View Full Version : Intrigue
Pages : 1 2 3 4 5 [6] 7 8 9 10
  1. 2000 Intrigue P0101 P0410
  2. Starting Problem
  3. Lights are burning out
  4. 99 3.5 radiator removal
  5. Suspension Noise
  6. Fog Lamps constantly requiring replacement
  7. 99 Intrigue Transmission Mount
  8. Bad noise while turning left.
  9. How to remove rear spoiler
  10. 98 Intrigue Climate Control Fan Noise
  11. P0301 problem
  12. My fenderwell intake with pics!
  13. bad ignition switch?
  14. Gear Ratio Change
  15. 3.5 Timing Chain/Tensioner R/R
  16. info on control arms
  17. Where can I get Dex-cool
  18. New Member/Hi
  19. Guidelines for buying a Used Intrigue:
  20. Location of Turbine speed control (part)
  21. Don't lower your Intrigue
  22. Odometer question
  23. New muffler/resonator pipe for '99 3.5L
  24. Blower motor not working on lower settings. Could it be the resistors or resistor mod
  25. 99 Intrigue "How to check power steering Fluid"
  26. Increase Gas Mileage
  27. Where's The Darn Power Steering Fluid Go??
  28. Climate control unit question
  29. sensors
  30. Exhaust Sputtering
  31. Cv R/r
  32. Reset Oil change light
  33. Bad Ball Joints
  34. Slight coolant odor
  35. help ! mass air flow sensor
  36. How do you replace an altenator?
  37. 12" rotors and struts question
  38. Windshield Wiper Problems
  39. How Much would you pay for a 99 Intrigue
  40. Aux Input Static
  41. head light flickering
  42. CV Drive Shaft Replacement
  43. 2000 Intrigue - 113k - Burns Oil - Synthetic?
  44. Re: Genera test vehicle search, CA.
  45. Paint Code
  46. Engine light on....
  47. Driverside window regulator
  48. Some dealer claims to want Intrigues
  49. Q; Replacing rear blinker bulbs
  50. 99 Intrigue GX Keyless Entry question...HELP!
  51. Defrost not clearing window
  52. Alternator
  53. Bad news from Tranzgenic
  54. tranny shifting hard
  55. Antifreeze change
  56. Multiple problems... Can anybody help???
  57. How to test the coil Pack
  58. Still necessary to disc. battery on recharge?
  59. window problem
  60. 2000 Intrigue engine dies
  61. Head lights are all Foggy
  62. "Yatzee Shaker"
  63. Power steering and brake fluid flush
  64. Trans filter change
  65. 3.5 vs 3.8 Intrigue
  66. problem with breaks
  67. Rear Defroster Does Not Work
  68. my newest mod
  69. '98 no start, SES on, 5 DTC's
  70. Break Problem
  71. Turn Signals...
  72. Which hose is heater inlet 1998
  73. Parts for '98 Intrigue
  74. Change all hoses?
  75. Steering question
  76. Winterizing your car:
  77. po171
  78. Am I going to kill my car (or myself)?
  79. 2000 Intrigue...P0385 code
  80. Will a cobalt wheel bearing Hub fit an Intrigue
  81. Downloading repair manual?
  82. My Car refused to start!!
  83. 2000 Intrigue location of blinker relay or other possible problem question
  84. Color of Remote Wire on 99 Oldsmobile Intrigue
  85. just a couple pics, nothin fancy
  86. Interior Lights not working
  87. 2000 intrigue abs
  88. How do you remove - front seat headrests?
  89. Update to noise while idleing
  90. Dead compressor?
  91. Flushing coolent
  92. Front wheel speed sensor
  93. '02 3.5 intake manifold cleaning?
  94. Cold air intake
  95. 98 Intrigue spark plug changing
  96. How do I remove the Steering Wheel
  97. Intrigue dead, no power, won't jump
  98. FIX IT OR GET RID OF IT 98 intrigue 130,000k
  99. no start,no crank
  100. Steering noise
  101. Service Engine Soon light after gas fill up
  102. Aftermarket Wheel bearing hub assembly
  103. Front strut replacement, '98 intrigue
  104. front bumper replacement
  105. 2001 Intrigue, a strange security problem
  106. a/c only works on high - '98 intrigue
  107. Installing a Fuel Pump
  108. Which Haynes repair manual for a 1998 Intrigue
  109. 99 Intrigue - NO start (new BCM)
  110. Power Window parts?
  111. what type of wrench?
  112. Vanity Mirror / Visor
  113. Front struts lower bolt removal
  114. Whirring/grinding noise 2002 intrigue on startup
  115. Rattle Sound
  116. Loud Bang when turnning on Reverse
  117. Good deal on two repairs?
  118. check engine light blinking
  119. tranny with 3.29
  120. Learned an Expensive Lesson
  121. 2001 vibrates, flutters in drive
  122. 2002 oldsmobile Intrigue
  123. E-brake wont lock
  124. 2000 Intrigue - Major electrical problem
  125. 2000 Intrigue 3.5 Air Conditioning blows warm under acceleration
  126. Loosing a weld in strut tower.
  127. What Did I Do Wrong? - Horn Problem
  128. 2000 Transmission hard shift
  129. Is there away of lubing the Strut Bearings
  130. Trunk Cd Changer cable location?????
  131. replaceing alternator
  132. a/c hissing
  133. I have a 99 with a 3.8
  134. Any one with a Code Reader In Toronto Area
  135. Rad cooling Switch on 3.8L 99 Intrigue
  136. Silver plastic covers on engine there for a reason?
  137. someone is getting a custom throttle body!
