View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22
  1. can i have 31's
  2. tranny problem?
  3. Slow start....
  4. No Lights in the Radio
  5. 94 Cherekee dies
  6. Book time of wheel cyclinder replacement?
  7. A new problem
  8. 89 chrokee limited transmission problems
  9. clicking rear end
  10. Another speedometer problem
  11. Fuse for Tail Light 94 Jeep Cherokee
  12. 98 Power Window Connection
  13. No Heat...
  14. 4.0 stalls intermittantly, but starts right up
  15. 91 cherokee-help jeep bretheren
  16. DEATH WOBBLE 98 cherokee
  17. Transmission Removal
  18. 93 JC Sport won't start....
  19. Vacuum Diagram- 89 4.0?
  20. Pop when take off
  21. 89 jeep xj problems
  22. Sluggish backfiring cherokee
  23. Pwr Locks and Windows??
  24. 1997 Cherokee Key problems
  25. Blue smoke
  26. Accesorie, but no on!!!!
  27. Gas Smell coming from Heater?
  28. ignition starter problem!><! help please
  29. 89 electrical problems
  30. '98 coolant temp sending unit
  31. Vibration Need Help
  32. a different overheating problem
  33. question about the radio
  34. 2000 Jeep Cherokee 4WD problem
  35. 4.0 I6 breather grommet
  36. Cooling mods for a 98. Any ideas?
  37. clutch adjustment?
  38. radio acc wire and hot wire makes dome lights work again hum
  39. 4.0 will not shift into drive
  40. Cruise control
  41. Electrical Problem??
  42. Guages, door locks, dome light Just Quit
  43. 1988 cherokee shift problems
  44. What is a resonable Labor $$ to change brakes?
  45. Sluggish backfiring cherokee
  46. Wont start after changing head 4.7
  47. Serpintine Belt
  48. sensors quastions in my cherokee 2000
  49. MaXXing Performance
  50. Better Braking
  51. Noisy @ High Revs
  52. aftermarket coolant sengin unit
  53. driver side power window stuck down
  54. oil pressure gauge question
  55. jeep seats
  56. Steering column loose
  57. 92 Cherokee rebuild
  58. Jeep hesitation @ startup
  59. Hard Start and fast Idle?
  60. blower motor not working
  61. front brake question
  62. 00' Hazard flasher switch
  63. Tranny Hose Connection
  64. Turn signal / hazards problem
  65. Kits for350 chev in jeep? How? Where? HELP!!!
  66. Check Engine Light
  67. New Jeep owner
  68. 95 jeep cherokee sport engine/crank
  69. '90 Cherokee - "The Sky is Falling"
  70. Cherokee 95 engine whine
  71. No Speedo
  72. anyone need radiator for 89?
  73. 95 cherokee sport clutch
  74. 88 Cherokee Cooling System
  75. Lift-gate lock sbolt?
  76. retro radiator install
  77. My Cherokee 2000 Engine light is on
  78. jeep cherokee 1988
  79. A/C or something?
  80. Power steering squealing whining sound... Please help!!!
  81. 87 Cherokee want to get bigger tires but dont know if they will FIT
  82. 1993 Jeep Cherokee No Start
  83. 2001 Jeep Cherokee Sport
  84. 93 jeep Out of Blinker fluid
  85. Ballast resistor
  86. 1995 jeep overheats
  87. '98 XJ w/possible clutch problems?!?!
  88. Odd electrical problem
  89. blinkers 99 cherokee
  90. wiring problem? window problem?
  91. Up Country Package Question
  92. Bad idle and whining fuel pump
  93. Shocks and Rubber bumper (rear)
  94. Engine smokes after 30 mins
  95. HELP PLEASE> loud knocking from engine
  96. 1996 Cherokee stalls after 20 min.
  97. cherokee 1990 fuel pumpm relay
  98. clunk clunk noise when driving
  99. HELP Installing a Distributor/Engine Rotated
  100. 91 Cherokee ABS problem after replacing rotors & pads
  101. 96 sport starting problem
  102. 88 cherokee> knocking from the engine
  103. Selling 89 cherokee - New York
  104. '85 cherokee pioneer/4x4 indicator light stays on...
  105. Fitting jeep engines
  106. were to buy to cherokee engines
  107. 2000 Cherokee Sport Trailer Lights not working
  108. Loose Steering
  109. Car acting funny...please help!
  110. 93 cherokee engine swap
  111. Antenna motor
  112. no power to power windows and power seats
  113. People in the Miami fl area
  114. Huge dent...need body work
  115. Anti-theft system 93 problems
  116. rear brakes stick
  117. 2000 Cherokee Power Window Problems
  118. 1992 4.0 HO issues
  119. cherokee 89 code readings
  120. 89 jeep cherokee won't start of course
  121. Keyless Remote Entry - Panic Button - 99 Cherokee
  122. Random Problems
  123. '97 Jeep SERIOUS Electrical Probs
  124. 99 Cherokee engine light P1494
  125. Spark knock
  126. Over Heating
  127. '90 Cherokee -- Low Rider
  128. Window Washer Problem
  129. '90 Cherokee front axle leak
  130. Falling Flat 91 4.0 liter Laredo
  131. Still can't find NSS
  132. Still can't find NSS
  133. ignition switch problems
  134. How much can my jeep pull?
  135. 1998 Grand Cherokee Laredo Neutral Safetly Switch
  136. What axle is in the front of this jeep?
  137. Minimum Lift for 32X11.5's?
  138. can i manually roll up a power window ?
