AIR DRIED BEEF DOG FOOD
A friendly reminder to change your spark plugs folks.
crunchymilk55
03-15-2006, 01:33 AM
Or your car will by trying to spark up one of these!! :rofl:
http://img70.imageshack.us/img70/3973/10103689wl.jpg
Remember guys, good DSM owners change their plugs every oil change! Don't be like me and get lazy, then see one of these :banghead:
NGK BPR7ES $1.39 stock number 2023 at Oreilly's
DO IT!
crunchymilk55
03-15-2006, 01:35 AM
O yeah this is what happens to your plugs when the screw on your boost controller falls out and you have a boost leak the size of a fat chick and you run rich as hell. :eek:
In case anyone wanted to know....:smokin:
kjewer1
03-15-2006, 02:36 AM
Sweet. I do plugs every other oil change typically, unless I suspect something is wrong with them. But thats the longest I go.
nova1313
03-15-2006, 08:30 AM
oh. I change plugs every 20k miles. I guess I should do that more often..
Killa
03-15-2006, 09:44 AM
is that the best plug for 4g63 engine ?. How do u gap them ?
ned032002
03-15-2006, 09:53 AM
When I had my DSM I tried to minimize my spark plug changes because both times that I changed mine I broke the Wires also. No matter how hard I tried to not hurt them they would always break, and each time they break its another $45.
I never knew NGKs were so cheap?
l_eclipse_l
03-15-2006, 01:13 PM
Yes, it is the best plug for the 4g63. You gap them using a gapping tool found at any auto hardware store, as with gaping any plugs.
crunchymilk55
03-15-2006, 02:31 PM
gap at .028
and what the FUCK does this have to do with performance?? wrong move sphyder...
Turbodog97
03-15-2006, 02:45 PM
And be sure not to buy Bosche:lol: :
http://img67.imageshack.us/img67/395/12341fg.jpg
MexRocket
03-15-2006, 03:51 PM
ouch... yah this isn't performence lol how do you know when the wires are going bad?
Turbodog97
03-15-2006, 04:18 PM
You'll know if you car starts missing/studdering in the higher rpms. They are usually good for 10k maybe a little longer. You can also tell, if they were as shitty as mine, by letting the car idle and touch one of the wires(does it shock the crap out of you? mine did:))
l_eclipse_l
03-15-2006, 05:31 PM
Uh...I think they go longer than 10k. I would guess they are good for atleast 25-30k before they need replacing again.
AbsoluteGTR
03-15-2006, 05:51 PM
What with the attitude?
Also...l_eclipse_l....Turbo cars must change there sparkplugs way more often than the N/T. I think that 10K miles would suffice if not more often. If and when I get my turbo DSM, I would do sparkplug changes every 3-4 oil changes (9K-12K miles).
l_eclipse_l
03-15-2006, 08:14 PM
I was talking about plug wires, since it seemed as though thats what you were talking about after mexrocket asked. Plugs I agree with you.
crunchymilk55
03-15-2006, 08:46 PM
haha you could touch the wire and it would shock you. Yeah, those wires must suck. I bought some crazy expensive onsonku wires or something. They're the widest on the market I could find. I can't remember for sure, but I think they're 11mm.
The attitude was because sphyder complained about us posting in the wrong forums several of times. The definition is that if the topic doesn't fit the subtopics, then it goes on the main page. I wasn't asking which plugs gave me the most performance, I wasn't asking about which plugs look better, and I didn't have any problems with them. If a mod tell us to post in the right place, and we do, but it's moved to the wrong forum, that's a problem.
rs97eclipse1695
03-15-2006, 10:03 PM
ok so how often should the plugs in my 420a be changed?
i think its been a while...def more than 5 oil changes
EDIT>>
and what do you other NA's reccomend as far as brand?...i know theyre just plugs and im not gunna see any power outta them...but as far as good plugs that last a while and work great
l_eclipse_l
03-15-2006, 10:18 PM
EDIT>>
I'm running NGK Iridium. Work great with the screamin' demon coil and OBX wires. I would say change them every 15-20k, dosn't need to be nearly as often as turbo cars.
xavier3jr
03-15-2006, 10:50 PM
im running ngk v power or some shit
scottsee
03-15-2006, 11:33 PM
My plugs are shot, just like my turbo, HG & oil pan seal. Fuck it.
defiancy
03-16-2006, 10:53 PM
I bought some Denso's for the GSX.
Living big.
Thor06
03-17-2006, 12:10 AM
Mike runs wal mart ones because his car eats the like fuckin cheerios. Hes got some wicked knock that melts them like butter.
MexRocket
03-17-2006, 12:13 AM
Fuck what? Doing the plugs? Or the car in general, rebuild I am assuming. :licka:
UnderEstimate Me
03-17-2006, 12:28 AM
Actually the best plugs for a 4g63 are the NGK BPR6ES. But thats considering the car is pretty much stock. BPR7ES's are for modded cars. Thanks for the post. I totally forgot to switch mine out, Ive used these for at least 10k.
ez1286
03-17-2006, 12:40 AM
I went to ngk's website and they say brp6ekn, a double ground plug. I wonder how those run, tey cost a lot more than brp7es's
crunchymilk55
03-17-2006, 12:51 AM
those are the stockers, those are the best to run if running 15psi or less, 16 or higher, the bpr7es are the way to go
ez1286
03-17-2006, 01:03 AM
Which one's are you talking about? The brp6ekn or brp6es? i thought the es was stock. I don't see any benefit of a double ground, it's either going to spark to one side only, or spark to both with half the power which would suck.
crunchymilk55
03-17-2006, 01:54 AM
I called the dealer the other day, they have the 6ekn listed as stock. I would guess the 6es is just the same thing without that extra crap. Obviously the 7es is 1 step colder
kjewer1
03-17-2006, 10:04 AM
The 1gs came with the regular single ground, the 2Gs came stock with the double ground plugs, though no one ever puts those back in.
Killa
03-17-2006, 08:21 PM
I went to advant auto, and bought some ngk plug, for my 94 eclipse. The guy pull up the list , I was suprise that BPR6ES-11 was on the list ( stock # 7133) I though it only for turbo, but any way I bought 4 ( 1.77 each ). Is this ok to put in my 94 eclipse. And since Im doing oil change tomorrow, can I use my mitsubishi oil filter ( I still have 4 left from my 97 rs ) on my 94 eclipse ?.
l_eclipse_l
03-18-2006, 02:19 PM
I don't think you will be able to use the oil filter from your 97 RS.
