98 eclipse gst no sparkk1999to20 12-19-2011, 05:25 PM I just replace the motor in the car and was trying to start it today. The car just turns over but will not crank. I did the spark test and found out that its not getting any spark. I don't know what to do, I check all the plugs and make sure I have in the right place. I don't know if I could have a ground off or I need to replace the coil. steviek 12-20-2011, 02:16 PM coil pack is your first place to start. Check to see it is getting voltage. We will go from there if thats a nope. k1999to20 12-20-2011, 02:20 PM well I did the ohms test on the coil pack and it checks out fine where do I go from there? steviek 12-21-2011, 08:37 AM Well if the coil pack is getting voltage then there's really no reason why the sparks shouldn't be firing at all unless you have bad wires. Are you getting voltage when you crank the car? How did you test to see if you weren't getting spark? SilvrEclipse 12-21-2011, 06:31 PM You can check the transistor pack Automotive Network, Inc., Copyright ©2013
