Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Mitsubishi
Eclipse/Talon/Laser
> Eclipse Problem Diagnosis |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
blinkers quit 97 eagle talon
smoking black 99 gst w 6bolt
Engine Idle jumps from 1000rpms to 2000rpms, when parked, why!?
1996 eclipse electrical problems
Engine Cuts Out on HARD Right Turns
1997 eclipse gs hessitates and back fires
98 eclipse died
99 gs
1995 Eclipse Stalls
Put car on computer.
Hooking up halo's
94 Eclipse Interior lights
Idle issues
95 eagle talon MAP sensor problem
94 Eclipse Problems
Oil Pressure
Throttle closed switch
97 talon engine stalls randomly without dying altogether
95 eclipse 420a Lacks power at higher rpms (4500 and up)
tires question
FIAV plate
95 eclipse, stutters while accelerating more than half throttle
gst stumbles in second gear??? help
97 Eclipse Missing on 1 and 4
95 Eagle Talon Esi hesitates on throttling
blinker relay 99' GS-T?
flywheel an intercooler piping need help to fix it
Vacuum Problem
1998 Eclipse... No spark... HELP!!!
car wont stay running
Failing Starts
97 Ecllipse Non turbo Idle Problems!
93 Laser With GSX motor swap
90 eclipse gs computer
eclipse missfiring and stalling
1997 eclipse GST- Do I need a new engine?
My 96 eclipse problem. help PLEASE!
Some mystery on my 90 Talon Tsi AWD
mass airflow wireing
Trouble with 99 GST
m.a.p. sensor on a 420a
3500rpm limiter in gear only?????
94 talon mass airflow meter
93 Eclipse idles and stalls in gear; please help
noise in timing cover
99 gst smoking can you help?
Speedo died at 90 on freeway, can anyone help?
95 RS Tail light
1995 eagle talon problem.... no turbo
95 Talon Esi - Problem after replacing plugs and wires
SRS Light
Engine Problems!!
Gauges dropped engine died
Ignition is locked in lock posistion!
Where to find quality affordable engine mounts?
Bad Idle... Must be an idle motor problem ?
90 gsx crank turns but cams wont
Timing Belt has too much slack
98 Eclipse - High idle when car is moving
95 Eclipse GST 4g63t jdm swap
Cluster Issues
Drive belt main component? locking mechanism?
General RPM question, and Overdrive issue
antilock break light on 97 eclipse
Car wont start still and replaced the coil pack
91 GSX Problems. HELP!!!
1996 eclipse gst MT - no spark to cyl #2 and #3
Security problems
Need repair advise, please
97 standard with 99 automatic engine
gsx cutting out?
Only runs with key in the START position
95 eclipse gs blue smoke won't start
91 AWD GSX Dead Injectors ,cpu or ??
fuel pump fuse
93 eclipse GS problem need help
12v ignition source
Excess fuel
Intake Flutter
diagnosis?
Convertibe bracket busted!
Convertible roof leaks at corners. 99 GST Spyder.
Really weird idle problem when car is in motion
Cant go over 90 in 4th gear
Question about a 97 eclipse
relay switch
Please Use Descriptive Thread Titles
Help
car wont start only getting spark at 2 plugs??
split second tuning
Pulled the motor...again
Mmcd logging problem?!?
not sure if its anything but..
ecu help
Pal's problem any insights
eclipse gst shaking problem
420a 2500-3500 Miss Under Load
97' eclipse Exhaust problems!!
99 Eclipse Eclectrical Problems
Cavy's angry and getting hot... :(
96 eclipse engine problem
1990 TSI Talon
CEL + Code P0170 = Guzzling Gas?
o2 sensor wires
im back on the forums
car hiccups
turn signal/hazard flasher
Very odd oil leak and very low pressure. HELP!
emissons failed HELP!
94' Eagle Talon help please
extreme EGT
think i have a serious problem
92 eagle awd need some help
93 Mitsubishi Eclipse
GS in Snow
Clicking When Shifting Gears???
