92 talon intermittent no start no codes help
skulley
10-10-2005, 12:04 AM
Hey I`d appreciate any help I can get I have a 92 Talon non turbo 2.0 automatic that won`t start sometimes, ussually after rain. It has no codes, has spark and fuel to the rail I am guessing the injectors are not firing. I saw someplace about a bad connection in the harness behind the right headlight causing this problem and wiggling the harrness does seem like it might help. The problem is too intermittent to be sure. I went to the dealer but they couldn`t find any tech bullitens, recalls, or product improvement campains. If anyone has any info on this, where the bad splice is, wire colors, or anything I would appreciate it before I just go tearing the harness apart. Thanks so much!!! Remember it`s not how you get there it`s how much fun you havegetting there.
ned032002
10-10-2005, 01:15 AM
Try checking the ground from the starter to the chassis. Also will it not crank or does it crank and no go?
skulley
10-10-2005, 07:49 PM
It turns over but won`t start, ussually after rain, as I said it`s got spark and fuel to the rail it just won`t even try to hit then all of a sudden it goes. It`s got a short some place effected by moisture I`m guessing causing the injectors not to fire but not twrowing a code. Guessing!
