View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22
  1. DIY Jeep Repair
  2. Huge sucess changing axle universals!
  3. corvette engine (327) or 4.0L
  4. Modulator valve on 98 cherokee?
  5. 1999 door panel removal
  6. Shudder at Hwy speed, NOT unbalanced tire
  7. 1989 Jeep Cherokee 4.0 Rough Idle Problem
  8. what causes auto tranny to shift? computer?
  9. 88 intermittent misses / dies
  10. Fuel Pump Quagmire
  11. 97 Cherokee Head Gasket Problem?
  12. changing front axle uni's (Hey Dale!!! you out there?)
  13. 76 cherokee 4wd
  14. carburated points distributor is there such a thing?
  15. Good Times changing the oil
  16. Replaced everything...what am I overlooking?
  17. Transmission Troubles
  18. My jeep starts runs for 5-10 sec then stalls
  19. 94 Cherokee Electric Seats Dead
  20. Problems on my 87 XJ w/ 470K Miles
  21. In the Jeep Market
  22. Rough country lift review?
  23. 1995 Cherokee wont start
  24. 89 cherokee auto trans won't shift!
  25. Common stall problem in Cherokee Sports?
  26. Core plug problem
  27. Wiper problems
  28. PLEASE HELP !!!! MANY Problems !!!!
  29. '98 Cherokee's headlights
  30. 99 Jeep Cherokee Sport Fan Sticks On
  31. Need a solution for mushy weak brakes
  32. transmission Concern
  33. Transfer case leak
  34. 1991 keyless remote
  35. Coolant Disappearing
  36. Door locks and latch lock troubles
  37. my jeep is history
  38. 94 Cherokee NO SPARK
  39. 87 Jeep Cherokee Idle and Rev Prob...
  40. transmission and lift questions 96 xj
  41. cylinder head torque settings
  42. Where is the Crank Sensor
  43. 88 Jeep Cherokee specs HELP
  44. help wit 01 chrekee limited
  45. '96 xj overheating prob
  46. death wobble
  47. Please need HELP with 96 cherokee sport
  48. Lost all oil in a 1998 Cherokee
  49. Shifting Problems!!!Please Any Help???
  50. Help...metal on metal grinding noise
  51. Oversized Tires
  52. 91 Electrical Problem
  53. 93 jeep cherokee stereo wiring code
  54. Help Jeep runs like crap and dies when I turn on the headlights?
  55. coolant leak...
  56. can i bypass the ac compressor?
  57. I Need Help !!! Quick!
  58. 89 Cherokee overheating...and overheating...
