View Full Version : Durango
Pages : 1 2 3 [4] 5 6
  1. reverse humming
  2. 2001 Durango engine service light
  3. 98 Durango Stalling
  4. Clutch Fan vs. Electric Fan
  5. 98 D preventive maint.
  6. Replacing Ball Joints
  7. A Little RANT about Dodge - and other
  8. Oil Use 01 vs 99 tsb - please help?
  9. turn signals
  10. 2001 5.9 using oil ???? - what's acceptable?
  11. 98 SLT 4x4 Slipping Trans When Cold
  12. 2001 Durango 5.9
  13. Water on floorboard
  14. door speakers
  15. Loud humming/roar in rear end at hwy speeds
  16. Is a solid axle swap for a 2000 Durango possible?
  17. Bjoint recall
  18. Power windows
  19. '99 5.2 D w/ #5 & #6 Misfire! HELP!!!
  20. 2005 Durango Water taken into Hemi Engine
  21. 1999 durango 5.2 cranks over fine wont start
  22. 99 d radio harness ?
  23. Heater Problems
  24. Fuel Pump Failure
  25. Help diagnose Humming noise problem
  26. 2000 Durango - Transfer case leak
  27. 2001 durango engine light P0051
  28. 99d 75mph vibration
  29. 99 durango need help
  30. 99 durango overhead console
  31. Security light flashes
  32. leaking transmission
  33. Rear Control PLEASE HELP
  34. Durango start issue
  35. 2002 Dodge Durango Clicks on Acceleration
  36. AWD 4WD to 2WD
  37. Winter Chains
  38. tranny
  39. looking for side nameplate for a 2000 dodge durango
  40. 2000 durango code p0320/ frustrated
  41. 98 durango shift indicator
  42. 2000 durango power locks
  43. Air Conditioning problems w/2002 Durango
  44. what's with the brakes?
  45. 2000 4.7 cold Trans
  46. '98 Durango headlight problems
  47. 2002 Dodge Durango
  48. starter removal 99 4x4
  49. 2000 Durango transmission
  50. meaning of Obd codes 0720 and 1368
  51. Code P0551, anyone else get this?
  52. resistor pack
  53. 01 durango PS leak
  54. help electrical problems
  55. 2000 durango power lock blowing fuse
  56. Moving stuff from one 2002 durango to another
  57. 2000 Durango Floor Heat
  58. About to Buy 2002 Durango
  59. 88 Durango with problems shifting to gear
  60. Headliner
  61. Wind noise
  62. 99 4x4 5.9L Rear Differential
  63. creaking noise front end
  64. engine oil type?
  65. Lifter noise
  66. 99 Durango stalled, now it won't start!
  67. PLEASE HELP-99 Durango TPS and Rear Rubbing Noise
  68. 98 Durango turns off as soon as I accelerte or reverse
  69. GPS 02' Durango
  70. Disk or Drum
  71. Dodge Durango SXT Gauge upgrade How To
  72. 2001 Durango - Headlights blink
  73. check engine light, code P1687
  74. moisture
  75. Front Body Mount Bolts
  76. help my radiator petcock is dripping.
  77. Intake gasket R&R how do I disconnect my fuel line
  78. no bus; check engine
  79. Help with 00 Durango Rear Brakes
  80. FS: 98 durango SLT plus w/ 87k miles
  81. Durango Error Codes
  82. Bad intake gasket, If I fix it will I get better MPG
  83. Transmission ?
  84. overheating
  85. Check Engine Light
  86. Check Engine light, ABS light, brake light
  87. 99 Durango - rubbing brakes
  88. ABS & Brake Light (Beating a Dead Horse)
  89. Ut-oh. Cold weather, there goes the idle
  90. Error code 1491
  91. acting crazy
  92. Replacing Thermostat on Durango
  93. Recallls
  94. 02' Durango SLT
  95. Door latches
  96. 2001 Durango Fuel Smell? After Starting?
  97. Engine Light and P0700 Code
  98. 2000 Durango/No speedometer, chk engine light, ABS light
  99. Creaking Noise
  100. 2005 Durango w/Hemi
  101. 2005 Durango Factory Remote Start
  102. 02 durango power Outage help!!!
