View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22
  1. Help! My Jeep Is Moaning!
  2. Total loss, what next?
  3. New motor - no oil pressure!?!?!?!?!
  4. Oil on the air filter.........Whaa???
  5. 4x4 and Starting Problem-90 Laredo
  6. Whinning noise normal
  7. valve train noise
  8. oil presure gauge went crazy
  9. jeep service manual
  10. transmission
  11. wiper fuse location...91 cherokee ltd
  12. Clunking along in 4x4
  13. 2" Lift on '92 2WD
  14. Reprograming remote for 2000 Jeep Cherokee
  15. 99 Cherokee rear end knocks when stopping
  16. charging problem
  17. were can i find a used 6cl?
  18. 1991 jeep cherokee laredo
  19. '96 Cherokee, no blinkers or brake lights
  20. wiring diagram
  21. 2000 cherokee #4 misfire
  22. Jeep Cherokee RHD 1999 running rough on mail route
  23. 96 Jeep Stops taking gas around 3000RPMS
  24. Camshaft
  25. Jeep Cranks but won't Start
  26. Electrical problem / alarm won't turn off
  27. 91 Jeep Cherokee; Random Stalling, Please Help
  28. erratic wiper behavior
  29. Where to buy molding gards
  30. New Jeep Owner
  31. 92 Cherokee NSS
  32. '96 Cherokee. No fuel at rail...
  33. 2000 cherokee #4 misfire
  34. 96 jeep cherokee sport NSS
  35. Length of shocks...Thinking air shocks
  36. 99 Cherokee Strange issue!
  37. no start 1996 chrokee sport
  38. Cherokee Sport: 2X to 4X?
  39. 4 wheel drive in snow
  40. 88 cherokee chief Emis/Maint light
  41. 89 Rear Wiper Replacement
  42. Gas Gauge Reads Backwards
  43. ODD electrical problem with 89 'cherokee laredo
  44. Tires for 3" Lift
  45. 1986 Cherokee stalling
  46. rear end trouble ? (Have 3 days to return)
  47. 95 cherokee starting problems
  48. Cherokee brake extention cables
  49. 89 Jeep Cherokee Wont Start
  50. 86 Cherokee Laredo
  51. Jeep Brake Cable Extension
  52. dash lights, i cant see at night
  53. 89 Cherokee 4x4 won't engage
  54. 1992 Cherokee Sport - Hard starting
  55. no heat / over heating
  56. Synthetic Oil ?
  57. Help!!!!! 99 Cherokee won't start
  58. 93 jeep cherokee has problem with stalling
  59. Simple mods made to your jeep ?
  60. Cherokee Lift
  61. Tire Talk
  62. 88 Cherokee clutch?
  63. overdrive.....interesting ride
  64. 99 Cherokee Rear Wiper Motor Replacement
  65. 97 cherokee start/stall fuel filter question
  66. 90 cherokee blows lukewarm air from heater
  67. 92 laredo clutch problems
  68. Faulty spark plug wires hurt computer?
  69. Drum
  70. cherokee starts then dies
  71. How can I test/bypass my NSS switch
  72. What Kind Of Axle??
  73. power windows aftermarket
  74. "Part Time" Dash Light
  75. 93 cherokee heater fan
  76. Cherry red exhaust, still not good
  77. airbag light
  78. 2 batteries, new alternator.... still dying
  79. Help!!! Radiator fluid in floor.....99 Chief 2.5
  80. Stock Roof Rack
  81. 99 Cherokee heater fan switch
  82. Vaccum Trouble +
  83. Air conditioning
  84. Where is the Neutral Safety Switch?
  85. Idoling Probs For 90' Cherokee
  86. Fuse Diagram Needed
  87. Fuel system?? Help
  88. 89 Cherokee "Part time" 4WD?
  89. 2000 Cherokee wiper motor installation
  90. 95 xj remote start installation problem
  91. 93 4.0 - Gas on Intake - Help!
  92. what to do when changing out infiniti speakers
  93. jeep factor stero wiring
  94. Mystery Wiring ??
  95. several problems 94 GC LTD. Keyless,antenna and cruise.
  96. air bag light stays on on instrument panel
  97. Cruise Control Vaccum Tank
  98. 80 cherokee trans fluid pouring out ?
  99. Jeep Cherokee 89' Turns Over but dies, eventually starts and dies while driving.
  100. 96 jeep labors at start
  101. Power steering
  102. Mystery Vibration on Cold Engine
  103. Roof Rack?
  104. noise when front left wheel fully turned?
  105. Starter
  106. Replacing a left front axle U joint
  107. 99 cherokee 4x4 electrical
  108. Fuel Injector Upgrades?
  109. Radiator for conversion
  110. loud ticking sound
  111. when can i use 4WD Hi
  112. 1994 fsm
  113. 94' cherokee transfer case
  114. Installing 242 Transfer Case '88 Cherk 6cyl
  115. every week i have to add fluid
  116. Cherry-red exhaust
  117. Help I've got a 4WD problem
  118. Problems with Jeep cherokee-someone help!
  119. Need Help Plz Cherokee starts and then OFF
  120. Serious problem!!!! Electrical !!!! 92 cherokee. got nothing
  121. Vacum prob keeps car from running
  122. 1990 Cherokee: Mystery stalling
  123. Front suspension clunking
  124. 95 xj sport tranny problems
  125. blower makes whirling screeching sound?
