View Full Version : '91 - '96
Pages : 1 [2] 3 4 5
  1. Help
  2. Distributor Cap Keeps Carboning Up
  3. 92 Jetta starter issues Version 2.0
  4. check engine light
  5. 95 jetta transmission shift problems
  6. Engine Build!
  7. Head removal
  8. No Heat :(
  9. Speedo and Tach
  10. 1994 Jeta III
  11. Need Help!
  12. MkIII Jetta Auto Trans
  13. Valve Cover gasket
  14. FYI on blinker problem
  15. car buying help sought
  16. 94 jetta stereo wiring
  17. 96 Jetta GL clutch cable
  18. lights flickering
  19. 96 jetta problem????
  20. 1991 jetta idle issue?
  21. 1996 jetta starting problems
  22. NA left fog light cover - help!!!!
  23. coolant leaking.....
  24. Cruise Control Problems
  25. Misfires - 2000 Jetta
  26. torque steer
  27. Transmission Problems
  28. Transmission Selector Lever Display will not light up
  29. Transmission problems!!!!!!!!!
  30. 95 jetta jerking need help!
  31. Selling shot 96 Jetta III GLS, needs engine
  32. exhaust bolts--catalytic converter
  33. just got a jetta and got a couple problems
  34. Head foglight and side markers
  35. 95 Jetta III Not Starting
  36. Jetta window/alarm
  37. 93 Jetta stuttering while driving and sometimes gas smell
  38. Runnin rich
  39. 95 jetta bucking and hesitating
  40. 4 codes to fix
  41. Oil pressure warning in 95 jetta
  42. 94
  43. Jetta Mk Iii Rear Bumper Brackets!!!!!!!!!!
  44. Anyone up to the challenge?
  45. Reset computer?
  46. transmission problems help please
  47. Volkswagen Jetta MK III/ Golf 3 front bumper
  48. 96 Jetta, has spark,gas,compression - but no start
  49. Jetta is acting up. HELP!!
  50. German Guy Needs Help With His Us Jetta!!!
  51. Jetta 96 tranny and overheating problem.......Help please
  52. 96 Jetta Electrical Problem turn Signals/Brake lights
  53. Front Door Speaker Wires
  54. 94 Jetta Transmission Trouble
  55. 94 jetta transmission trouble
  56. 1994 hard start, hard idle
  57. jetta '96 gls starting problems. HELP........!!!!!!!!
  58. 96 Jetta DTC error code P1613
  59. I need a VR6 jetta real bad
  60. blinkers
  61. 92 jetta rotor cap clips
  62. Won't hot start!!
  63. 95 jetta gl wont start with key
  64. R-134a pressure on conversion
  65. 96 Jetta will only run while I spray carb cleaner
  66. Parts for sale
  67. 93 Jetta Starting Problems, Not a car person
  68. 94' VW JettaIII GL AT
  69. speedo/instrument cluster question
  70. 95 jetta --HELP !!!
  71. we need help please!! 96' jetta trek
  72. Thermostat replacement
  73. Interference engine?
  74. Location of ecu on 95 jetta gl
  75. 92 jetta with no spark
  76. '96 Jetta GL Clutch replacment...how difficult?
  77. 1996 Jetta A/C Loud
  78. 91 jetta gl ac problems
  79. Ignition Problem
  80. Looking for statistics on a 96 Jetta
  81. Gas guage inop....
  82. 94 Jetta, series of problems
  83. '92 Jetta-Timing belt change now high rev: HELP!!!
  84. 95 Jetta Radio
  85. Speaker Wiring.
  86. jetta 1.8 '92
  87. Location of cruise module - 96 Jetta
  88. Wanted:91-96 Jetta
  89. 96 Jetta A/C problems
  90. 95 Jetta relays and wiring nightmares. Please help.
  91. 96 Jetta alarm trouble
  92. noob: pics of my cars....
  93. 92 Jetta clutch
  94. 92 Jetta irregular idle
  95. 92 Jetta starter problem
  96. Oil leak
  97. help me help a friend shifting problems
  98. How do i get the crank handle off?
  99. 1995 Jetta VR6 Pouring Out Antifreeze...
  100. alram arming it's self after 2 minutes
  101. '96 Jetta TREK, Stereo Help
  102. Vibrations 96 Jetta
  103. where is OBD port on 1996 jetta 2.0?
  104. 96 Jetta Broken Door Latches
  105. Diverters for heater core box
  106. dash lights don't work. any ideas?
  107. upgrades for the 2.0
  108. Flowmaster muffler 50 series for 93-97 vw Jetta
  109. 91 jetta wont fire
  110. 96 Jetta, Can't find OBDll plug
  111. 94 GLS Won't Start
  112. 96 Jetta radio
  113. Oil light on 91 jetta
  114. blinkers stop working when i step on the brake
  115. seat belt light on?
  116. water in trunk
  117. 96 jetta III 2.0, whana go fast to the drags
  118. TPS Throtle Position Sensor
  119. Exhuast System-- I am replacing it
  120. 1994 antifreeze leaking
  121. will not crank
  122. How to get codes?
  123. 94 Jetta starting problems pls advise
  124. Window cables
  125. Vacuum Pump
  126. got my jetta but...