  103. Durango PCM source that's cheaper.
  104. Super Charger
  105. code 320
  106. Need help- Dealership is stumped
  107. 99 Durango 5.9
  108. Wanting to buy Durango
  109. Keypad entry?
  110. Missing when idling???
  111. Rear Wheel Well Liner Removal?
  112. Durango stalls - It's in th UK and I'm in Qatar
  113. mp3 PLAYER
  114. Side Window Seal Replacement???
  115. ni turn signals
  116. ABS and Brake light stays on
  117. oil going bye bye
  118. Flashers and blinkers not working, replace flasher box?
  119. Front Blower Motor Not Working?????
  120. 20" rims and tires 4x4
  121. 2001 Durango R/T Power Outlet Problems
  122. Durango is loud and I think the engine is blown
  123. Help!! Rear Brakes Locking Up!
  124. Can I fix this P0601 code?
  125. What is P 0601?
  126. Drivers seat rocking
  127. 2001 Durango A/C works only on rear
  128. What battery for key fob?
  129. 2000 D acting up (again)
  130. New to this forum??
  131. Problem With Durango Vents
  132. Speed sensor
  133. 99 Durango power window problem
  134. overheating
  135. Durango A/C Question
  136. 4.7 Idle Air Control Valve or Throttle position sensor
  137. Installing Trailer Brake Under Dash Need Help!
  138. Popping Noise while making turns.
  139. 2000 slt A/C not working properly, blows warm air
  140. Overheating
  141. Power door locks problems
  142. Durango power locks problem
  143. help?? engine shut downs
  144. harmonic balancer removal?
  145. RE: 2003 D Computer reset?
  146. EVAP Problem
  147. A/C condenser removal?
  148. How to remove center console?
  149. a/c problems
  150. vibration while towing durango
  151. AIT relocation... in question
  152. 04 key and remote
  153. Replacement Speakers
  154. 2000 Durango - Error 1491
  155. 2000 durango
  156. Error code 1388
  157. 2003 Durango Overheat problem
  158. dome light flashes with emer. flashers
  159. specs
  160. 99 radiator fan problem, engine kill
  161. 03 5.8 Plenum air fitting Q
  162. What's the problem?
  163. Motor RPM's high shifting 1st/2nd/3rd
  164. Desperate Help for my 2001 Durango
  165. Blower resister on 98?
  166. 98 Gauges jump around with key ont of ignition
  167. Thinking about buying a '99
  168. Crazy Gas Gauge
  169. Where to mount trans. oil cooler
  170. Transmission cooler
  171. Durango Broken into, need new steering column? Help me please!
  172. 5.2 to 5.9 engine swap? anyone done it yet?
  173. Need Keyless Entry (HELP?)
  174. Thermostat
  175. 2001 Durango Cruise Control
  176. engine code help
  177. '98 stalls in a hard turn
  178. purge solenoid valve
  179. Wrong trans fluid??
  180. 1999 Engine Light
  181. 2002 Durango SLT Acceleration Problem
  182. stupid durango want start
  183. service 4wd light
  184. 1999 Durango 5.9L stalling issue
  185. power windows on 1998
  186. 2003 Durango transmission service
  187. trouble code po720
  188. dome lights
  189. Check Engine Light
  190. AC Compressor kicking on and off?
  191. Water pump torque sequence and specs for 98
  192. check engine light on
  193. Love My Durango
  194. interior light fuse keeps blowing
  195. 4.7 gas mileage
  196. A/C about to go out?
  197. abs and brake light on after speaker upgrade, please help
  198. How to tell if recall work has been done.
  199. ball joint problem ????
  200. need advice
  201. Gauges Randomly Go Out, Warning Lights On
  202. power plug
  203. Windshield Washer fluid
  204. Tires Durango R/T
  205. 2004 Durango Limited Fuse Panel
  206. 99 dodge durange starter problems
  207. Vibration
  208. Dtc P0456
  209. Need help to find a wiring short
  210. Touble code po320 please help
  211. Ball Joints that can be serviced?
  212. Help with 2k Durango Please
  213. 4.7 surgeing
  214. 2001 Durango
  215. 2001 handling
  216. black dust?
  217. no pressure in cooling system
  218. 98 Dodge Durango died twice...
  219. 99 Durango High Speed Vibration
  220. 2003 Durango Whistling Noise
  221. engine lite
  222. throttle body sticcking
  223. 2000 Durango Major repairs?
  224. Cruise control
  225. 2001 Durango Ashtray -opens automatically
  226. Durango Seat heater does not work
  227. AC lines cut by Mopar nerf bars???
  228. 1999 Durango Running Strangely
  229. shift into overdrive very slow
  230. Accident, Blew Out Engine on 2000 Durango
  231. 2002 Dodge Durango is acting crazy
  232. 2004 Durango Limited - Loose Hubcaps
  233. 2002 Dodge Durango Problems
  234. Problems turning on '98 durango
  235. mod suggestions please
  236. lowered 2000 durango
  237. flush or not?
  238. Installing PCM for 1998 Durango
  239. Need an OBD Code confirmation
  240. Durango defrost problem
  241. 2001 Durango 4 Wheel Drive not working
  242. door lock not buzzing
  243. 2000 durango
  244. Help! Driver's side window question
  245. Help with tires!!
  246. Headlights turning yellow
  247. Keyless entry not working!!
  248. Trans. torque convertor
  249. 2000 durange lower ball joint replacement
  250. 2002 durango problem
