View Full Version : Cherokee
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
  1. Clutch Stuck
  2. Temp Shows False Overheat??
  3. 99 cherokee sport air conditioning
  4. ABS Issues NO BRAKES! sometimes
  5. just got a cherokee
  6. need help deciding on parts
  7. gas gauge
  8. 01 fuel starvation problem
  9. 99 jeep cherokee sport...fuses
  10. 2000 cherokee sport fuel filter
  11. Wont start! Engine turns over then done.
  12. 96 XJ Replacement Rear End
  13. overheating at night
  14. shimmy at 55 mph
  15. Older '87 question
  16. Tire Advice
  17. rear wiper comes on when I brake
  18. Help!!! Overheating problem.
  19. 2000 Cherokee Classic - No Start Problem
  20. More detailed vin info for cherokee?
  21. CEl no work, now no start!! related?
  22. HELP! no CEL on dash, won't start!!
  23. 97 cherokee problem after mudding
  24. dash lights
  25. I love Electronics... Fuse keeps blowing.
  26. Transmission will not shift into 4th after adjusting the brake light switch
  27. My first Car!
  28. Need to adjust how much brake force goes to the front and back.
  29. 1998 Cherokee No Sound From Radio
  30. 89 Cherokee Power Steering Box
  31. cherokee or wagoneer
  32. Cruise Control Brake Switch?
  33. What may have happened?
  34. Slotted/ drilled brake rotors
  35. 1998 Jeep Cherokee vibration at 2200 RPM
  36. jeep cuts out at cruise
  37. cherokee overheating
  38. 1999 cherokee Ball Joints !!
  39. Instrument lights
  40. spark wire compatibility ??
  41. YJ brake line in rear? ##'s
  42. Cherokee 98 Exhaust Problem
  43. Wierd engine/exhaust problem !!
  44. Lower control arms: recommendations?
  45. 90 xj coolant tank mod help
  46. 1990 XJ Temp Sender at a slight angle
  47. Ambient Lighting
  48. Speedometer Not correct-- how can I fix??
  49. 96 Cherokee Sputters
  50. Selling 2001 jeep cherokee sport
  51. Just bought a Haynes
  52. "remodulating" the tach??
  53. Wider Tires on XJ
  54. drivers side door switches
  55. PLEASE HELP '96 jeep cherokee won't start
  56. exhaust threat?
  57. Headlight Problem 95 Cherokee
  58. 89 cherokee, hood left open in rain and wont start
  59. Jeep Instrument Cluster Replacement Odometer Fix?
  60. removing front axle to replace u-joints
  61. 95 Cherokee stalling
  62. Intake Modifications ?
  63. check engine light on and transmission seems weird
  64. New to XJ's - Problems
  65. Squeaking while moving
  66. Rear Differential question
  67. radiator removal
  68. tachometer false reading-500 hi- how to fix??
  69. chirp up front= miss or lope???
  70. 2.5" exhaust pip or not
  71. 85 cherokee chief we are selling or gonna scrap
  72. Stalling out
  73. tow points on 2000 Jeep Cherokee
  74. Can someone help with vin check?
  75. Exhaust manifold hardware
  76. Information needed: will be installing a 5.5" lift on my 96' cherokee
  77. creeeak,Bushings front and rear..rrrrrrrr
  78. 96 Jeep Cherokee 4 cyl Standard Trans
  79. 1999 jeep wont start...loud, rapid clicking noise
  80. 2000 Cheroke Evaporator
  81. 1995 Jeep Cherokee speedometer not working
  82. Windshield Washer Hard to Fill - 99 Cherokee Sport
  83. no transfer case fluid change ever
  84. 95 Cherokee Help
  85. Nu Finish polish/wax. Any good?
  86. 88 Jeep Cherokee Pioneer won't start
  87. 94 country ac leak
  88. 10 W 30 or 10 W 40?
  89. jeep cherokee .... safari doors?
  90. 99 Cherokee Wont Start
  91. Installing Hitch Reciever?
  92. 1999 Jeep Cherokee Alternator issue
  93. Exhaust noise question
  94. '96 Sport sometimes stalls at low RPMs
  95. Transmission question
  96. window repair ??
  97. 2000 Cherokee O2 sensor problem
  98. 1990 XJ Instrument Cluster Upgrade Help
  99. 1990 XJ Steering Click
  100. Need new shocks
  101. 93 Cherokee will not stop running
  102. All right guys... Help! lol
  103. 1996 Cherokee Air Conditioning
  104. wiring harness
  105. 97 Cherokee Issues
  106. 99 cherokee needs suggestions
  107. power door locks
  108. cherokee lifts
  109. Cherokee passenger door question 01 Cherokee
  110. 01 Cherokee question
  111. 97 xj lift
  112. charging problem 1987 cherokee
  113. throwout bearing noise?
  114. 89 cherokee 4.0 4X4 wont move
  115. Cherokee Thrashing Video
  116. Transmission shift problem
  117. 98 XJ Gas Tank gasket?
