Oil leak question
Sepharu Sakhmet
06-19-2005, 11:37 PM
I am looking at a late 80's eagle talon turbo at a local impound yard. I startred it up and it runs rough but stable, and there is a small hole in the valve cover that I have no clue what it's for... there is oil leaking rapidly from it when the car runs. Presently there is a golf tee plugging it to stop the leak. any idea if this hole was supposed to be there as a pressure blow off - filled with a rubber grommet, or is this hole possibly the result of an internal engine part punching its way outta there?
l_eclipse_l
06-19-2005, 11:44 PM
Late 80's = 1989 first year of the eclipse/talon
That sounds fucked up. Personally, I wouldn't even bother with that POS. I doubt that hole was supposed to be there if oil is spilling out of it that easily. Go and find something a little newer, you will be better off, unless your into rebuilding engines and shit. Good luck.
Sepharu Sakhmet
06-19-2005, 11:48 PM
Just looked at the paper, 1992, apologies, and yeah, that was my fear, Thank you
l_eclipse_l
06-20-2005, 12:43 AM
Hope you find something worth your time and money. These cars definately won't let you down in the satisfaction category. However you will get some headaches, your wallet may get a little slimmer, and you will be cursing the word dealership, but after all is said and done, you won't care. Your driving a DSM baby. That's all that matters. :grinyes:
