93 Eclipse idles and stalls in gear; please helpw_cohen 06-21-2009, 08:50 PM I have a 1993 Eclipse 1.8L SOHC and although it idles fine when not in gear, it almost always idles so low while in Drive gear that it stalls out. How can I increase the idle while in gear so that it won't stall out? Is this a simple carburetor adjustment or ???? Thanks. Walt chickmagnet 09-11-2009, 02:27 PM whats your rpm gauge read while idling, and is it an automatic? idle should be around 800 and if its stalling out when u put it in gear (if auto) then ur torque converter might be locking up...u might know all this already but i just thought id throw it out there seeing that ive had the same problem before. if thats not the case, well then good luck with whatever it is!! Automotive Network, Inc., Copyright ©2013