  126. would like to be able to post attachments
  127. 93 Cherokee with oil/transmission troubles (first post ever)
  128. Ignition Timing
  129. Rattle-Rattle and a cloud of smoke!
  130. Newbie with newly acquired 92 Cherokee
  131. free mods
  132. Map sensor i think HELP!
  133. Power Windows, Radio go out...................
  134. 91 jeep cherokee 4wd 5 sp, 6 cyl wont start
  135. some times wont start if i dont unplug then plug the map sensor
  136. Fuel Pressure Regulator, 88 Cherokee
  137. 94 4.0 np242 no 4hi
  138. 86 wont start
  139. Help, my power windows do not work
  140. new interior for 87 cherokee? where do i get it
  141. fuse diagram
  142. finiky jeep
  143. Fender flares for a 96 cherokee
  144. 89 cherokee, no cup holders!
  145. 92 cooling conversion
  146. odd electric problem - need help
  147. Cherokee Passanger Mirror
  148. WHERE IS HEATER BLOWER ENGINE (89 jc)
  149. chev 350
  150. Brake bleeding blues
  151. Heater Box/Heater Blower Resistor Block/Vac Schematic
  152. Ignition switch Question
  153. Cherokee Laredo 88 speedometer
  154. code: 1041
  155. 97 cherokee sport semi-stalling problem
  156. 4 wheel drive not working
  157. Gas Tank to small??
  158. instaling automatic start on an 87
  159. Engine & Transmision
  160. Starts on and off
  161. ac oil for compressor?
  162. R-12 or R-134a?
  163. 4x4 will not ingage in front axle? help!
  164. Oil From Blown Head Gasket? - 88 Cherokee
  165. Rear disc brake conversion
  166. fuel tank humming
  167. overheating, not as bad
  168. runs great...won't start
  169. Even Simple Jobs can be trouble...
  170. Overheating...gee who woulda guessed
  171. Blow-By
  172. Shimmy at speeds between 56 and 64 mph
  173. '99 cherokee sport
  174. valve train chatter
  175. Horn not working!
  176. Ignition Problems
  177. Cherokee belt squeal
  178. stuck thermostat?
  179. 91 Jeep Cherokee keeps stalling. Help me!!
  180. exhaust flowmaster or magna flow
  181. turn signal
  182. Headlight do not shut off, bright indicator on
  183. overheating, of course-revisited
  184. Help!!Rear end sagging and clunking
  185. Help, tire selection
  186. removing the fan in a '96 4.0 . . .HOW!!
  187. Idle Problem
  188. dash lights and window fuse keeps blowing PLEASE HELP!!!!!!
  189. Steering gear box replacement
  190. restoer engine & lub?
  191. 88 motor Problems
  192. Ground Location-Signal/Marker/HazLights Harness
  193. clutch fan
  194. 88 Wagoneer front end "skip" and grind
  195. what lift kits would you guys suggest
  196. U Joint?
  197. key troubles
  198. 1987 Cherokee Fuel Rail
  199. 1999 sport heated side mirrors...
  200. Overheating, of course
  201. wipers
  202. GEN light - 96
  203. 89' Jeep Cherokee temp gage
  204. Does NE1 know where I can find a pic of how the window cable attaches...
  205. XJ seats
  206. Cherokee 91 rain water leaks.
  207. problems starting
  208. won't start
  209. remove ignition tumbler
  210. 4wd
  211. Shaking
  212. i have no compretion
  213. Yellow spark=no start
  214. Serpentine Replacement
  215. 2001 Jeep Cherokee Sport radio problem?
  216. [Req] Dash Pics
  217. FYI--rear window wiper motor an easy replacement
  218. any one know where i can find an engine?
  219. service manual for 93 cherokee
  220. '01 sport window regulator oem part number
  221. not geting spark
  222. electrical problem
  223. Oil pressure gauge stock
  224. Very Bumpy Ride
  225. 93 Jeep Grand Cherokee 4.0 Crank Position Sensor?
  226. wont start when hot
  227. More horses for my 92' 4.0
  228. 1987 Jeep Cherokee Electrical Problem
  229. 88 Cherokee Headliner
  230. Rubber Recommendations Anyone?
  231. Cherokee damaged by thief.
  232. Seat belt light does not go out
  233. 1992 cherokee ignition/starter problem?
  234. My XJ shakes at 55-60... CANT FIX IT!!!!
  235. 87 Cherokee Lift ?
  236. popping noise
  237. Oil leaks--where to start?
  238. 94 cherokee dashboard problem
  239. Swapping Differentials
  240. high idle
  241. 1990 Odometer/Speedometer not working!
  242. 89 cherokee delayed spark
  243. Thinking about adding roof rack...Ideas?
  244. 4.10 gears
  245. 2000 Cherokee Parts
  246. 1989 cherokee crank sensor wiring
  247. Average gas mileage
  248. 89 jeep cherokee
  249. 2000 Jeep Cherokee Front Drive Shaf Question
  250. Overseas Military, Help W-89 Cherokee
