View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22
  1. Car Show In Ct
  2. stalling and starting issues with 89 Cherokee
  3. clunk/bump in suspension?
  4. Vacuum line location
  5. I saw something horrible today
  6. Location of Backup Switch
  7. trans slipping
  8. 1989 Jeep Cherokee Laredo - Door Locks
  9. Power steering leak
  10. Cherokee 2 Door... Rare?
  11. Auxiliary fan vibration '01 XJ
  12. 1997 Jeep Grand Cherokee Engine Stalling
  13. dual fuel....
  14. different lift kits...
  15. 1995 Jeep Cherokee sport
  16. vacuum canister?
  17. Radiator problem?
  18. Fuel Pump fuse
  19. 6.5" or 8" Rock Krawler Severe Duty Lift
  20. No more oil leak?
  21. 1999 Cherokee overheating?
  22. air bags available for 92 Cherokee Sport?
  23. '92 with Death Wobble
  24. Engine fell
  25. How to get better gas mileage?
  26. Put a 2" lift now i have a problem
  27. Squeaky Clutch
  28. 90 Cherokee wiper blades
  29. 00 Cherokee vs 05 Grand Cherokee
  30. 88 Cherokee Clutch Slave
  31. which lift kit
  32. Brake lines after lift kit
  33. 98 Classic Cherokee w/ Transmission Issues
  34. Stalling Solved - May Can Help You
  35. Cherokee 88 4.0,radiator Replacement
  36. window electric regulator
  37. FS: nice seats!
  38. 1996 Jeep Ch/Sport 6 Cyl, Replace Computer?
  39. 2000 cherokee center console removal
  40. Clunking
  41. Degreased 4.0, now tranny not engaging past 2nd
  42. Put a diaper on it
  43. death woble
  44. Sunday is lift kit day... Hints & Tips???
  45. 92 Power Steering
  46. no charge getting to battery
  47. '94 Cherokee TCM problem?
  48. high beam dont go on
  49. having jeep problem and need help
  50. Scramblers
  51. A day at the dealership or Cherokee vs Wrangler
  52. 93 Cherokee Sport tranny fluid line - HELP please
  53. Quick question about fuse box
  54. dyno max cat back ordering
  55. 2001 Cherokee Sport MIL Light On
  56. Tires in the desert
  57. Classified Forum?
  58. 94 cherokee stalls
  59. carb/intake question...
  60. temperature gauge fluctuating
  61. Airbag light and dash gauges
  62. need info 89 Cherokee Ltd.
  63. 94 Cherokee Headlight
  64. 94 Cherokee Headlight
  65. 2006 Jeep Cherokee
  66. thanx for the info
  67. spark plug help
  68. Problem with 4 low 98 cherokee
  69. oil pressure
  70. Cherokee dies
  71. Plastic Surgery
  72. Foglights
  73. 86 Jeep Cherokee wont crank
  74. '98 Classic 4.0 Stalls when turning
  75. Fuel sending Unit?
  76. piston slap?? please explain
  77. idle, stalling problems 2000 cherokee
  78. Over heating
  79. Cycling A/C compressor
  80. Leaking Oil
  81. What Brand of Spark Plugs?
  82. auction possibility
  83. Continued Problems! 1990 Cherokee LTD 4.0L
  84. 86 Jeep v6 (2.8)
  85. Slave Cylinder/Clutch Return Cylinder Problem
  86. Tranny problem
  87. jeep flag
  88. 1990 jeep laredo wont even click !
  89. Help! 1997 Cherokee 4.0L
  90. BFG MT's or Goodyear MT/R's
  91. When do you upgrade the Altenator???
  92. 87-90 A/C Relay Location
  93. 89 cherokee problems
  94. Power door locks and windows
  95. Dome lights stay on - drains battery
  96. engine
  97. 88 cherokee starting/stalling problem
  98. broken bolts/ Lug nuts
  99. leaky slave unit
  100. 97 cherokee, ALTERNATOR????
  101. Desert runner
  102. Lifting My Jeep
  103. Patience dear, patience. Cherokee still hates me...
  104. 86 Cherokee engine Vibration
  105. FOR SALE: 90 XJ in new jersey
  106. Morning Drive
  107. daylight module cherokee 91
  108. lift gate lock
  109. High rev when starting
  110. no headlights
  111. SALE; 1990 Factory TSM 2 book-set.
  112. Distributor Cap And Rotor Kit
  113. 89 cherokee hesitation problems
  114. what transmission do I have?
  115. neutral safety switch - help!
  116. Trottle Body adjustment - 1989
  117. 1991 Cherokee Lardeo Questions
  118. Roof Racks
  119. Steering shock question
  120. Brake problems
  121. Rear Brake Rebuild..
  122. 2000 Cherokee Stalls
  123. 1992 Cherokee bounces all over the road
  124. Tire Bump When Turning
  125. 88 Cherokee HVAC Lights
  126. Wet air filter
  127. What is this sensor?
  128. Fuel Injectors...
  129. general maitenance
  130. Instrument lights blink with turn signal/electrical problems
  131. 99 cherokee starting problem, stalling, no idle !!!!
