View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22
  1. jack
  2. Acetone and gas
  3. 89 Cold start problem
  4. 1993 Cherokee 9" rear brake problem
  5. NSS... Is it necessary?
  6. 99 cherokee squeaking
  7. 89 cherokee 4.0 hard starting...
  8. 4.0 mpg
  9. compressor clutch came apart
  10. GEN light on dash and smoke
  11. Shimmy that wont go away!!!
  12. '88 4.0L power loss...
  13. 92 cherokee front door window mod
  14. Oil Consumption sadness... :(
  15. Can i change the Donut for a full spare?
  16. automatic windows - not so automatic!
  17. 98 XJ Up Country aux trans cooler line routing
  18. 1996 cherokee sport
  19. Engine dies
  20. Jerky steering wheel issue.
  21. no spark
  22. oil oil everywhere-89 cherokee 4 ltr
  23. shift on the fly
  24. 97 cherokee sport - stalls turning left
  25. fan shroud
  26. Power windows
  27. Removing 4.0 Litre With Tranny
  28. 93 windshield wipers dont work
  29. redish-pink fluid leak
  30. replys to old treads
  31. abs change over to reg brakes
  32. Urethane Bushings
  33. dim charge light when heater on
  34. Thermostat Problems
  35. Trans fluid change
  36. FS: 1988 Jeep Cherokee
  37. 4.0 to 4.0 HO?
  38. changin belts
  39. Add Power Windows & Locks for 96 Sport
  40. Mushy brake pedal on 89 Cherokee
  41. Dashboard Lights
  42. Dashboard Lights
  43. Jeep won't turn off
  44. Where is the coolant leaking from?
  45. Ignition switch Problems
  46. engine light
  47. 87 XJ questions
  48. Backscape Decals...
  49. 4.0L Reg or HO?
  50. Screwed up trans issue....
  51. torque converter solenoid
  52. Correct Nuts & Bolts?
  53. Dimming headlights
  54. 1995 Jeep XJ Cherokee
  55. 90 JC, Horn wont work
  56. transfer case
  57. Jerking at high speeds....
  58. Troubleshoot w/o MIL Light...
  59. rear wiper
  60. feels weird
  61. sounds weird
  62. where can i get little pieces that are driving me crazy
  63. rear wiper
  64. cherokee
  65. crazy guages
  66. 01 Cherokee electrical madness!!
  67. What to Put
  68. 93 cherokee fuses
  69. AC Upgrade...
  70. My '88 XJ...
  71. Neutral Safety Switch Help
  72. Transfer Case...
  73. 98 Cherokee Dash Removal problems, Need Help!!
  74. Need help finding the right amplifier
  75. clutch plate or master & slave?
  76. Radiator replacement 95 w/tow pkg
  77. stereo amplifiers
  78. Engine Control Fuse Keeps Blowing
  79. what diffs?
  80. freewheel transmission?
  81. Side marker light and turn signal
  82. 89 4L auto wont start
  83. Slow To Start
  84. 1988 cherokee wont start
  85. 180 Deg Thermostat...
  86. MIL Light...
  87. temp light test 1996 cherokee 4.0L
  88. Hooking up a system
  89. 92 cherokee sport not cranking
  90. No Radio
  91. 1985 Jeep Cherokee
  92. starter soelinoid on an 87 jeep cherokee laredo
  93. 86 Cherokee
  94. It Runs !!!
  95. 97 Cherokee having no hot air
  96. Acceleration Problem
  97. Rear Pass Window Depth...
  98. running rough
  99. Camshaft Position Sensor
  100. brake and backup lights out
  101. Key Fob Programming
  102. synthetic or not
  103. Hatch Prob...
  104. Disconnecting Battery...
  105. 90 Cherokee..thumping when breaks are on
  106. New Ground...
  107. Thumping Noise From Left Rear?
  108. condensator
  109. 1995 cherokee transmission dipstick
  110. Cps Sensor Down
  111. charging system
  112. More XJ Q's...
  113. *scratches head
  114. Crank Position Sensor
  115. XJ Q's...
  116. 1997 jeep cherokee air bag module?
  117. Radiator Hose Q...
  118. Chrome Bumpers 4-Sale...
  119. Locate fuse seat heater
  120. Trac-loc?
  121. 88 Jeep Juice to positive wire(Red)/Need your help plz
  122. 1996 Cherokee Classic - No start
  123. 4.0 Fuel injected engine needed
  124. PLease Help, BIZZARE no start !!!!
  125. What Size Connector?
  126. 1990 Jeep Cherokee Laredo
  127. 99' Cherokee Limited
  128. Radiator and More 4-Sale...
  129. Alternator Bracket...
  130. My power locks are draining the battery.
  131. Stock 15inch Rims for sale with tires only $100
  132. Stuck Key and Control Arm Bolts...
  133. Stock 15" Rims 4sale
  134. XJ Engine Needed
  135. My jeep Was stolen :(
  136. 1993 Power Window Fuse - Which one is it?
