View Full Version : '91 - '96
Pages : 1 2 3 [4] 5
  1. 96 Jetta GLS stoplights alsways on-brake pedal switch OK
  2. MAF cleaning Procedure
  3. Corrado Spoiler
  4. Idle Air Control Valve
  5. 92 Jetta stalling when splashed underneath
  6. Water pump leaking, easy job to replace?
  7. !996 jetta can't start
  8. Vapor Canister
  9. motor swap
  10. 95 jetta loss of power
  11. Tires
  12. Tune Up?
  13. '96 Jetta 2.0 Turns over but won't start
  14. CD player
  15. 95 jetta wierd
  16. looking for aftermarket parts Gl/GLS/Vento/Trek/Gt
  17. 93 jetta gl
  18. Relay Layout
  19. 96' jetta gl acceleration loss
  20. Radio In Safe Mode
  21. 94 Jetta stalling problem
  22. V and Serpentine belts, 96 JEtta GL 2.0
  23. Where is the throttle valve?
  24. Ignition switch is toast
  25. 96 2.0 jetta won't start
  26. 96 Jetta GL Fuel pump fuse blows after 5 minutes
  27. 96 Jetta Hoses
  28. MK3 power mirror wiring diagram
  29. Rally Jetta!
  30. 1996 Jetta tranny swap questions
  31. stuck on starter removal 91 auto...
  32. 95 Jetta overheated today
  33. oil
  34. 1992 Jetta problems
  35. Fan won't stop (92 Jetta)
  36. heat shield
  37. Crank Sensor?
  38. help! car starts only with foot on gas
  39. 95 jetta lll check engine light under 3500 RPM
  40. need 96 Jetta help fasttt
  41. HELP!!! Dead car
  42. 92 jetta won't start
  43. advice on repairs
  44. How to remove door panel
  45. 96 Jetta brakes
  46. 96 Jetta stops working after 5mins
  47. '95 Jetta III GL won't start now
  48. 95 Jetta car alarm problems
  49. 94 Jetta Surges and spuders on acelleration
  50. Blinking Temp Light
  51. Heated Seats
  52. Signal Light
  53. single wiper at home modification..
  54. Starting Problems; 91 jetta.
  55. from 90 deisel to to 91 1.8 having tranny issues with cluth
  56. Turbo
  57. which muffler? [+pic]
  58. 95 Jetta III idle problem & missing once warm
  59. Help my jetta runs but lacks top end
  60. u-clamps that hold the front steering
  61. 96 Jetta Trek-CEL,Vacuum Prob??
  62. 1996 Jetta Trek Broken hood release cable
  63. '92 engine swap?
  64. 95 jetta stumbles going down the road
  65. 1994 jetta wiper problems
  66. dash lights
  67. broken glass
  68. 95 Jetta NO START!! Please HELP!!
  69. water engine
  70. pitted windshield
  71. help my 92 jetta wont run in the cold
  72. slipping clutch
  73. Help!!!
  74. Delayed start
  75. jetta new coil no spark
  76. Tricky Ignition
  77. Similar problem
  78. Technical questions, troubleshooting etc.
  79. 1996 Jetta GL 2.0 sputtering/slow getting into gear
  80. Clicking suspension
  81. 94 Jetta GL issues (oil pressure light, alarm, gear lights, locking mechanism)
  82. What's In Your Sound System In Your Jetta??
  83. 1995 Jetta III Celebration Edition (A) Acceleration Issues
  84. 91 Jetta crazy idle...please help!
  85. 91 Jetta crazy idle...please help!
  86. clutch went out! Help
  87. Trouble starting '96 Jetta...electrical problems?
  88. 95 Jetta manual window crank removal
  89. 95 jetta startup problems
  90. 95 Jetta injectors
  91. Jetta starting problems when wet
  92. 95 jetta diese heater fan problem
  93. 95 Jetta GLS fuse diagram and interior lights problem
  94. 95 GLS with power window problem
  95. 1995 Jetta 2.0
  96. 96 Jetta wont start
  97. 1996 Jetta Rough Idle / Stalling
  98. 1996 Jetta GLS - Ignition coil
  99. Coilover question for 92 jetta
  100. 1995 Jetta
  101. 91 Jetta loss of power at highway speeds
  102. 95 jetta III doors
  103. OBD-II on 95-Jetta
  104. OBD-II on 95-Jetta
  105. 95 Jetta Timing Belt ?
  106. (please help) 1995 Jetta - Reading the Check Engine Codes
  107. 96 Jetta Engine light flickers
  108. 94 GL Problem
  109. (HELP PLEASE) 1996 VW Jetta (ROUGH IDLE)
  110. PLease help ME.Does My 1992 Jetta Rear Seat fold Down?
  111. Rear speaker wiring in 96 Jetta GLS
  112. 95 manual trany fo a 91 golf gaz motor's trany
  113. 94 Jetta transmission problems after engine swap
  114. 1995 jetta throttle problems?,check engine light(how do you read codes)?
  115. 95 jetta oil light
  116. 95 jetta speedo dosent work
  117. 95 Jetta Idle problem
  118. 1995 Jetta Warning Light Question, should be easy!
  119. 1994 JettaIII GL intermittant no start/stall
  120. 96 Jetta Trek leak
  121. 95 jetta overheating like crazy
  122. 95 brake light switch
  123. 95' jetta IIIGL burned out compressor clutch
  124. 1996 Jetta 2.0 GL Brakes Suck
  125. 95-97 Jetta 2.0 8v Turbo Project
  126. 96 Jetta A/C not working
  127. 95 Jetta III Issues
  128. 94 Jetta alarm problem
  129. changing suspension in a 95 jetta gl
  130. Help with 1995 factory floor mat color
  131. 1996 VW Jetta Cooling fan?
