gsx cutting out?badgsx 03-23-2009, 11:59 AM Okay so i just finished building my 97 gsx with a 90 6bolt i have low comp pistons 20g turbo 660injectors fuel pres reg 272 cams. I took it out today and 1st gear cuts out at 4500rpm and no boost will build. 2nd gear starts to build boost up to about 15 car shakes and cuts out at 4500rpm.3rd gear and up build boost and then starts to shake and cut out at 4500-5000rpm i dont have my speed sensor in at the moment just put in a new zoom cluth and aluminum fly wheel can someone please help me! haha SilvrEclipse 03-23-2009, 12:04 PM Do you have a CEL? Maybe you should wait and put your speed sensor in and see if that helps. badgsx 03-23-2009, 12:16 PM Yes it showing o2 heater circuit bank 1 sensor 2 code p0141 SilvrEclipse 03-23-2009, 12:19 PM That shouldn't be heating anything. Does the car rev past 4.5k when driving it easier. Have you checked for boost leaks? What are you using to control those injectors? badgsx 03-23-2009, 12:21 PM i have a stock fuel rail with a regulator badgsx 03-23-2009, 12:25 PM I have 680cc injectors and just a fuel pressure regulator SilvrEclipse 03-23-2009, 12:28 PM Im talking engine management. You cant just throw in big injectors and expect the stock ECU to control them properly. badgsx 03-23-2009, 12:36 PM dsm link v2 NateS 03-23-2009, 03:14 PM Sounds like a boost leak to me. Do a boost leak test. Even if its not your problem its a good thing to check. badgsx 03-23-2009, 05:33 PM there isnt a boost leak anywhere thats the thing i relooked at everything could it just be the speed sensor? SilvrEclipse 03-23-2009, 06:13 PM Its possible. I dont know if the stock ECU uses it for anything of not. Does the car rev past 4500rpms if you drive easy? Blackcrow64 03-23-2009, 07:18 PM Whats your fuel pressure set to? Definitely sounds like its running out of fuel... badgsx 04-05-2009, 02:53 PM My fpr is set at 40 psi i just talk to someguy that said i might need a wideband? LandoAWD 04-06-2009, 11:29 AM What type of plugs and wires? What are the plugs gapped to? What does link show for A/F through the logs? How is your fuel set up in Link? Automotive Network, Inc., Copyright ©2013
