View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22
  1. Tailgate Latch Won't Open
  2. Emissions vs grade of gas ?
  3. High gas pressure!!! Please help!!
  4. high idle
  5. Electric Mayhem
  6. Adding louvers
  7. Air conditioning blows!!!
  8. Wife's 1992 Cherokee 4.0L Just Quits - Help!
  9. what differential
  10. NOX of luck
  11. Cherokee Manifold replacment Part II
  12. battery getting weaker
  13. Dumped wifes jeep in mud hole
  14. 1991 Cherokee over heating!
  15. 1988 jeep cherokee laredo
  16. trans line issue.
  17. jeep tranny not shifting
  18. 31's, Stock Lift?
  19. 2.8L Needs More Power!!!
  20. 94 Cherokee Sport Temp Gauge
  21. 87 xj needs man. trani fluid change?!?!?!
  22. engine light on
  23. Draining coolant system in a 98 Cherokee
  24. Please Help. Refilling A/C with R-134a 94 Jeep Cherokee Country
  25. how to reset the ecu?
  26. '95 Cerokee won't start!!!
  27. Electric Fan
  28. 1991 Cherokee Rotor Disc Removal
  29. 89 cherokee with issues...
  30. 1991 Cherokee won't start???
  31. '01 Spark Plug Replacement?
  32. Fuses and what they protect?
  33. A/C Hi-pressure sensor?
  34. A/C freon level
  35. a\c Clutch/ Low pressure switch
  36. Removing venture?
  37. What I did this weekend
  38. window replacement
  39. 96 xj how can i make it run cooler?
  40. 97 Cherokee A/C fault
  41. Loss of Power on hills
  42. fuel filter and spark plugs
  43. Electric Fan '92 XJ
  44. Brake Shoe size?
  45. clacking noise in engine
  46. Cherokee Manifold replacment
  47. Clutch
  48. 1999 Cherokee Needs Air Freshening
  49. air conditioner not blowing cool air
  50. 1988 jeep 2.5l and 2.8l questions 1988
  51. better gas mileage?!?!?
  52. Coolant leak!
  53. want to buy 1990 jeep, what to look out for?
  54. blower motor
  55. burn't piston
  56. Electric Fan motor
  57. power window motor
  58. Speedometer
  59. wont start checkin for spark, etc
  60. swaping a jeep engine
  61. 1996 Cherokee Sport keyless remote wiring
  62. 00' Cherokee - Rear lights, dash lights, clock light out, brake light works
  63. crazy shake
  64. Black ball thingy
  65. What are the chances of a rock busting out the headlight?
  66. Manuel to Auto tranny?
  67. HELP! She's broke!
  68. 01 cherokee a/c problem
  69. 1999 Cherokee Sport long cold start
  70. Power Windows and Power Locks problem...
  71. Strange overheating
  72. Wheel bearings-97 Cheerokee
  73. Eletric problem with my '96 cherokee
  74. 93 Cherokee- Replacing Rocker Panels ?
  75. a/c clutch doesn't engage when hot
  76. 86 2.5 oil leak
  77. thinking about buying a jeep
  78. 96 cherokee sport radio wiring
  79. durabanks coating
  80. shifting problem
  81. 90 cherokee makes beep noise
  82. rear end noise
  83. Parts swap?
  84. power steering fluid
  85. 92 sport a/c/ compressor problems
  86. 86 cherokee major problems
  87. V-8 Swap
  88. No power going to the coil, can I jump it to the battery??
  89. Tranny Flush??? Yes or no.
  90. Squealing front console - arrrggghhh!
  91. steering question
  92. 88 cherokee stalls a lot
  93. 95 cherokee keyless entry remotes?
  94. Odd Electrical Problem
  95. wasting away 15x6 steel whls (8) $32
  96. wrong side?
  97. idle prob?
  98. 90 cherokee stuck in 4wd
  99. '88 XJ...no wipers
  100. 87 cherokee power mirror wiring diagram?
  101. 87 cherokee power mirror wiring diagram?
  102. Marvel Mystrey Oil
  103. wiring diagram for a jeep cherokee laradeo 4x4 for the radio
  104. Ah...no start and complete dying '01 XJ
  105. A/C Heater Vents
  106. A/C Heater Vents
  107. 1990 Cherokee,need help identifying relays
  108. 90' XJ want stay running/stalls in park
  109. Synthetic Oil qiestion
  110. How to test the power window motor?
  111. bad oil leak (not rear main seal)
  112. 97 jeep cherokee questions
  113. 90 Cherokee Dead!
  114. 96 jeep has no fire to the distributor or coil HELP
  115. 96 Cherokee 6 cyl Starts and Dies
  116. O-ring seals on oil-filter assembly
  117. 98 Fuel Intake/Stalling issues . . .
  118. 1992 Cherokee Laredo - Auxilary Fan Keeps Blowing Fuse
  119. No a/c at operating temperature
  120. 96 crank no start
  121. removable doors
  122. Remote Entry for 98 Jeep
  123. High RPM at 60mph. HELP!
  124. 94 Cherokee heater valve? Can I bypass it?
