View Full Version : Intrigue
Pages : 1 2 3 4 5 6 7 8 9 [10]
  1. Update to Service Engine Soon Light
  2. Temp Gauge acting funny - Possible Thermostat Problem?
  3. 2000 Factory Repair Manual
  4. 1999 Intrigue 3.8 Engine Hesitation
  5. High Idle - Causing major headache!
  6. Air and Oil Filters for 99 Intrigue
  7. 2001 Olds Intrigue Fog Lights Not Working
  8. Horn not working and window is stuck
  9. Consol indication
  10. cruise control
  11. Turn Signal problems
  12. 3.5L spark plug replacement, how to?
  13. starting problem in 01 intrigue
  14. 99 Olds Intrigue - RPMs remain accelerated even while idle??
  15. Whiney belt
  16. Security Light 98 Intrigue
  17. Three warning lights on at once - help! ('99 3.5 Liter Automatic)
  18. Hello, need assistance
  19. fuel filter whereabouts
  20. Where is the in-door fuse panel?
  21. 1998 intrique purchase ?
  22. newbie saying HELLO to the group!
  23. Locked out of radio
  24. Power Steering
  25. excessive noise
  26. On-line Parts Suppliers
  27. 1999 intrigue consumes oil
  28. Headlights/Dashlights flickering
  29. Hi, I have a 99' 3.5 with rod knock 29k can you replace rod bearings in car?
  30. Knight Performance Intrigue Pictures
  31. body kit
  32. Other GM factory radios that fit a 2000 Intrigue?
  33. Need Help: Replacing the map light bulbs on mirror
  34. crankshaft position sensor question
  35. Solution for intermittent no-start/no-run problem
  36. 1999 Int. Trans or alternator problems?
  37. Intrigue tranny conversion
  38. Oil filter wrench for 2000 Intrigue
  39. Intrigue performance & troubleshooting source
  40. 1999 3.5L hard starting problem fixed
  41. P1441 - Service Engine
  42. fuel pressure regulator Q for the gurus
  43. Intrigue electrical problem
  44. Cabin Air Filter
  45. Buick 1988 Torque Converter
  46. security sucks
  47. Does anybody answer questions on here? I'm sorry if I'm not a frickin' car tech
  48. Oldsmobile Intrigue
  49. Keyless Entry
  50. Performance for intrigues
  51. Fog Lights
  52. Transmission problem?
  53. Oldsmobile Intigue 1999 GL
  54. Clock radio problem
  55. What could be the problem?
  56. 98 Intrigue Front Air Dam
  57. 99 Intrigue not starting when hot!
  58. Turn Signal Trouble
  59. Keyless entry for '98 Intrigue
  60. 13 sec intrigue
  61. Stop light race stories??
  62. security system on 2001 Olds. Intrigue
  63. Do I Have Keyless Remote ??98 Model
  64. windshield washer
  65. Keyless entry Remote Instructions
  66. Olds Intrigue Performance Options
  67. Oil change, 1999 Oldsmobile Intrigue
  68. Question for Intrigue Owners
  69. Olds 2001 Intrigue Change Oil light
  70. Intrigue Headlight Questions
