View Full Version : Intrigue
Pages : 1 2 3 4 5 6 [7] 8 9 10
  1. Wheel Bearings 98 Intrigue
  2. FS 2001 - 2005 Remote Fobs(2)
  3. FS 2001 - 2005 Remote Fobs(2)
  4. tranny prob may need flush?!!
  5. Penzoil Platinum Oil full Synthetic
  6. Window Troubles
  7. replacing the bose head unit
  8. fuses
  9. Sticky Gas Pedal
  10. what brand tires do you have?
  11. burning oil, which oil is best?
  12. please help...guage prob + sum others
  13. 99 3.5L Engine Change - Other years?
  14. Crankshaft Sensor replacement...
  15. Aftermarket Rims
  16. SES, PCS, ABS, trac all lights on Help
  17. 99 olds intrigue 3.5
  18. car running lean?
  19. 98 intrigue air conditioner
  20. Check out this Intrigue its superchargered
  21. Check out this Intrigue its superchargered
  22. Miles to a tank of gas??
  23. 2000 oldsmobile intrique heating problem 3.5
  24. Fuel gauge is acting funny
  25. Engine shutting off
  26. extended warranty '02 Intrigue
  27. AC Compressor for 2000 Olds Intrigue
  28. 2000 3.5 misfire
  29. Starting Problems
  30. What kind of MPG do you get?
  31. Looking at a 2002 GX
  32. New Transmission in 1998 Intrigue
  33. Very Confused And Need Help!!!!!
  34. Peeling rubber sill
  35. White film on PCV valve???
  36. Sagging Headliner
  37. ignition-no tune-up
  38. Will my car go 'stupid'?
  39. Stuck cassette tape
  40. Ac Light Stays On Whenever Heat Is On
  41. '98, brake & abs light on, bad shifting, and other issues
  42. Service Engine Soon Light
  43. Adjustments to Bose Amp?
  44. cars puking gas
  45. Spark Plugs
  46. Motor mount
  47. Multiple Cylinder Misfire, 3.8
  48. no crank at all!!!!!!!!
  49. interior climate fan making a clicky sound
  50. 99 Olds License Plate Light
  51. Low Oil Light
  52. Help!!!!
  53. Bought AC Delco Platniums, NGK were in the box???
  54. need help for new injector(s)
  55. 2000 intrigue climate control question and a couple others....
  56. 2001 Gear change problem
  57. Changing a crank position sensor
  58. Climate Temperature Sensor
  59. car shuts off while driving
  60. How do i get the dam door panel off?
  61. replacing 3.8 intake gasket
  62. stuck r. f. brake caliper
  63. A few Audio wiring questions..4 my new 98.
  64. Help, many problems
  65. newbie, just bought a 98...few questions
  66. hard shift when hot
  67. 98 Intrigue S/C possibly?
  68. Sporadic High Idle
  69. Is it my tire or something else?
  70. 98 intrigue service engine light
  71. Calibration of 2000 Intrigue Rear View Mirror With Compass and Thermometer
  72. 2000 Intrigue - Heating up in Cold Weather
  73. 99 intrigue rough running/starting
  74. Starter Replacement
  75. Engine Temp./No Heat ????
  76. Please give me good advice
  77. Hard to start sometimes
  78. Locking Gas Cap
  79. Bad Fan Motor- Any1 Know How to Replace
  80. Where in the world is the power steering check?
  81. Anyone know how to remove change tray?
  82. '98 Intrigue Power Window Problem
  83. Foul Smell
  84. Timing Belt Replacement
  85. Tech2 C-code list
  86. How do you replace brake fluid
  87. Strut-Tower Bar
  88. 98 intrigue wipers stuck in vertical position
  89. Intermittent starting problem
  90. HID Light Conversion
  91. Changing the Blinkers
  92. 1998 olds,pbile intrique hot and cold temp
  93. 2000 intrigue A/C clutch bearing removal
  94. Here is a new one for you, at least for me it is
  95. late shift
  96. 2001 intrigue no start
  97. Stuck Emergency brake
  98. ABS and BRAKE light are on
  99. where is the cdplayer interface located?
  100. Over charging issue with alternator
  101. Groaning sound when stopped in drive
  102. Confused Oldsmobile Intrigue 2000 Owner
  103. UPDATE!! on "What the Heck is going on" Message
  104. automatic headlights
  105. ses light on
  106. Control Arm Bushings
  107. Gas Cap Actuator
  108. 99 Olds Intrigue (3.8l) strut noise? also ps noise,vibs.
  109. What the heck is going on?? Need Help!
  110. Security Problem i think?
  111. Recall and TSB lists in MS-Excel format
  112. Water pump removal
  113. Ticking Noise and Belt sounds
  114. Highway vibration
  115. Oil usage
  116. Gas Pedal
  117. Sensor Hell!
  118. Hard start smell gas (cold or hot) 98 Intrigue
  119. Noise from the front right side wheel
  120. Thermostat Replacement
  121. 1999 Osmobile Intrigue Service Engine Soon
  122. Anti-Lock light on
  123. service light
  124. dimming lights
  125. Replacing the Starter
  126. 98 Intrigue signal lights
  127. no heat, no seat warmers, no window
  128. Vibration from front of car.
  129. want better brakes?