  118. 01 cherokee tinted glass
  119. slave cylinder or master cylinder
  120. 1992 Cherokee, Engine knock
  121. 1995 Jeep Cherokee reverse light problem
  122. 2001 Sport price
  123. This wagoneer doesn't exist
  124. Steering Wheel will not lock when key is removed
  125. Blinker flasher location?
  126. Headlights
  127. LCA's Squeeak when disco'd
  128. 1992 Cherokee engine swap
  129. Odometer question
  130. Looking to make the Wipers go faster???
  131. Rear Sag
  132. FSM Advice???
  133. Transmission problem.....grinding noise
  134. Help, running rough *cough*
  135. 1999 Jeep Cherokee Cooling fan.
  136. 1990 Cherokee - Clicking no start.
  137. looking for help
  138. tires
  139. Distributor replacement
  140. No power to radio or cluster in 2000 Cherokee?
  141. Temp Knob won't turn to cool
  142. 99 Jeep Cherokee Brake lights
  143. cost???????
  144. Large evap leak, beeping from gas tank
  145. 96 XJ won't turn over
  146. 1999 Jeep Cherokee Classic PROBLEM!
  147. 1989 cherokee fuel pump stays on with key off
  148. Just bought a 1999 Cherokee
  149. 96 Cherokee Died while driving and won't start
  150. Steering Wheel will twitch when i make turns
  151. 1998 Engine issues...
  152. 1999 Throttle hanging up.
  153. wont go into drive, need help plz!
  154. What are the odds?
  155. transfer case
  156. Tiny hole @ Y in header. Suggestions??
  157. 1996 jeep alternator repair
  158. 1990 Cherokee Lock up torque converter not locking up .
  159. Noise in tranny after fluid change worsens
  160. what tha?
  161. locknut w/wo washer for thermal clutch?
  162. turn signal fails to turn off-Cherokee 1997
  163. oil pump prime
  164. swapping tranny
  165. Flex plate?
  166. XJ battery & rpm gauge not working!
  167. Starter bolts
  168. Did my mechanic rip me off?
  169. Temp Gauge never moves
  170. I got a BDS lift . anyone else? pros cons?
  171. Did I screw my bushings up?
  172. Fcc Number
  173. Brake sieze problem
  174. 96xj 4.0 Spark plug gap
  175. What does this button on the shifter do???
  176. Trans. fluid change 96 XJ
  177. Line-X ed Jeep Pictures
  178. computer codes on 89 jeep cherokee
  179. helppppp!
  180. Computer not sending signal to solinoid
  181. Light problem...any imput helpful
  182. '96 Hub removal, strange fasteners
  183. starts, just for a second
  184. smog issues
  185. I have raised suspension about 2 inches. How much it will cost me to get it back...
  186. Suspect Gasket - Clatter on acceleration
  187. How much can 4.0L 4*4, Man tr. Cherokee tow?
  188. mech. fan thermo clutch test?? Any way ?
  189. rattle in OD and when it drops to 4th on hills
  190. If you replaced timing chain on 4.0 engine why did you do that and what mileage did..
  191. removing overhead console
  192. Scanner
  193. 98 Cherokee sport Transfer case swap
  194. 1988 Jeep cherokee Vacuum switch diagnostics
  195. 1997 jeep cherokee won't start????????????
  196. 89 cherokee cold air intake
  197. Why would a switch be added?
  198. no acceleration lots of backfireing
  199. New catalytic convertor necessary?
  200. Shaking Steering Wheel when exiting freeway
  201. 2000 JCS no start, voltmeter high
  202. No Air Coming From Vents
  203. 2000 Cherokee fuse diagram
  204. No Power and overheating !!!
  205. Electrical Problem...Plz HELP!!!!
  206. cherokee door handles
  207. Turn Signal Problems
  208. 1998 Cherokee Rear End Noise Help
  209. 98 cherokee "death wobble"
  210. Rear main seal
  211. lack of cooling...not very cool.
  212. Coolant level
  213. child safety locks
  214. 91 Jeep ABS pump wont turn off!!!
  215. windshield crack repair kit
  216. oil pan for an Xj and grand cherokee
  217. Possibly Running Hot ?
  218. 99 Cherokee Sport won't start
  219. check engine code
  220. 1997 cherokee electric cooling fan wont work
  221. AW4 Transmission shift problem
  222. 1989 Cherokee hard start
  223. 98 cherokee sport idle surge
  224. xj for student car?
  225. 92 cherokee fuse diagram
  226. front end parts
  227. A short? Bad battery? Alternator problem?
  228. How to glue/join hood latch rods
  229. Troublesome XJ, Any ideas appreciated.
  230. 92 cherokee electrical problems
  231. jeep starts but wont stay running help!!
  232. door buzzer 1996 cherokee
  233. WIndshield 1996 Cherokee sport
  234. Abs Mod!
  235. Cherokee wont start
  236. Replacing Ignition Switch
  237. Not getting gas?
  238. Installing a chevy 350 in a 94' cherokee
  239. Help!!
  240. Major Transmission Problems on 95 Automatic
  241. Help before I shoot this dam% jeep
  242. 4.0 Motor swap
  243. 2000 Sport Brake Rotor **HELP**
  244. need some help
  245. Need owners manual for 95 jeep cherokee sport
  246. liftgate adjustment????
  247. Name This Jeep !
  248. headlights activate rear wipers and washer
  249. 97 CHEROKEE 4.0 MANUAL WON'T START (details inside)
  250. How to open stuck tailgate - lift gate on 99 Jeep Cherokee XJ
