trouble code po720
coonrod70
05-05-2005, 11:15 AM
Ok folks, now I'm getting somewhere.....PO720 is the output low speed sensor circuit malfunction. Would it be safe to assume the sensor is bad or just something in the entire circuit, which could be anything?? Anyone out there have any experiences they would share on this trouble code? Again , there are no drivability issues as of yet. Can any one tell me where on the tranny this located? Thanks, Brian
rksnc
05-05-2005, 01:14 PM
The speed sensor is located on left bottom side of trans. There are test that can be done but the basic will be bad sensor, bad wiring to pcm, or bad pcm. If you have scan tool you can see if it is working.
coonrod70
05-05-2005, 05:09 PM
thanks for the info! I'll try replacing the sensor and see what happens.
DurangoDave
05-05-2005, 06:39 PM
There are two speed sensors, one on the tranny and one on the rear differential.
Dave
Dave
rksnc
05-05-2005, 06:50 PM
The speed sensor he wants is in left bottom side of trans. The one in rear differential is the abs speed sensor.
DurangoDave
05-05-2005, 08:39 PM
thanks! (I assume you know that's the one from the Code).
Dave
Dave
