Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
> Engineering/ Technical
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
parts after swap
Help with H23 swap
oil pressure....
PTS Shiftronic?
what cai do i use?
Just kinda wonering why you come in here.
DC sport CC headers worth the money?
oxygen sensor gone bad?
is this an indication of a transmission problem?
Supersprint
b18c1 swap JDM wiring?
Port & Polish on SOHC VTEC... gains?
Where to go to school to become an Auto Mechanic?
Anyone try the Tornado?
Bent connecting rod???
internals #deuce
brake pads
What does "stock" mean?
CTR pistons in my b18c1
fuel relay question
Torque steer vs understeer
Easiest way to run under under 13's in a civic
FYI: Group buy on engine swaps in group buy section!
spec needed
Bliker problem
motor mounts
f20c
Rotary Engines
What is the best ECU?
Turbo & High-Tech Performance
A h22 in a 3g civic
underdrive pulleys
LS-1 Motor block casting process??
"I need NAWS I need NAWS!!! (seriously, safe use of Nitrous)
HELP:A/F ratio meter in 92 civic
Octane #
dyno charts?
5th gen accord w/ H22A or 2nd gen Teg w/ b18C1
What is that site that shows the washer / bolt trick for camber?
Fritz, got one for you....ok two.
The Mixing Of Oils.
Am I paying too much for a new head+gasket?
N1 vs Racing Medalion
Port and Polish
b18 internals
'99 dx hatch w/ JRSC......my alternator/speed sensor fuse keeps popping......WHY?HELP
4th Gen B16 Swap
Correct Fuses To Reset ECU
jsm b20a5
How to be a good driver
'87
turbo prep...Crower Cams & Pistons?
PTC Receives $1 Million Order from Lamborghini
good tech info site?
flywheel installation cost
Walbro fuel pump problem
4th gen ignition upgrade!?!?!?
internals
b20 head swap
300zx Engine Transfer
17 flashes on ECU???
Civic HB Swap dilemma
Tuning an Apexi VAFC
Canada Swaps
computers necessary
Fuses??
Potential hybrid?
Wheel issue
Tanabe Racing Medalion
fuel injector leak, should i change myself?
Hondata
Whats Wrong wit my auto?
Turbo/Supercharger question
Engine Bay
300M engine into 94 Intrepid
Need Opinion
Jr Vpac
will a b16a2 work on a 90 civic si
Air Intake?
popping after clutch release.
Painting Ceramic Header
Other AF tech forums.
custom exhaust
H22A vs. F20B SIR-T
high compression
Timing belt is loose!
question on the f22b1
what is a good engine swaps for a 91 accord
auto to manual conversion for a 94 accord lx
New Honda Buyer
JDM B16A Aftermarket
Turbo theory
buying b18c1
Type-R mirrors
How much for I/H/E?
S/C B16a
97gsr with a 97 b16 head - will this do?
Need fast advice on buying an engine!!!!
Does JDM engines pass smog test
zc for a 92 + civic HB
b series
Computer Board (ECU Tweeking)
A/F Gauge Install
Longblock? Shortblock?
Boost Spikes
99 Civic EX - B18C Swap.. Questions???
Clutch Recomendations..............
Ecu??
Ecu??
Swap this Swap that.....
H22-B18c1-B16a2
Trans options for B16A JP VS USA spec
Lamborghini,Porsche,Ferrari & Alfa Romeo
build up... the most serious parts
Mugen for '99 Accord EX
Help me ...my car is dead!
B20 long block+b18c5 head=?
Tranny for LS??
aftermarket parts installation
a lil imput please
starting valve and hose #8 from pgm-fi on a 4th gen accord?
suspension questions
Whats the best swap for a 97 civic
Port and polish?
EGR on my 4th gen accord?
NEED help about parts for JDM front end!
vtec
fuel filter
tach install?
engine papers
B18c-r swap into 96-98 civic
Single Cam Mods...what should we do?
B16A2 into Civic 4spd
TECH: Switch for Reverse Indiglo Gauges?
ls/vtec how about a f22/vtec
HELP! How-To put a B18c1 into a 88-91 civic DX
problems due to aftermarket parts
I am In need of HELP!!!
I need HELP!!!
Usdm Gsr Swap
Cams??
LS help
5th gen b16A
Sorry..Mitsu question but I need help and that forum is slooooooooooow
AEM intakes
b16a into 97 Civic DX... Cost?
Check engine light
B16a wiring and shift linkage questions
Oil Burning?
how difficult is it...
Att: Moppie Jdm Bumper Lights
h22 in a 2000 civic
tune up question
accord tranny on an h23
Weird smell
Best Radar detector for the money?
Where did everyone get their swap
Need Help
b16a sir 1 vs. b16a sir 2
Compression Ratios....drift..your sarcasm welcome hehe
Swap in a Sedan
iVTEC & VTEC
History of Honda - Moppie? Fritz?
cadaletic converter
Brake Fluid Table
Brake Fluid Chart
Hey I've got a automatic transmission and i want to race with it....
ATT: Moppie JDM PARTS WANTED
airbag question
Exhaust
Brake Fluid
How good are JDM cams
Milling head good or bad?
Engines
H22a in 6th gen civic
b16a
Is JDM Engine Legal?
Will a B16 head fit on a D16 block?
B16A swap into 88-91 CRX
What can I use on the Si ?
91hb 4speed to 91 B16a 5 speed? quick question
Mods for New Type R
Cheap Supercharging
Crossed drilled/slotted rotors.
squeeling throwout bearing!!
Intriguing question for you tech nuts...
B16a Speedo cable to trans
wierd shifting stuff
Mods for Type R
ignition timing
Civic Type-R Motor
Question on Spark Plugs!!!
Just thought of a JDM mod that ive never seen on a USDM
Engine Weight?
driving a 5 speed
DC catbak exhaust
Gude head on
JDM steering wheel
questions about an 2000 hx
Accord Engine Swap? HELP!
smoke???
3rd generation accord weight?
ls buildup
cost for H22?
electomotive tech ll
too much fuel?
Is This Possible???
ZC common probs?
2nd gen B16?
Anybody have this???
B16 smog in Cali
reprogramming v-tec
Fram Oil Filters
what to check for?
Bore and Stroke
If I were to change my block...
engine mounts
distributor degrees (point dwell)
JDM front end conversion question
intercooler without turbo?
bumper light wiring
question on rotors
exhaust
Yo...Tech heads...shhhhh...V8 question...
JDM B16A to in a 92 hatch
quite exhaust
Engine not heating up?
Vtec
does VAFC affect motor stability?
Why VTEC???
knocking/pinging/ticking @ start up.
Air Intake Question....
Spiking Revs
JDM EF8 CRX question
Cable arm on swaps
distributor swap question!!
Shave me, baby!
B16a Ver 2
b18c swap in civic...turbo or na
coilover help 95 ex stabilizer bar
Mugen FG-360 steering wheel
inline fuel pump install
Anyone Please Help me with chip install
Apex-i Rev/Speed meter
What to do to my B16
steel braided radiator hose, anybody know where i can find...
Spoon needed
someone please tell me a link on a how-to clutch install for a 89 DX
SAFC Clarification
B16 engine needed
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