  125. right side power windows
  126. Newbie ? about engine swap.
  127. Where to get new flares.
  128. Gauges just died in 2000 Cherokee
  129. Front Speaker Wire colors?
  130. Can someone help me with this turn signal issue??
  131. engine misfire?
  132. Rear "rumble" type noise when stopped in DRIVE
  133. Wheel Paint
  134. Radiator Drain
  135. M/T wheels...help please!
  136. Stereo Help
  137. 90 Wagoneer overheating
  138. 88 cherokee stuck in 2nd gear
  139. compass,temp display
  140. changed clutch pedal
  141. Parts
  142. Noob Question Time Again
  143. OEM Radio Wiring Info
  144. New Jeep Or New engine?
  145. antifreeze smell
  146. Interchangable jeep manual/book ?
  147. Jeep Cherokee Mk 1 Skid Plates
  148. better MPG and mods what next?
  149. Idle Problem
  150. front axle!?!
  151. 98 Grand v8 front springs on 89 Cherokee
  152. 93 jeep cherokee overheats
  153. 89 Jeep Cherokee
  154. Cherokee Headlight problems
  155. 1992 Cherokee Limited Overhead Console problem
  156. 86 Cherokee Engine ??
  157. FS: 36" Spare Tires
  158. FS: 36" Spare Tires
  159. Engine Knocking at idle when cold
  160. Two Cherokees
  161. 88 Cherokee Brake booster
  162. Help! Left Key On all day - Now No Spark
  163. What else do I need ?
  164. 1995 Jeep Cherokee towing capacity
  165. Sensors different for different dash clusters?
  166. sorry 4 double post
  167. What would u do????
  168. What would u do?????
  169. 89 Cherokee 4.0 Fuel rail leak ...
  170. please I need owners manual cherokee 99
  171. Transfer case drops out of gear
  172. engine swap
  173. a/c controls help in cherokee 99
  174. Caster - Camber Adjustment / Ball Joint Replacement
  175. Audio problem ??
  176. 1985 cherokee engine swap???
  177. Jumping NEedles
  178. over heating jeep
  179. 1995 Cherokee Country quit while going down the highway.
  180. what switch and where?
  181. 87 Cherokee won't start
  182. #2 misfire
  183. helping a friend
  184. Sagging headliner
  185. '95 cherokee won't start
  186. radio trouble!
  187. Lifters replaced, still strong clicking noise
  188. 1998 4.0L wants to die on freeway
  189. A Scary Night in Northern Idaho...
  190. exhuast help
  191. is oil pressure ok??
  192. '94 Tranny/clutch probs - need suggestions
  193. return spring 88 Cherokee
  194. Blower motor location? 01 cherokee
  195. brake grinding noise
  196. adding more lift
  197. Front Left Speaker No Working
  198. Turn signal lever replacement
  199. new tire carrier on back door?
  200. when installing injectors
  201. A/C Compressor not cycling ??
  202. Water in blow by tube
  203. bushwacker flares
  204. Skipping, stalling, OBDII 45, or P0705. clean you NSS
  205. horn not working wan to rewire it
  206. Keys
  207. loud noise coming from driver side door
  208. 93 jeep keyless reciever
  209. Best Shocks?
  210. self tooting horn
  211. Top speed in 4H
  212. Rubbing noise
  213. 88 cherokee won't start (sometimes)
  214. main seal leaking
  215. Wet carpet and Towing
  216. Fender Flare Hardware
  217. Locking gas cap or door?
  218. Blue Vacuum
  219. 2000 Cherokee / Blown Head Gasket !
  220. fuel filter(s)?
  221. a/c issue
  222. gauges/interior lights dont work
  223. Cherokee Performance Upgrades
  224. yet another starting problem - 1996 4.0
  225. window lock on 2000 cherokee
  226. 2000 jeep cherokee 4.0L
  227. 1998 Cherokee Gas Gauge shows empty
  228. Are HO engines better?
  229. rear ends
  230. speaker size
  231. need tc help
  232. 86 Cherokee 2.8L tranny probs
  233. Up Country suspention
  234. 96 Grand Cherokee motor, into a 1989?!?
  235. Rear Locker Question
  236. Fender Flare change reasons from pre97 to newer
  237. clutch pedal diagram
  238. clutch pedal
  239. 88 closed cooloing system question
  240. Tempature Sensor/Dash Gauge
  241. Please Help with headlights
  242. 89 cherokee blinkers, clock, & dome lights all stopped working???
  243. ???? 2.5 liter to 4.3 liter engine swap ????
  244. need help fast
  245. A/C troubleshooting
  246. long cranking before start
  247. acceleration problem???
  248. Can anyone tell me where the Reverse light switch is
  249. Seprentine Belt Squeaks with A/C On
  250. gearing after lifted jeep
