h.p gain !!!!!!
baker1234
02-12-2006, 08:49 PM
http://www.slowboyracing.com/more.php?id=4859&
would that really give someone 40 whp on a t-25 turbo????
and im looking for the most horepower for my car without upgrading the turbo any one have any suggestions on what to buy????
DragonofBC
02-12-2006, 09:14 PM
Why not upgrade your turbo? I'm sorry I can't give any input on the intake manifold.
crunchymilk55
02-12-2006, 09:16 PM
it wouldn't give you any more power with the T25, you're not anywhere near outflowing your stocker. SMIM's are one of the last bolt-on's, if not the last in the upgrade path.
UnderEstimate Me
02-12-2006, 10:27 PM
Id focus on upgrading your fuel system right now.
gthompson97
02-12-2006, 10:55 PM
save the money you waste on that and get something that will help you more now. fuel, turbo, tuning devices, etc.
E-Klips
02-14-2006, 07:21 PM
For $650 you could get a 14b, make your own install it, some 550cc injectors, and a S-AFC and make more power than you ever would on the stock T25 with a sheet metal intake manifold. Just a thought.
scottsee
02-14-2006, 07:34 PM
The reasion why it's just not worth installing an aftermarket sheet metal intake manifold is because of the flow rates of the t-25, runner desine of the intake & cylinder head speed volosity. The 2g head was designed for higer volosity/lower flow # becasue of the size of the runner ports. The t-25 has absolutly no chance of ever maxing out the flow limits of the 2g head. The turbo it's self is only usefull within its boost thresh-hold of 2600 and flow effenct of 5500. If you look at the mathamatical equations of VE and compare it to the Flow #'s of the head & intake you will see that it's impossable to out flow either. High speed volosity stacks, pendium desigine and port size is relitivily worthless at such a low rpm range of the t-25. You need a 14b
UnderEstimate Me
02-14-2006, 10:12 PM
Hell just go for the 16g :D
TheRomer
02-15-2006, 08:18 AM
agreed :2cents:
agreed :2cents:
