wiper fuse location...91 cherokee ltd
stabcabin
01-06-2005, 04:48 PM
the wipers worked fine yesterday.....but today, the snowiest day so far in chicago, they just would not work at all.
after eliminating the fact that they just froze up, i assumed it was either the fuse or the motor.
i have the chilton book and it said the fuse is in the fuse block, to the left of the steering wheel
i don't see a fuse for the wipers in that fuse block.
i see everything labelled pretty clearly, i see a fuse for the REAR wipers....i just don't see a fuse for the front.
the book says it should be a 7.5 A fuse but due to the car changing hands, i'm sure fuses have been replaced/upgraded/downgraded so it's hard to tell whats what anymore.
so before i move on to the wiper motor, can someone tell me exactly where the front wiper fuse is located, color, amperage....anything?
thanks
thanks
fergmonster
01-06-2005, 10:59 PM
ok, on mine a 1994 2dr. its a 5.5 amp "circuit breaker"
in slot # 20 all the way to the left under one of the round flasher relays. good luck...
JDPascal
01-06-2005, 11:24 PM
My book shows a circuit breaker. If there is a round flasher at the top left of the fuse block, then the breaker is directly underneath it. A long verticle piece.
JD
JD