  132. brake lights don't work
  133. 89 Cherokee starting problem
  134. Strange Coolant Loss - 2000 Cherokee
  135. Stock 89' Radio Wiring
  136. Converting a 4 Cyl. to a 6 Cyl??
  137. Rear Suspension??
  138. Water pump replacement
  139. Oil Pressure
  140. dash lights come on dim when brake is applied
  141. Dull headlights
  142. Removing engine fan-adding electric
  143. 1993 Cherokee-"NEW" ENGINE WON'T START
  144. newbie with tranny question
  145. 4.0L not running right, sensors/computer??
  146. interior lights wont go out
  147. 91 Cherokee still won't start, please help!
  148. '91 Cherokee for sale
  149. throttle body
  150. Oil pump replacement?
  151. all time 4x
  152. forced air
  153. A/C to Air Compressor conversion
  154. Ford Fuel Injectors
  155. Need to cool off a little
  156. More horses for my 4.0
  157. fuse box
  158. crazy flex?
  159. Looking for a 4.0L 242cu engine for my 88 Jeep
  160. 1900 Jeep Cherokee Laredo Cooling Issue
  161. Power window trouble
  162. 2001 Cherokee Sport 2WD 4door misc?
  163. 1999 Cherokee Classic stalls while on highway!
  164. Puzzled on Bolt
  165. Idel Motor Sensoer problem
  166. 1994 4.0 Cherokee Will Not Start!
  167. Tough starts--cold and hot
  168. 1996 Cherokee Sport For Sale !!!
  169. tow hitches
  170. 2000 cherokee engine into a 1987 body...
  171. Replacing CV Halfshaft
  172. Positive Valve Cover Pressure-->How Much?
  173. Ok let the laughing start
  174. 1994 Jeep Cherokee transmission fluid coming out of dipstick
  175. Oil Filter Mount
  176. Gear Ratio help
  177. abs braking system
  178. '91 Cherokee Trans
  179. Mystery Leak
  180. Squeak-squeak
  181. cruise control
  182. 88' some questions
  183. #26 injectors
  184. 4x4 vacuum modulator????
  185. Changing to 4X4 Full time??
  186. Another idle issue thread 1991 Sport 4.0
  187. 90 Jeep Laredo Factory Radio Removal
  188. Color fading on plastic over wheel well.
  189. Desperatly need 02 accord digital clock
  190. Blow-By Problem
  191. Rear door lifts question
  192. 93 Cherokee Low spark
  193. "limp mode" on 93 intrepid
  194. "limp mode"
  195. 91 Cherokee fuel pump relay clicks on then off
  196. 94 Grand Cherokee misfires above 2000 RPM
  197. oil pan gasket
  198. Newbie repair questions from a new Jeep owner
  199. Replacing a 89 Cherokee Radiator
  200. vibration , noise? 2000 cherokee
  201. Fuel Injector
  202. Front Seats Upholstery
  203. wont start
  204. 4wd/2wd shifter fork (front axle)
  205. Momentary rough idle???.
  206. i smell like gas
  207. Rear Bearings
  208. 94 Cherokee A/C whining
  209. vibration cant figure out why
  210. 99 XJ 4.0L Electric Fan won't shut off
  211. start/stall/no start
  212. leaking coolant all over the ground....
  213. GC Seats in a Cherokee?
  214. 1987 jeep Cherokee dashboard symbols
  215. Best Oil Filter
  216. Headlight relay
  217. 2Fast2Furious?
  218. check engine codes
  219. PurgingAir From Water (Coolant) Jacket Post Water Pump Change
  220. If your hood release cable breaks
  221. Oil leaks from main seal again?
  222. Look out below!
  223. 89 Cherokee low rpm hesitation
  224. waterpump 2001 cherokee
  225. Overhead Console
  226. cherokee tranny problem
  227. lifting my 92 cherokee
  228. Chrysler or AMC ?
  229. Non blinking turn signal-94 Cherokee Sport
  230. Shocks
  231. rear main seal
  232. 94 Grand Cherokee wont start
  233. 2000 Cherokee Sport equipment question
  234. 99 cherokee won't idle..........
  235. knocking sound after spark wire mixup
  236. sudden kills
  237. Bad headlight switch??
  238. Fuses blowing, wierd electrical
  239. No Start, no Insterment panel gages work?
  240. Hot To TROT
  241. Vacuum Lines
  242. automatic transmission fluid change
  243. light switch on a 94 jeep cherokee country?
  244. Neep Help ASAP Please
  245. Post-traffic engine quiver
  246. radio and dome light
  247. missed the guys here!!!
  248. a picture for all you jeep guys
  249. 97 Country Problem!
  250. factory wiring harness in 98 Cherokee?