  138. Poll: How long before changing spark plugs?
  139. fog light housing
  140. Trio of Problems
  141. Secondary Air Pump
  142. new to forum
  143. hints or tips
  144. 'groan' noise from steering
  145. DIY tranny flush?
  146. what color is your intrigue?
  147. Headlight problems.
  148. odometer issue?
  149. steering grind
  150. 2002 - replacing o2 sensors
  151. 2002 engine will not start
  152. New owner.....
  153. Poop's out at higher RPM's while accelerating
  154. 98 intrigue...ABS and BRAKE light
  155. How to change trans fluid
  156. A/C cool...not cold?!
  157. Intermitent A/C operation on 2000 Intrigue
  158. Changed my Own Oil on 2000 Intrigue
  159. Fuel Gauge Broke. Anyone ever fix there's
  160. Broken Motor Mount?
  161. a/c clutch fastener bolt
  162. Testing A/C clutch
  163. Dash board removal to fix A/C door
  164. Removing 99 Intrigue Steering Wheel
  165. Crankshaft Position Sensor
  166. 99 intrigue 3.5L engine making loud noise
  167. 98 3.8L Air Conditioning Problem
  168. PK2 Passlock 2 system failure and bypass proceedure
  169. All dash lights come on, headlights dim and car dies
  170. car pulls slightly to the right when...
  171. Service engine soon light -- again!!
  172. 99 3.8 shut off problems
  173. 1999 Rear View metal plate
  174. Cruise Control
  175. start up/dying probs
  176. Where is the fuel pressure regulator located in 2000 Intrigue (3.5)?
  177. 2002 3.5 Intrigue Tranny RPO
  178. Check engine light-Help
  179. 99 Intirgue overheating in idle
  180. Outside Temp Thermometer
  181. Engine Hesitation At Constant Speed
  182. 98 Intrique belt broke on engine temp went to hot
  183. Addco Front Swaybar
  184. Shifter got stuck in park
  185. Car starting/dying problems!!!
  186. throttle body spacer
  187. Starting
  188. Installing a Remote Starter.
  189. 99 Intrig. A/C & display itermittent operation
  190. How do I check fuel injector 4 for misfire?
  191. What are the cylander # layout on 3.5L?
  192. Anyone know how to change spark plugs?
  193. Engine Oil Pressure Switch
  194. HVAC fan not working
  195. Center console LED's not lit up...
  196. Engine Mount Replacement
  197. Gas Gauge Fluctuations
  198. Reverse glow gauges
  199. 2000 Intrigue Brake pulsations
  200. I am so lost when it comes to performance parts.. please help
  201. Would swapping my non digi climate control for a digi work?
  202. Shifting an automatic? Bad?
  203. Hole in firewall for amp/electronics install?
  204. 1998 Intrigue Engine Valve Problems
  205. More of a high pitched noise than a vibration....
  206. Door panel removal
  207. Leaking rear valve cover
  208. Severe coolant leak - please help
  209. Front wheel noise
  210. Setting time in Intrigue 98'??
  211. 2000 Intrigue - Changing the Coolant
  212. Engine Vibration! Help please...
  213. Repaint
  214. Crankshaft position sensor
  215. '99 Intrigue 3.5L fuel sensor shows 150%
  216. First post check it out
  217. Service Vehicle soon Light
  218. '99 intrigue 3.8L air conditioning problem
  219. P0410 Fix???
  220. Starting problems
  221. Numerous HVAC problems
  222. New and Old Members Please Read
  223. Plastic Roof Strips
  224. Power window problem
  225. Power Stearing leak question
  226. factory wires in stereo
  227. Weird electrical problems
  228. Another turning signal problem
  229. Bad Ignition Coil
  230. Bizarre odo behavior
  231. Dash lights blinking and needles going crazy
  232. Help With Ac
  233. 98 intrigue starting issues
  234. AC - ext. temprature stays at 32
  235. Hazard Lights work....Right side turn doesn't
  236. ABS and emergency brake lights
  237. Rear Brake Vibrating Noise
  238. Hard Start Issue Semi-Resolved
  239. waxed and washed....sort of
  240. Brakes
  241. Biggest rim size
  242. Xenon HID Light Bulb Replacement
  243. replacing the head unit with a bose
  244. Gurgling noise!!!
  245. Air Bag Dash Cover/Insert Replacement
  246. car starts its self, dash lights out ramdomly
  247. Top end knocking when hot
  248. Replacing Oxygen Sensor
  249. Bad Compressor?
  250. wierd question
