oil pressure gauge
97GSTspyder
08-19-2004, 06:02 AM
got my auto meter oil pressure gauge finally installed...now i'm asking a question about it because my knowledge on these things isn't too good. at idle it reads a little under 25. normally cruising around it'll vary from 50 - 75...when i'm at WOT it reads past 100 even though my gauge only goes to 100...just wondering if this was normal to be this high?
also, am i able to splice the stock oil pressure gauge into my new oil pressure gauge? i replaced the sending unit, and there is a wire running from it to the gauge...just wondering if i could splice my old gauge wire into that wire to have both gauges working.
thanks for the help
thanks for the help
kjewer1
08-19-2004, 07:21 PM
THats perfectly normal pressure.
I wouldnt run two guages off one sender. I Would use the aftermarket pressure guage on that port, and keep the idot light sender on the other port.
