View Full Version : Intrigue
Pages : 1 2 3 [4] 5 6 7 8 9 10
  1. 3.5 coolant drain
  2. Anti-Lock Light is On
  3. About to change Hub Bearing Torque spec?
  4. Water Noise in Dash
  5. noise when turning
  6. Power Sunroof/moonroof mechanism broke
  7. OBDII DLC connector
  8. 12 spoke Alumninum Wheels
  9. rear cam cover gaskets (finally)
  10. Fuel pressure regulator or electrical?
  11. Temp gauge
  12. Car hesitates while driving down the road.
  13. what is this called
  14. Clicking before starting
  15. Did the '98 Intrigue have an air dam under the radiator?
  16. Turn Signal Indicators
  17. Won't start - Clicking under dash from
  18. clunking noise while turning
  19. Governor on 2001 Olds Intrigue
  20. Repair Manual?
  21. 1998 (3.8 liter engine) Oil leak
  22. Looking for Climate Control Unit
  23. Guide: Accessing the rear speakers in your Intrigue
  24. Rear Panel Removal
  25. ABS/TracOff/Anti-Lock radio going in/out
  26. Keyless entry problem
  27. Minor Electrical Issues
  28. 2000 GLS Hard-starting Resolved!
  29. cut off - hit curb
  30. Climate Control Doors
  31. Stalling and hard to start
  32. How do I change Crank shaft sensor?
  33. Windshield Chip question
  34. Tiger Paw Touring T vs. BF Goodrich Pro Series
  35. Re: Blend Door (with pictures and the common problem)
  36. nothing is working
  37. Engine, airpump, or something else? help!
  38. Help!!
  39. flashing ses light
  40. 2000 Intrigue...starter? ignition switch?? HELP!!
  41. Another Starting Issue
  42. Flashing Instrument Cluster
  43. Loose window control panel
  44. Amplifier Power Wire
  45. Horn Not Working
  46. Drivers window very slow
  47. 1998 Intrigue Front Speaker Replacement
  48. Trunk Space
  49. Check Engine Light
  50. Auxiliary Audio Source
  51. Prestone Antifreeze
  52. Air Dam
  53. My radiator/coolant light keeps blinking on my 1998 Oldsmobile Intrigue.
  54. All power went out and won't start!!!!!
  55. 98 Intrigue cranks slow, but starts
  56. wont start and no spark but cranks
  57. Abs Control Module Not Working??
  58. New spark plugs at 100k miles
  59. Heater Cores or Heater Fan....HELP
  60. Is there a brake fluid 'dipstick'?
  61. '99 Inttrigue 3.8 misfire
  62. Plug Wires
  63. Shift Kit Installed
  64. Wiggle and Rattle in 2000 Intrigue
  65. 98 3800 won't start
  66. 02 Intrigue coolant leak questions
  67. Trunk Lid Support
  68. A/C Flush-Recharge
  69. Lights replacement on 99 Intrigue
  70. Climate control problem (2000 GX)
  71. Passenger-side Wiper not working
  72. PO102 code during inspection
  73. brakes
  74. Odd noise while stopping
  75. Starting issue a bit different than the rest...
  76. Wipers park in middle of windsheild
  77. HID's
  78. High Mileage
  79. Brake fluid resevoir emoval
  80. tune up
  81. Parts For Intrique?
  82. Help Starting Issue. Doesn't want to start sometimes
  83. Climate Control
  84. Strange cords found behind radio
  85. Misfiring and ticking
  86. Electrical Problems
  87. Chasis Lube?
  88. keyless entry and door problem
  89. remote car starter
  90. another blower motor/fan prob.
  91. 2 new CKP and 1 new CPS. 10,000 miles and both bad again!?!
  92. Transmission
  93. 2000 intrigue starting madness
  94. Radiator fan problem
  95. No traction control
  96. Long cranking before starting up and Service Vehicle Soon lights up.
  97. Hard tire spin
  98. 2000 Intrigue
  99. Front Valve Cover install pics.
  100. 2 Problems New Member
  101. Oil Consumption Questions
  102. Security light
  103. Check Engine Light
  104. LED dash replacement?
  105. Turn signal problem
  106. 2000 Olds with 36,000 miles on it
  107. Maybe, just maybe, I should .....
  108. Drivers side door intrument control panel lights
  109. Wiper Blade Park
  110. Hazard light switch part number
  111. Change Oil Light
  112. Dead 99 Intrigue
  113. 98 Intrigue - Misfire or transmission?
  114. What do you use, 5W30 or 10W30??
  115. 1999 Intrigue rebuid snag
  116. '98 Won't take gas, rollover check valve?
  117. Antennas on 01 intrigue gls?
  118. Troubleshooting keyless remote programming
  119. GM's Engine Problems, Solved with easy Fix
  120. im stumped
  121. Will 5x114.3 Rims Fit on Our Intrigue's
  122. got a doner car
  123. 1-2 Shudder
  124. Sticky Shift Knob/Button
  125. Oil in rear cylinder?
  126. Washer pump 01
  127. ac compressor
  128. need new motor
  129. climate control went out...HELP! its cold out!!
