'96 Cherokee. No fuel at rail...
fat_daddy_dave
01-03-2005, 04:57 PM
...I replaced the fuel pump and filter a few weeks ago and it ran fine until yesterday. It turns over, and I have good spark (I just replaced the plugs, wires, rotor and cap) but no fuel is getting to the rail. I can't believe that a pump would go bad so fast. What else should I check? Would a bad relay cause that to happen, or should I check the CPS first?
JDPascal
01-03-2005, 07:55 PM
There is a fuel pump relay in the power distribution center under the hood near the battery. Check there.
JD
Dale Aeppli
01-04-2005, 06:07 PM
When you turn the key on can you hear the fuel pump relay click
Dale [email protected]
LiftedObsessions
01-05-2005, 08:18 AM
If it clicks you need to check you Fuel Filter. Becuase that could be clogged
bmwilson
01-06-2005, 08:43 AM
if you can hear the pump with the key in the run position, and have a new filter as you type. I have an idea, I know that no mechanic makes mistakes yet if the install was poor the pick up tube may not be attached curently. Also if I am wrong as I would like to be disconect your line at line at the rail and tank and blow it out for possible obstruction. At any rate it you can do it yourself and save gas money.
