many cranks to start?????
  228. cherokee 2000 engine light on
  229. Splitted tail pipes
  230. Unibody vs Frame
  231. key won't turn
  232. disabling air bags 96 cherokee
  233. Jeep staying idled up
  234. egr testing 88 4.0 cherokee
  235. My XJ hates me... Stalling problems.
  236. 1992 Jeep Cherokee LMTD Cruise Control
  237. Preventitive MAintenance?
  238. Best place to buy new front hub assembly for my 99 cherokee??
  239. Jeep shaking badly need advice!
  240. Battery good, but NOTHING at start
  241. Electrical Gauge in red
  242. 1990 Jeep 4.0 Run Problem
  243. 90 cherokee cold and damp running problem
  244. Service Manual?
  245. obdII failure
  246. 94 Temp Gauge
  247. Clutch Master Cylinder
  248. Help, 1994 Cherokee clickins sound and
  249. no dash lights
  250. 87 XJ Tranny / T-case noise??