  137. one headlight brighter than other
  138. 1991 cherokee won't start
  139. Front end "POPS" when i turn left????
  140. Egr Valve...
  141. Troubleshoot Seat Heater Cherokee Limited
  142. Fuel Injectors...
  143. 89 Jeep Cherokee-Frost plugs popped out and probably a bad starter?
  144. 2000 Cherokee Sport ??
  145. 4.0 air intake system
  146. 89 cherokee H-lights,radio,horn intermittent
  147. Heating Issues
  148. Size does matter
  149. Best made
  150. Emissions...
  151. Rear differential rubber drain plug
  152. 1991 with 4.0 putting 1989 4.0
  153. Other heating problems
  154. Thermostat...
  155. Power Window and Door Lock Probs...
  156. 87 jeep cherokee starting problems after swap
  157. How to...
  158. Fan Switch...
  159. Thermostat Good?
  160. What’s better off-road, a Cherokee or a Blazer
  161. 88 4.0 Upgrade
  162. looking for a 6cld for my 78 jeep mail truck
  163. 1984 jeep cherkee 4x4 stick truck
  164. 1987 cherokee 6cyl serpentine belt installatioon
  165. Power Door Locks SLOW
  166. '93 Jeep Cherokee 4wd problems
  167. 99 jeep
  168. 88 XJ Cherokee Laredo Q's...
  169. 95 Cherokee gate supports
  170. Temp Sending Unit Replacement HELP!!!
  171. 95 Cherokee brake pads
  172. Front end noise
  173. 1999 jeep cherokee vibration and humming
  174. 2001 Cherokee serpentine belt
  175. 94 cherokee won't start, help.
  176. 88 jeep cold start problem
  177. Engine keeps flooding
  178. Engine Swap for xj?
  179. Weird starting problems.
  180. 98 cherokee radical missfire while driving
  181. 88 Comanche 4.0
  182. auto tranny nightmare
  183. Where are the plugs
  184. 88 Cherokee 4.0, Fuel Injected, Stalling
  185. 1993 Cherokee 4.0 quits (not cps)
  186. Blowin' Fuses For Signals
  187. No Luck...Thanks any way.
  188. bad steering in my cherokee
  189. Windsheild washer pump
  190. Dana rear question
  191. Block heater on my cherokee???
  192. Heating Problem!?
  193. Column replaced and Windshield wipers don't work
  194. Rear Wiper Help! 99
  195. Electrical Short - Dome Circuit - 91 Laredo
  196. starting trouble
  197. Small Lift Suggestions
  198. heater blower
  199. No heat 96 Jeep Cherokee 4.0
  200. 89 Comanche Stalls hot won't restart
  201. blower motor on high speed only
  202. Overheating-90 Cherokee
  203. lots o miles
  204. can't get in
  205. 97 jeep cherokee won't idle on its own
  206. Hydraulic Clutch Slave Cylinder-88 Cherokee
  207. 1991 jeep cherokee Limited keeps stalling
  208. Technical service manual?
  209. 2003 requiring new valves and cam shaft
  210. 1991 Cherokee Laredo Dashboard problem
  211. Start problem
  212. oil leak
  213. No tail lights, dash lights
  214. Intake manifold
  215. 95 cherokee leaking heater valve
  216. 95 Cherokee, Lack Of Power
  217. overcooling???
  218. XJ killed!
  219. track bar install
  220. Engine died when sitting at idiol, No spark
  221. Headlight Problems!!
  222. Tire size
  223. Problem Starting, No Fire...
  224. evo sensor for steering control
  225. Tramission blows fluid from dip stick
  226. have to fight my jeep like crazy to keep straight???
  227. Manual window regulator
  228. Won't start in cold!
  229. No horn
  230. have to fight my jeep like crazy to keep straight???
  231. Won't start in cold
  232. ??Bump Steer?? -Searched
  233. Stock HP for 98 Cherokee Classic
  234. Heating *wierd*
  235. Control Arm Bushings
  236. Distributor 1992/1996 both 4.0
  237. 1990 Cherokee rebuilt transmission problems
  238. Temperrature problem?
  239. subwoofer help
  240. posi or detroit locker?
  241. Temp sending unit broke
  242. Is there a certain oil i need to buy or will any do?
  243. I have an electrical problem.(i think)
  244. 95 starter issues
  245. Power Steering Pulley Installation
  246. Omg!!
  247. neutral start/back-up light switch
  248. 1996 Jeep Cherokee 4wd Indicator light not working
  249. Need JEEP/EAGLE ADAPTER For DRBII
  250. Somebody Help Me!