  127. Very longt time to lock Vento -93
  128. Corrado engine in a 95 jetta
  129. 96 starter
  130. 95 vr6 power loss
  131. 94 JETTA - electrical help needed!!
  132. 94 JETTA - electrical help needed!!
  133. Don't run without oil
  134. 94 jetta power windows
  135. honking horn dead battery
  136. clicking in reverse
  137. 96 jetta. Buzzing Hazard switch
  138. 95 jetta need expert help
  139. Performance
  140. 92' Jetta...I'm ready to fix it but I need your help
  141. '96 No power >40mph
  142. 96 jetta drum brakes
  143. is it worth getting a vr6 with manual trans in my 96 jetta
  144. ungo alarm system
  145. Stereo Codes
  146. Diesel 1994 Jetta GL NO-START
  147. Diesel 1994 Jetta GL
  148. just bought a 92 jetta
  149. 96 Jetta Cat. Conv. part #
  150. 96 jetta rain problems
  151. fan coming on too late / idle speed and shaking
  152. '92 Jetta's
  153. gas tank
  154. 2001 Jetta check coolant warning light
  155. '91 Jetta diesel overheating
  156. Need Direction - 95 jetta
  157. 1994 Jetta cranks but will not start update.
  158. 96 jetta 2.0 dummping to much gas at high rpm's
  159. 1994 Jetta cranks but will not start
  160. tach/speedo intermitantly not working
  161. 91 Jetta 16V, bucking at low RPM
  162. car dont start in bad weather
  163. car alarm!!
  164. 94 volkswagon jetta
  165. 1995 vento
  166. 92 Jetta won't start wont' crank
  167. 96 jetta wont start, after extensive work
  168. tranny problems in 95 jetta III
  169. Heater core
  170. fuel injector cleaner
  171. Jetta Trek '96 idling high
  172. 96 Jetta Gls Electric Problem
  173. Hello BOSCHMANN
  174. 95 Jetta problems?
  175. Jetta Won't shut off
  176. 1994 jetta electrical
  177. MAF and Fuel Injectors
  178. 1992 Jetta - Idle and intermittent stumbling
  179. about to buy a 2.0 1996 jetta
  180. Sudden Valve Cover Leakage
  181. Ignition Coils
  182. 1991 jetta thermostat
  183. Fuel pump relay
  184. Help!! 96 jetta 2.0 no start problem
  185. Need help for '96 Jetta, 2.0L, with overheating problem.
  186. Newbie needs help with bucking '92 Jetta
  187. 95 Jetta intermittent run rough
  188. 95 Jetta-III Questions
  189. 95 Windshield Wiper Switch / MFA
  190. Jetta transmission conversion help
  191. VW tools??????
  192. 93 Jetta GL Relays
  193. Questions
  194. 94 jetta wipers stopped burnt smell in interior
  195. Help! 1996 Jetta won't start
  196. 96 Jetta Trek Starting Problems
  197. HELP - Can oil buildup in the intake/MAF/air cleaner cause rich running when cold?
  198. Problems w/the alarm 1996 Jetta
  199. 96 Jetta Stalling
  200. Tranny Linkage Cable
  201. Where to find aftermarket parts for a 96 jetta gls?
  202. 1996 Jetta Not Starting
  203. 1996 Jetta Not Starting
  204. 1995 jetta electrical problem
  205. car won't start because of alarm
  206. mechanics in NYC Tristate
  207. Window Cables / Motor
  208. Fun upgrades
  209. '94 Jetta Fuel Consumption!
  210. '94 Jetta III Gl 2.0 5 spd problem
  211. Engine runs only 2 seconds
  212. 96 Trek horn
  213. 96 Jetta 2.0l GL emissions/blowing
  214. hesitation, bucking at slow speeds
  215. Anti theft code number
  216. ABS Light
  217. thermostat
  218. 1995 Jetta celebration
  219. Check engine light on/off
  220. ignition switch replacement
  221. vr6 tranny
  222. HELP!95 jetta won't start after small fire/mechanic ripped me off
  223. need advise on buying rims
  224. '95 JettaIII GL engine lock
  225. car with issues
  226. Jetta Check Engine Light Keeps coming back on
  227. Audio Question
  228. hopefully easy ? about seatbelt.
  229. transmission
  230. '99 Jetta GLS Alarm
  231. broken drive side lock
  232. Oil Light
  233. timing problems
  234. p0341 crank position sensor error
  235. Please Help with 96 Jetta starting Prblm...
  236. 94' Jetta Gl problem
  237. Radio code car is too old...
  238. Remote start wirings?
  239. '96 Jetta AT slow shifting
  240. Dashboard light
  241. 94 jetta overheatng
  242. car cranks but does not start
  243. Oil leak question???
  244. front end alignment
  245. can't start after changing battery
  246. 95 Jetta Starting Problem
  247. Ask Doug Tatham...?
  248. Recall Information
  249. Jetta Car Memory
  250. Motor Noise... Where's It Coming From?