  130. Service Engine Soon light
  131. Engine problem
  132. Lights for fuel filler door and trunk release
  133. Intrigue heating blower
  134. Hazard Button Removal Procedure?
  135. low coolant light 02 intrique 3.5
  136. performance chip
  137. Air bag light flashes
  138. instrument cluster not working
  139. Z-Max (linkite) Yes or No?
  140. problem solved..Thanks
  141. night illumination
  142. Vehicle Breakdown
  143. passlock problem
  144. 99 Intigue
  145. Change Oil Light
  146. heating, AC, headlights, cruise control
  147. heating problem
  148. Low Oil Light
  149. rough acceration
  150. Problems with Intrigue
  151. 2000 Intrigue windshield washer
  152. Intrigue downpipe size?
  153. Aux input
  154. temparture sensor
  155. No blower for the heat!
  156. "Advance" codes for Service Engine Soon light
  157. Serious Electrical Problem?
  158. engine swap
  159. 2001 olds intrigue
  160. intrigue sercive engine soon light
  161. A.c.
  162. New Window Motor, too weak
  163. Help !! 98' intrigue.. maf problem and more.
  164. wich alternator
  165. Sticky e-brake
  166. car shutting down
  167. radiator cap, stupid question
  168. heat is so slowly
  169. First Freeze
  170. Cleaning the MAF
  171. turn signals on '98 Intrigue
  172. 98 Intigue headlights
  173. headgasket/intake manifold issues
  174. 2000 Intrigue
  175. 00 Intrigue/ noise come from left side when braking
  176. 00 Intrigue/ noise come from left side when braking
  177. RockAuto 5% Discount
  178. Stereo problem
  179. can not start only "click" scan test B2960
  180. Rear coil springs 1998 Intrigue
  181. start problem "click"
  182. Good Bye Intrigue...Hello Optima
  183. Power Steering
  184. Driver's seat belt won't retract
  185. BCM draws 270 mA from battery, normal?
  186. '98 Olds Intrigue, repair manual, or brake help
  187. Need help with turn signal problem
  188. Car cranks but hard start when warm
  189. Help! I think I have a coolant leak!
  190. Aftermarket Headlights
  191. rear drivers window down
  192. Keyless entry ?'s
  193. Intrigue ?'s - struts
  194. 3.5L oil consumption, dealer says piston oil rings stuck
  195. trunk leaks....
  196. How do I replace Turn Signal Indicator Bulb(or LED)
  197. DRL and fan turning on issues
  198. 2 questions
  199. 98 Intrigue tranmission ?'s
  200. Apology
  201. 98 Intrigue tranmission ?'s
  202. 98 Intrigue tranmission ?'s
  203. Coolant Filling
  204. Who's not using DEX-Cool?
  205. Random Hard shifting
  206. Radiator Flush
  207. New tranny, same problems?
  208. Brake Light
  209. loosing air preasure
  210. Good to know about your alarm
  211. sticky door locks
  212. Vibration
  213. Alarm system woes HELP!!!!
  214. Drivers Side Windows no longer working
  215. Hard to Start after sitting
  216. wipers stop working
  217. pulls right on accel after repair
  218. 1998 Intrigue, Transmission question
  219. Need car smart opinions, please
  220. No Start/Crank
  221. NEW BODY KIT Oldsmobile Intrigue NEW BODY KIT
  222. 2000 Intrigue steering question?
  223. Scary suprise while adding oil-what is this?!?!
  224. How Much?
  225. Is this major enough to keep me from visiting inlaws?
  226. '99 Intrigue: a couple problems...
  227. Tie Rod Ends/Rotor Question
  228. Changing spark plugs
  229. Cracked Wheel?
  230. Tranny Problems
  231. temp light
  232. front end noises, help!
  233. Coolant looking funny
  234. Engine moves 1/8"....motor mounts?
  235. heater sensor
  236. Service Engine Light code-Multiple Missfire
  237. 1998 intrigue steering rack recall CANADA????????????????????????????????????????
  238. someone using ethanol e-85 on intrigue?
  239. 98 Intrigue Gas Gage freaked out
  240. 1998 Intrigue steering rack recall
  241. Buzzing noise
  242. Same old problems
  243. true CAI for the 3.5
  244. couple suggestions
  245. Code C1226. RF Hub Replacement
  246. a few questions about my 2000 Intrigue
  247. Isn't it amazing?
  248. Problem starting 2000 Intrigue GLS
  249. 2000 Olds Intrigue Alternator Help
  250. Fuel gauge still not working proberly after replacing sending unit