  130. Help with 99 Intrigue climate control or blower motor resistor
  131. got it runing
  132. 99 Intrigue, lug caps needed
  133. battery indicator-real simple
  134. CLimate Control cluster/Auto headlights not working
  135. Oh... S*%t!!!
  136. 2000 3.5L AIR pump system
  137. 1999 oldsmobile intrigue/security light
  138. 1999 oldsmobile intrigue/stalling
  139. Fuel level sensor
  140. Electrical System Pulsing
  141. 2000 Intrigue blower motor works sometimes
  142. so never seen!
  143. Trans Problem as well
  144. cooling fan problem
  145. Fog Lights
  146. water pump replacment on 98'
  147. 98 intrigue trans problems
  148. Check Engine LIght - P0101
  149. 98 Intrigue headlight/heater problem
  150. Cluck noise when steering 00 intrigue
  151. a/c recharge
  152. where can the coolant leak be?
  153. Transmission - OD troubles
  154. Subwoofer Wiring
  155. 99 Intrigue - replacing just the mirror glass on the drivers side?
  156. cure for water on pass. floor?
  157. How to install fan motor on 99 intrigue
  158. 99 Intrigue - Dirvers Side Window
  159. please help!!
  160. Energy Suspension Bushings
  161. intrigue transmission fluid change
  162. adjusting rocker arms?
  163. oil dipstick tube location?
  164. reinstalling a coil pack problem
  165. Strange things are happening
  166. Crankshaft Position Sensor Question
  167. a/c not working fuse keeps blowing
  168. Changing PCV on 3.8L engine
  169. Expert advice needed!
  170. Maintenance on 2000 Intrigue
  171. 1999 Olds Intrique Gage and Warning Lights
  172. 1999 olds intri 3.8 wont start
  173. seems alot of people have tranny issues..heres mine
  174. 1998 olds intrique 3.8 broken starter snout housing
  175. 1998 olds intrique 3.8
  176. OIL Leak
  177. Firing Order
  178. Clunk when braking in reverse
  179. check engine soon stays steady, blinks periodically, rough idle, driveable?
  180. Transmission Problems
  181. blinkers?!?
  182. weeked chores, spark plugs, pads/rotors etc
  183. Starting problems
  184. Transmission Problem (No OD)
  185. AC is stuck on and some doors wont open on 2000
  186. Coolant Color?
  187. Location of ground screw for HVAC
  188. Night view mirror broke
  189. Won't start
  190. Tire pressure?
  191. Passenger power seat-doesn't work
  192. 99 Olds Intrigue transmission problems
  193. Fuel door release latch
  194. blinkers
  195. Blower Resistor?
  196. Steering left - noise/hard to turn
  197. Airbag cover open?
  198. Rough Shifts
  199. Transmission Troubles
  200. Tire or Bearing noise? LR tire/wheel
  201. looking for 2001 ign harness diagram
  202. oil consumption
  203. Transmission filter change
  204. 1999 Intrigue Climate Control Problems
  205. Fuel Bleeding Down in Fuel Rail Quickly
  206. 99 Intrigue Hard Starting
  207. Transmission Problems with 98?
  208. hi - airbag light
  209. How to measure Tire Tread Depth
  210. transmission pan gasket
  211. 1998 Intrigue, New member looking for advice
  212. Is it Possible?
  213. White smoke at startup
  214. DTC code questions
  215. CKS or camshaft sensor needed (2000 Intrigue)
  216. found the leak, water pump or line (with pic)
  217. Resonator has a hole in it
  218. Starter On Its Way Out???
  219. coolant capacity
  220. My Heater Core Just Blew 2nd time
  221. 2002 Intrigue Blower Motor
  222. 99 Intigue front bumper cover and fenders
  223. Can I Replace my 3.5 ENGINE with a 3.8 series II-SAME YEAR
  224. No Speedometer or Odometer
  225. Power steering fluid reservoir location?
  226. 2000 GLS - troubleshooting P0410 code (service engine soon light)
  227. How do I install switch to turn on Cooling Fans
  228. think im loosing coolant...or not?
  229. Drive axle Olds Intrigue
  230. Transmission Fluid Color
  231. Coolant Change - Engine Drain Plug
  232. Cranks Long before Starting
  233. 2000 Intrigue, difficult starting when warm
  234. Anyone put on different fog lights
  235. Any change Exhaust on 3.5L
  236. 2001, coolant overflow question
  237. Car can't start at all its been 4days
  238. Electrical! Gauges moving without keys in!
  239. Cold Air Intake and Air Pump?
  240. Rubber covers to headlights/plugs up the hole
  241. Passlock disabled but stalling persist
  242. 99 intrigue will not start... new starter, new battery, i dont know what to do
  243. 2000 3.5L stalling after starting
  244. 99 Intrigue tracion control, abs & airbag light flash. Blower motor cuts in and out.
  245. Possible transmission leak
  246. Hard to Start
  247. Parking brake malfunction...
  248. HVAC Air Conditioning recirculate mode issues
  249. Starting/Electrical problem?
  250. Air Condition Blows Out Every Vent