420A hesitates under load
1998 Mits. Eclipse RS Turn Signal Stays On
idle issue
fuel problem
95 elcipse electrical timing
Ignition Coil
1992 Eclipse
91 eagle talon, high idle, tranny stuck in 4'th
90 TSI AWD turns over no hit?
92 talon tsi awd, starts&dies horrible misfire
'96 Eclispe downshifting and dying
96 RS Consistant Problems, can't find the source
trouble starting on a cold start
Drivebelt won't stay on
1991 1.8 eclips no spark
Alternator upgrade?
95 gsx trouble starting
valves
bad hesitation turbo car
1990 Eclipse GSX help
1990 gsx that won fire.
1990 gsx o fie.
98 RS Start Issue
My Convertable top leaks
Oil in Boost Gauge Hose
Noise Filter
oil leak and low oil pressure at idle
slave bleeding problems
Please Help 92' Eagle TSi AWD
1990 eclipse fuel wiring problem
96 talon flywheel problem
'92 Eagle Talon TSi AWD Idle Problem
95 eclipse rs wont idle and hit rev limiter at 3500
96 Spyder starts then shuts off
93 eclipse wont start
96` no heat....
90 laser gst starts then dies. troubleshoot
injectors problems please help
96 Eclipse RS Start issue *Paniced*
Idle Bounces 0-1200
94 Eclipse no sparks
1996 Talon Cylinder Head
1995 ecpilse GS Crazy problem need help with
1990 gsx
Water Pump Problem (NOT SURE) EMERGENCY
Stuck Timing Belt????
Problem with gas gauge.
1996 Eclipse Blowing Engine Fuse
Oil Pressure Light
manual window to power window swap
92 Eagle Talon will not start HELP PLEASE!!!
replaced MAF but still getting code?
rear lights stay on
car runs bad
Car not running well
need a little advice
Jerking when accelerating slowly
Electrical fan problem?
White smoke and no spool up
Remote mirrors will not work
Popping in front end
light comes on while taking turns
2nd gen gsx
speed sensor a
The Push Starting Woes need help to fix problem
Car runs bad
Quick Wiring Question
Leaks
revs at idle
To High Fuel Pressure
running problems.
water pump
1993 eclipse 1.8 L no spark
Went on Road Trip, now feels sluggish at high rpms in 1st
Lock Jammed for convertible trunk release lever
problem with boost and tranny
Oil pressure
No power at all and a weird idle...
1995 Eclipse wont run
engine nock
1992 Eclipse non Turbo cranks and has spark but won't start
logger results help 1st thru 3rd gear pulls
Turbo about to take a crap?
Tach not working, Hard shifting, And oil in the plug wells
HELP: cant fix the CEL light
how to use afc controller
No power to the CAS on a 91 talon.
I know this does not belong here but HELP LOL 96 cavalier
Mitsubishi eclipse 97 stutters and shuts off help :(?
2g Coil Question????
1995 TAlon TSI: Stalls when warmed up
02 sensor location
vss
95 eclipse rs, ready to trash it..........
90 eclipse 1.8L: ecu fried need help
late start
Eclipse Gst Not Firing
eclipse acting wierd
94 Eclipse problems - engine light, rough idle & dies when A/C is on, loud rattling
Yay for electrical!
Clutch problem
oil leak when starting
Gaah friggin B-Joint
Running Hot
Slave Cylinder? possibly??
Preventing hydrolock
My car is sick some advice please
Smoke from exhaust while idling and Check Engine Light
Have to jump every start. Closer...
Issues Continue with my 1996 cirrus!! Open for answers!!
Hopefully my head isn't warped.
Sunroof STILL leaks
Hydrolock Aftermath?
95 Altima keeps stalling.
starting issues
Electrical Issue: Battery or Alternator or ...?
random stuttering at 3000 rpms
shifting and brake problems
Wtf???
Turboed my 88 Dodge Dakota, problems!!
Replacing O2 sensor... super fun!
Throttle position sensor
Do Eclipses break easily?
91 talon tsi no boost after findind heater hose sliced
Trouble Shooting my talon
I had no idea where to put this, 1996 chrysler cirrus help plz
timing job done: idle acting up!
Tranny sticking & wont idle
Check engine!!!?!?
wheel bearing
Bad case of clutch slip - 97 Eclipse
20 psi??
clicking coming from engine!
Still running very rich.
Web
AF