  59. prostart remote starter won't work
  60. Looking for a Cherokee Overhead Console
  61. Ignition Switch Compatibility
  62. Valve Cover
  63. All JEEP parts for sale (new from dealer)
  64. Won't hold oil pressure
  65. Rear brakes
  66. Ticking noise
  67. 1995 Cherokee cuts out on idle
  68. engine turns over but doesnt start Help Please
  69. Power Window makes noise when fully up
  70. Speed tach and fuel gauges out
  71. 98 XJ 2.5 I4- Need Power
  72. Help Problem with my 1988 cherokee cooling
  73. Cherokee sounds like a jet
  74. Transmission knocks when warm
  75. 1998 Cherokee electrical problems
  76. Headlamp switch? Bare wire? HELP!
  77. 1991 Cherokee ABS Light
  78. striped power window
  79. Busted U-Joint
  80. 2000-2001 Jeep Cherokee Rough Idle / Multiple Cylinder Misfire
  81. EGR System problems!?
  82. 2001 Cherokee Check Engine Light
  83. Cherokee/ Grand Cherokee
  84. Wont Start when warmed up
  85. NEWBIE here!
  86. OIL LEAK search HELP!
  87. transmission light on
  88. checking the quadro 1987
  89. 97 Cherokee w/ rear end vibration when decelerating
  90. Leak in transmission???
  91. Leakage on the return line for automatic transmission, how to connect?
  92. 1989 Cherokee 6cyl shuts off while driving
  93. How Big Is Yours???lol
  94. 18" rims and tires FOR SALE
  95. Please help me fix my Jeep so my girlfriend won't make me sell it!
  96. just another lift question
  97. 95 Cherokee brakelight burnout
  98. More motor mount stuff
  99. How Big Is Big Enough?
  100. up country suspention
  101. 1990 4.0 passenger side motor mount
  102. No thermosthat
  103. 2000 power window issues
  104. rear end thumping and grinding
  105. Please Help, Axle Shift Motor?
  106. Speaking of Harmonic Balancers...
  107. 98 Cherokee Transmission smoking
  108. 87 4.0 cherokee overheating
  109. 85 Cherokee High beam & blinker indicators
  110. Installing keyless entry, lil' help?
  111. buying a jeep
  112. jeep that revs at idol
  113. 1992 cherokee wont stay running
  114. programing car remote
  115. sounds like jeeps going to turn off when inreverse
  116. EGR Valve Question
  117. stuck in 4wd
  118. Any Good Sites On Cherokee Parts Installation
  119. any ideas would be helpful
  120. 1988 XJ 4.0L serpentine belt replacement
  121. Power door locks on 89 cherokee
  122. knocking 4.0
  123. Hard to start 1990 Jeep Laredo
  124. Keyless Remote Programming?????
  125. Window crank - Does it come off!!!
  126. Please Help With 89 Cherokee
  127. Why all the Giggles????
  128. 89 cherokee & 91 bronco parts swap
  129. Jeep (Chrysler) Svc Manuals Contact Info
  130. tranfer case specs
  131. Electric window motors
  132. Where to mount cd changer in Cherokee???
  133. New water pump, new stat still overheats
  134. 1990 steering problem...Help
  135. 1996 Cherokee won't start
  136. Just rebuilt engine, car won't start
  137. need more slack from speedometer cable
  138. Pre 92 Cherokee Radiator Conversion
  139. Jeep has sat for two years un-started...What to do to help the engine before startin?
  140. 1999 Wont Start, Going Nutz HELP ASAP PLEASE
  141. Rear Brakes
  142. Throttle position sensor
  143. pressireized air
  144. 1990 Jeep Cherokee Laredo Cruise Control
  145. wheels
  146. headlights quit 94 cherokee
  147. Rear Crankshaft Seal $
  148. 96 Cherokee w/ Suspension Issues - Help
  149. UPGRADE ?'s On MY 87' Jeep Chero Pioneer
  150. springs/coils
  151. Removing Rear Panel.. How?
  152. Older model Jeep Cherokee (1990)
  153. water from the tail pipe
  154. How do you BURP! the cooling system??
  155. Cannot open rear door
  156. Replacing speakers, a few general questions
  157. 87' Jeep Chero Pioneer Water Pump and Nocking Noise Problems
  158. wiring diagram.....
  159. Oil sending unit issues????
  160. Where is a/c fuse located for 90 jeep cherokee laredo
  161. no 4wd low
  162. oil pressure
  163. Engine dies when warm
  164. wheels/ thumping
  165. windshield wipers not working properly
  166. Hellllllllllllp!!!!!!!!!!!!!!!!!!!!!!!!!!
  167. 88 cherokee won't heat up!!
  168. 92 Chero Laredo-body/frame question
  169. Fuel pressure drops when I turn off the motor
  170. tires/lift/dilemna
  171. Tire size on Jeep
  172. u joint installation
  173. Instrument panel lights 1991 Cherokee
  174. 95 Cherokee... overheats on highway
  175. Newbie,with some questions
  176. '84 cherokee wont idle when cold and blows black smoke
  177. Looking for parts jeep
  178. Want to Buy Seat
  179. if your cherokee wont run it's probably your ground wires
  180. Bad News for my T-case
  181. 88 Cherokee clutch problems
  182. 87 jeep cherokee 4.0l oil in air filter
  183. Air Filter has OIL ON IT!?!?! What's wrong??
  184. erratic oil pressure
  185. 1996 Cherokee Sport Power Windows dead
  186. AIR Intake
  187. 88 Cherokee Gas Guage not working???
  188. local 4x4 shop in TN?
  189. Jeep with 20's
  190. oil pressure
  191. Interested in Leather?
  192. Will A Tach Cluster fit in a Pioneer with no modifications?
  193. 87' Cherokee OverHeat During Idle
  194. aftermarket tach
  195. do i have a blown headgasket?
  196. Instrument panel lights
  197. Electrical Problem
  198. no parking lamps
  199. Tach, Speed, Gas Guage
  200. i need help on underhood relays
  201. Chrome grill shell
  202. gauges not working....please help
  203. Resistance across fuel sending unit?
  204. Need 2001 XJ sport wiring diagram
  205. Custom Wheels for JEEPS
  206. idleing problems... please help
  207. 1988 Cherokee Pioneer, electrical problems, turn/S, blower, radio, wipers.
  208. 88 comanche chief hard vibration
  209. Custom Leather Seats
  210. 2000 Cherokee Sport-Vibrations-Shaking in Steering-Trans Problems?
  211. J8s-800 2.1td/1991
  212. oil pressure?
  213. Transfer case swap in '84 Cherokee
  214. 20" rims 4 sale
  215. New Leather Seats for my Cherokee
  216. rear main seal
  217. 1991 jeep cherokee cutting out
  218. Fan not kicking in
  219. Transmission cooler 2000 cherokee
  220. wont turn over
  221. red brake light with a timer like noise???
  222. Cold air intake for a 90 Cherokee
  223. Replacing blinker switch
  224. Help setting clock...
  225. clunking under the hood
  226. engine missfires and backfires
  227. Stereo wiring and harnnesses
  228. 82 Cherokee Chief V8 - engine cuts out
  229. passenger door lock
  230. Charcoal Gray Leather Seats
  231. A/C compressor only works sometimes
  232. Oil getting in my air filter
  233. Heating problem
  234. 4 x 4 problems
  235. 89 Jeep seems to be Frozen?
  236. Jeep Cherokee 2000 transmission trouble
  237. Electric Fan Not Running
  238. 2001 Cherokee Classic engine starting issues
  239. Elecrical problem Instrument cluster
  240. FWD electrical problems
  241. Tail Lights...Short? HELP
  242. '99 Jeep Cherokee high oil pressure
  243. Another overheating Jeep
  244. 1992 cherokee stalls
  245. POWER vs. COMFORT
  246. 1990 xj laredo missing something !!PLEASE HELP
  247. 89 jeep bout to cause divorce please help
  248. air conditioner conversion
  249. Sending unit for water temp
  250. Thermostat housing gasket info??