  139. Cowl area water leak
  140. '93 cuts off after few minutes at ilde
  141. Wheels
  142. 87 cherokee wiper problems
  143. 98 Grand Cherokee Exterior door panel loose
  144. 88 Cherokee shook violently then died
  145. cant get key out of ignition
  146. Lost 25% of fuel mileage, possible solns?
  147. Clutch frustration
  148. 89-drive to reverse sounds
  149. Getting bolts inside frame rails
  150. 88 4.0 Cherokee dies out in higher RPM.
  151. Cruise Control
  152. 1986 XJ w/ 2.8l V6
  153. 87 Cherokee A/C
  154. 87 Cherokee death wobble
  155. OK, Who needs parts? 91 Cherokee
  156. heating/AC problem
  157. 97 cherokee-rear wiper fluid not coming out
  158. 96 Cherokee clutch pedal question
  159. is it worth the price?
  160. engine interchange
  161. New Power Booster and Master Cylinder, brakes still suck!!! :(
  162. 90 Cherokee I'd love to kick a few times
  163. 97 Cherokee problem
  164. Speaker issue - Drivers Side - 99 Cherokee
  165. 91 Jeep Cherokee. Feeling really bad!
  166. vacuum line diagram 88 cherokee
  167. Transfer Case Socket Size?
  168. 89 XJ - HELP! Engine is choking...?
  169. 1986 2.8l V6 won't run--HELP!
  170. Got new Brake Booster, How to test Master Cylinder?
  171. 89 Cherokee sport 2 door rocker panels
  172. 1994 Cherokee electrical problem
  173. Is this Death Wobble??
  174. Back firing 6 cylinder
  175. 88 cherokee won't start or turn over
  176. Final answer on Jerk and Hesitation!?
  177. 92 cherokee laredo terrible gas mileage
  178. Dash Lights
  179. motor revving high out of control...help!!!
  180. message consul says "bad coolant sensor"
  181. 1992 Chrerokee Speedometer and Cruise Problems
  182. Transmission Slipping
  183. 89 cherokee stalls turning corners!!
  184. Grinding sound in 1998 Grand Cherokee
  185. rearend gear oil recomondations
  186. For Sale NJ: Smittybilt Modular Nerf Bars (Black) 97-01 XJ
  187. Static!
  188. Transmittion Filter Replacement
  189. 86 Cherokee Acceleration @ low RPM
  190. 88 Cherokee Overheating badly - out of ideas
  191. front leaf springs?
  192. Electrical Problem Where do I start?
  193. 98 Cherokee won't idle at first.
  194. 1999 Cherokee - Check Gauges/High Temp Prob
  195. 1996 Jeep Cherokee Electrical Problem
  196. Heater Controls
  197. 94 Cherokee 2wd Transmission noise
  198. 87 cherokee wont stay running
  199. Body side mouldings
  200. 98 wont start after fuel pump install
  201. ac compressor bearing noise
  202. 92 Laredo, Battery Causes Engine To Die
  203. Slow to shift
  204. Please help find web link
  205. My 91's Ignition Is Locked - Help!!
  206. turn signal problem
  207. front bump stop removal
  208. I love my cherokee.....but.....
  209. 1995 Jeep Cherokee Cuts off w/o warning.
  210. Need power steering pulley
  211. 1992 Jeep Cherokee battery tray removal please advise!
  212. Starting Problems 1993 Cherokee
  213. 88 4.0L no fuel
  214. 98 Cherokee jerks from bumps
  215. 1995 jeep gc idle problem
  216. Starter Selinoid Wiring
  217. ash tray light
  218. Vibration
  219. Throttle Body
  220. performance parts
  221. Jeep Cheroke 95 blowing instrument fuses and park lights
  222. 1991 Jeep Cherokee Laredo Alarm System does not reset-cannot crank
  223. looking for rear springs
  224. 91 Cherokee Laredo dies when warm
  225. A/C odor
  226. 1991 Jeep Cherokee Fueling Problem!
  227. battery draining
  228. Buying a Jeep Plz Help me!
  229. Heavy Vibrating Noise (Near Dash ?)
  230. k and n intake system for 1987 cherokee 4.0
  231. Odb Ii
  232. No Cat?
  233. oil pressure problem (89 xj)
  234. webber carb and vac
  235. No Spark???
  236. liftgate compatibility
  237. Overhead console??
  238. Door Graphics
  239. stuck in 4 wheel drive
  240. Rear Reverse Lights stopped working
  241. Losing Fuel Pressure
  242. Spark plugs ...Double Platimun needed or harmful?
  243. Trans hoses leaking ... repaired for a buck !
  244. 96 cherokee stalls, sputters, and lost power
  245. No Headlights!
  246. Cruise control won't take control
  247. 93 cherokee wont start
  248. 1999 Overhead Console
  249. Electrical problem with 87 Cherokee
  250. 2000 Jeep cherokee sport