  132. Is it worth my time? and what site has a variety of 93-98 jetta body kits???
  133. radio display on 95 Jetta
  134. 96 jetta leaking in car
  135. 94 Jetta ignition problem, please help!!
  136. 94 Jetta Ignit. Coil help
  137. 92 jetta wont start after running
  138. 95 Jetta GLII 2.0/4 cyl A/C quit
  139. 95 Jetta Tranny Q's
  140. 96 Jetta Starter prob?
  141. 95 jetta III GLS question
  142. 1996 jETTA SUNROOF MALFUNCTIONING
  143. 95 jetta intermittant hesitation
  144. 91 Jetta won't start after replacing timing belt.
  145. 1996 VW Jetta 2.O GLS-Electrical
  146. 96 Jetta GLS antenna base needed..
  147. 1994 Jetta Gls problems
  148. Cooling fan problems 96 Jetta
  149. 96 Jetta Heater Core Help
  150. will a3 (93-98) fenders and body kit fin on A2 jetta?
  151. 92 jetta..no spark
  152. 91 jetta won't start, beginner needs help
  153. '94 Jetta temp light
  154. 94 Jetta Gls 2.0 stalls on Hiway
  155. 1995 Jetta III GL cold start problems
  156. 1994 Jetta Sputter
  157. 96 Jetta GLS Speedo Problem
  158. 1996 Jetta "Engine Check Light"
  159. 1995 Jetta won't Start
  160. 92 Jetta A/C HELP!
  161. 95 jetta vr6
  162. 16V for '94 2.0L
  163. 1995 factory speakers
  164. 96 Dome Light
  165. 96 Jetta need kelp
  166. 1996 Jetta GLS Feaky Electrical......
  167. 96 jetta trek cruise control
  168. 96 Jetta starter trouble
  169. '96 Jetta Brakes
  170. 1991 MK2 Jetta ECOdiesel for sale
  171. 91 turbo diesel stalls (starving for fuel?)
  172. 96 jetta CEL...?
  173. exhaust jetta 96 TREK
  174. FS: 1991 Jetta ECOdeisel in AZ
  175. Odometer on 1996 Jetta
  176. 94 Jetta Check Engine Light
  177. jetta 96 wiring switch starter
  178. Major Problems On My 1996 Jetta Trek- Need Advice
  179. Idle Problem 1995 Jetta III
  180. 1991 Jetta
  181. my 94 jetta has no spark/no fuel
  182. 96 Jetta 2.0
  183. 94 Jetta possible electrical problem help!
  184. 96 Idle Problem
  185. 96 jetta trek
  186. 96 Jetta Gls Engine Light
  187. 96 jetta won't start (fuel pump problem?)
  188. '96 Jetta Mass Airflow Sensor
  189. Wiper prob on 96 Jetta
  190. Any advice on replacing coolant pipe? '94 VR6
  191. Need Info for 96 Jetta Head Board Removal
  192. 95 Jetta Misfiring With Warm Temps
  193. 1996 jetta radio antitheft code
  194. 1994jettahelllllp!
  195. stock stereo removal 96 jetta
  196. 96 Jetta/Passat Recall 02V256000 - WHDK
  197. Jetta 1994 Starting problems
  198. 95 jetta fuel pump trouble ???
  199. '96 Radio Display bad AND needs to be reprogrammed!
  200. '96 For Sale $2,500
  201. 91 Jetta temp light, clutch problems...I need advice
  202. just got a 1991 diesel!!!
  203. *96 Jetta CHECK ENGINE LIGHT ON*
  204. 1994 Jetta GL Sunroof
  205. 95' Jetta Problems
  206. Help! Stereo probs. in my '96
  207. 94 jetta III tranmission problems
  208. 94 jetta heater fan
  209. 92 Jetta two electrical problems
  210. 1992 Jetta eratic Idle, loss of power, runs to rich
  211. '96 Jetta Oil light/beeping wont stop!!
  212. installing a new head unit for a 1994 vw jetta
  213. 96 jetta power windows!!!
  214. 91 jetta Hole in firewall?
  215. question for the early 90's jetta owners
  216. 92 jetta worth it?
  217. Buying a 95-96 VR6. I need opinions.
  218. 95' Jetta OBDI system
  219. 1994 Jetta acceleration hesitation - Bogging Down
  220. 94 automatic trans. question
  221. 94 Jetta 3
  222. 95' jetta clutch
  223. 95' jetta starting problems
  224. 96 jetta problems
  225. 94 jetta 2.0 Wiring diagram
  226. Help with my 95 jetta
  227. 1996 jetta
  228. 92 Jeeta dies after starting
  229. Buy a '95 Jetta.. or not?
  230. 94 Jetta, automatic -- Towing Technique
  231. Jetta III 95 Auto Tranny Only drives in 3rd...
  232. '91 Jetta ecu
  233. 1995 jetta Gl III to vr6 swap
  234. 1992 Jetta stall problem solution
  235. 94 Jetta GL Dash Lights Not Working!!
  236. 1995 Jetta sunroof
  237. Jetta 92 dashlight and AC
  238. 94 with problems
  239. 96 VR6 OBDII 50K miles Motor 4Sale
  240. 91 Jetta Starting Problems -HELP!!!!
  241. Alternator Probs 96 jetta
  242. 1991 Diesel Jetta 2dr questions...
  243. 96' Vw
  244. 96 jetta automatic trans help!
  245. 1994 Jetta Check Engine Light!
  246. 1994 Jetta GLS Dashboard lights, radio and A/C fan won't work!
  247. 95 jetta check engine light codes
  248. What do you think about a '95 Jetta?
  249. Erratic idle in 1995 Jetta, help?
  250. Clutch slipping on 1995 Jetta
