Fuel
Black99GST
03-06-2006, 07:52 PM
ok, so i got fired about 2 weeks ago, and i've been kinda down... so i decided... i'm going to finish my Fuel system. I've got a Aeromotive AFPR, SS lines, Walbro 255 HP and a rewire kit... i'm thinking 1000cc injectors, because thats what everyone was telling me...I will be runnign a AGP Turbonetics RS49T, With manifold wastegate set up... and as my Sig states... I'm only looking for 400-450 because i dont want to touch the internals untill after i get out of school... i got $400 and something that tells me 1000cc's is over kill... anyone?
Talon69
03-06-2006, 08:14 PM
Like kevin says if your gonna buy injectors and plan on upgrading bigger later, get the big ones now. Thats what im gonna do now since i finally got my DSMLINK ;)
Maybe this site will help you if you have not allready seen it before.
Im going with 880cc i think
http://www.importevolution.com/product_info.php?products_id=2983
Thor06
03-06-2006, 08:28 PM
I'd get the biggest ones you can get cheap. I think 780's will suffice, but that seems like a stretch. I wouldnt go lower that 850's. Definately get DSM link first.
blk_srt
03-06-2006, 08:30 PM
Go big or go home:lol:
Black99GST
03-08-2006, 08:21 PM
so 1000cc's??? on a daily, street driven car??? you sure? that just seems SO big to me... I wont be going any bigger then my 50 trim, and no higher than 400 WHP... thats it... thats my last goal... so really? 1000cc? i dont know, it just seems like i can kiss gas millage GOOD-BY... any more input?
scottsee
03-08-2006, 09:31 PM
1000cc's on that turbo is perfect with Dsmlink. You do infact have DSmlink right?
defiancy
03-08-2006, 10:38 PM
Just lost your job? Just dump all the rest of the money you have into your car! ;) Just playing.
I'm going with 1000cc injectors but I also plan on running a 60trim.
kjewer1
03-09-2006, 06:29 AM
With DSMlink there are no percievable drawbacks to running up to 950cc injectors, regardless of the rest of the setup, in my personal experience. I haven't yet run anything larger, but aside from 1000s from RC, there are really only the 1600s from FIC and some other place. The 1600s can now be controlled by DSMlink (adjustment range extended), but I can't comment on driveability.
I'll be going straight to 950s on the EVO, even if I stay on the stock turbo ;)
Black99GST
03-09-2006, 10:14 PM
ok, I'll have to get 1000cc's then... i was thinking something more like 880's but that was just a rough guess... alright, one more question, i have the walbro 255HP and was wondering what amperage it runs at? when i do my fuel system install, i'm going to rewire my pump, obviously... and i need to put a fuse in the circuit... anyone know the amp limit for this pump?
Thor06
03-09-2006, 10:45 PM
IIRC, Kevin said they run up to ~20 amps. I dont know though. I dont think you need to worry about a rewire, I think the 255 should do you fine for 400-450 hp.
Black99GST
03-10-2006, 06:07 PM
on stock pump wireing? as it is, i can here the pump kinda "dieing" at idel with the turn signal on... its like its just not getting enough power... and besides, i already bought the kit... so 20 amps?
kjewer1
03-11-2006, 10:01 AM
I usually run the standard 30 amp fuse, and 10 or 8 guage wire (though 12 should be plenty).
Edit> It's worth mentioning that the rating of the fuse should match the rating of the wire, or be lower. The fuse is to protect that wire, not the pump :) The current rating can sometimes be found on the wire (on high quality stuff) or taken from the many charts available online that cross reference guage and length.
Black99GST
03-11-2006, 10:43 AM
thanks Kevin! so you think i should get 950's? i'm only looking for a little over 400 WHP on a 50 trim turbo... after that, i'm done with power mods. i still need the car to streetable... but at the same time, fun as hell to drive.
kjewer1
03-11-2006, 11:21 AM
I really like the FIC injectors, so yes, with DSMlink, I recomend 950s. Enough for tons of airflow (75 lbs or so?), and with DSMlink, they idle and cruise like stockers.
Black99GST
03-15-2006, 10:31 AM
thank you sir...:worshippy
