3500rpm limiter in gear only?????biohazard50002 07-01-2009, 09:38 AM I got a 97 eclipse gsx automatic trans. When I put in drive, and floor it it goes to about 3000 to 3500 rpm and just bounces there and dont shift. When i release the gas it will shift. Hit the gas again and go up to the same rpm and does it again. put in new plugs, wires, tps, cam angle sensor, and still no change and there is no codes. i have a $3,500 snap-on modis scan tool and i cant find anything wrong on the live data. i cant figure out anything, anyone have any ideas. PLEASE HELP!!!!!!!!!! Blackcrow64 07-01-2009, 10:56 AM Change your tranny fluid and filter. That should straighten it up. If not then you could be lookin at a problem with your torque converter or TCU. SilvrEclipse 07-01-2009, 11:20 AM How does it drive when driving it easy. Will it shift fine then? Does this problem only occur when boosting? jsaviour84 10-18-2009, 04:02 PM I'm also having the same issue, did you find out what it was? Automotive Network, Inc., Copyright ©2013
