View Full Version : Engineering/ Technical
  1. disks or tires?
  2. Need advice on building a 400+ Hp Chevy 350 race engine street / track
  3. What Frustrates you about having a mucle car?
  4. Running without an exhaust manifold or clutch
  5. Handbrake light wont turn off.....
  6. New Mopar Event
  7. New Mopar Event
  8. New Mopar Event
  9. Oops, it expoded.
  10. GM#491253 & GM#8869561 - Where can I purchase one?
  11. brake light and dashboard cleaning
  12. Problem with fuel dissappearing in car*urgent*
  13. 1970 AMX and Javelin differences please?
  14. Volvo Cars
  15. Auburn posi unit
  16. SBC: Edelbrock Torker I vs. Weiand 7546
  17. CVT transmissions.
  18. Remote start and key?
  19. Jeep Cherokee overheating
  20. 3.3 Oil Pump?
  21. will using this cause battery to explode?
  22. odd question on starting
  23. Need help with Battery
  24. Engine swap from 5.2to5.7 grand cherokee
  25. neon won't turn over
  26. Broken Plastic Ring on Fuel Injector
  27. more 93 sentra question w/video!
  28. how to test a distributor
  29. Fouled spark plugs
  30. air compressor
  31. low fuel pressure
  32. Chevy truck won't run---need help
  33. Can a ecu tune change the peak output of an engine
  34. Atkins cycle - Prius and the Lithium powered future
  35. My radar detector doesn't detect laser at each time
  36. Where I can find this repair manual?
  37. Corolla Head issues
  38. Coil Springs
  39. Performance Help
  40. Question about rust protection
  41. rusted exhuast
  42. lateral load transfer
  43. spark knock
  44. axle installation
  45. Removing Fender skirts
  46. Gravel scraper/grader/scoop trailer ???
  47. Exhaust system cost
  48. simulink model - source blocks
  49. Timing Chain?
  50. Speed, tractive force and rpm
  51. Long-term and Winter Storage Tips for vehicles.
  52. 588 piston rings v-12 build
  53. Questions about 69 Chevelle
  54. Smokey Engine
  55. Hid conversion kit
  56. Is my camshaft toast?? Performance issue!
  57. clutch test
  58. fuel additive/cleaner
  59. 10 thousand What to buy
  60. Whyrear wheel drives have better gradeability ???
  61. Tire and wheel selection
  62. Car shut off
  63. transmission question
  64. K&N Engine Air Filters - Worth It?
  65. Increase HP for '07 2.4L Solstice??
  66. Winter Care Tips For All Cars
  67. error codes
  68. looking for 4sp transmission for 77 camaro
  69. Turn signal stalk removal, GM steering column.
  70. 01 Elantra - Catalytic converter below efficiency
  71. Please Complete this Quick Survey
  72. Material for Chassis
  73. Timing chain
  74. what are those rims?
  75. Comparing Transmissions
  76. Will it work?
  77. a/t system malfunction.....HELP!
  78. Modify gas tank
  79. Timing Cover
  80. 1990 pathfinder SE automatic. Tranny issue
  81. how to seperate the trans from the engine
  82. taking the scenic route
  83. Recommendation Wanted: High torque rear end gears
  84. Building an engine.
  85. Cracked brake shoes
  86. Holley Carbs
  87. How to do spraypainting headlight designs
  88. a four sided nut
  89. How do i tell if I have a bad Harmonic Balancer
  90. ::::::::Is this a safe way to start my car::::::::::?
  91. HELP with 05 Tahoe
  92. How hot does styrofoam get before it gives off fumes or melts?
  93. oil
  94. less torque at high rpm's
  95. Using Toyota Wiring Diagram
  96. truck vs race car
  97. 2003 monte carlo
  98. Best Truck
  99. Electrical Fan Wiring...
  100. The antiroll bar
  101. '91 911 in storage, oil change questions
  102. rust issue
  103. 1997 F-150 4x4
  104. Secondhand Gems: Fast pickup trucks
  105. LED turn signal prob's AFTER load EQ install
  106. changing an engine
  107. Q jet throttle bushing repair
  108. 355 Project build
  109. help
  110. What is the Proper color for Gasoline?
  111. Brake Repair and Rotor question
  112. 2001 s10 transmission
  113. First post! - What do you recommend for painting?
  114. Fuel pump connector and Delphi vs AC Delco
  115. automotive engineering bible?!
  116. Crackle in the front suspension
  117. General Question about Error Code Readers
  118. yet another power steering question
  119. Exhaust Question
  120. Maual to Auto (Windows - Chev Cavalier), how-to-do?
  121. Turbo identifier??
  122. New video/new question
  123. Can anyone help ???
  124. question about 1965 gmc interchanges
  125. Engine knocking oil pressure flutter
  126. how to measure wheels
  127. another power steering question
  128. Question about buying a car security system
  129. 72 duster
  130. Clutch questions
  131. Suspension for my truck
  132. Shocks
  133. supercharger carbs
  134. selecting a 700r4 high performance trany
  135. custom engines
  136. 68 ford galaxie 500
  137. Ridiculous fuel mileage...
  138. How to increase horsepower?
  139. Need a new compressor 2003 Honda Accord
  140. rebuilt vs reconditioned transmission
  141. olds 350 heads
  142. back to the power steering pump
  143. Engine Swap
  144. selecting rear end gears
  145. torque converter solenoid
  146. Request for input
  147. Question about painting accessories in cars.
  148. Connecting LED Tail Lights
  149. Essential Electrical Systems
  150. Lowering Help.....
  151. Want to go Urethane On my Car but. . . .
  152. What's my problem (battery/alternator issues)?
  153. steering axle question/video
  154. Improve handling on old car
  155. axle hub nut question
  156. Your thoughts on this issue related to cruise control
  157. supercharged chevy 350 build
  158. cigerette lighter wiring question
  159. Brass unions in steel brake lines.
  160. A/C control unit too big, Replace?
  161. 3.4 motor swap
  162. transmission code
  163. Rewiring Question
  164. Cayman Islands - Tire Pressure Issue
  165. Exaust pipes for my F-150.
  166. Need to learn about Scanning with Autoxray 5000
  167. What is a good muffler to get?
  168. Ford 302 EFI flywheel.
  169. Benifits of oil filter relocation?
  170. mutiple questions involving changing an engine
  171. power steering pump
  172. Radio display is blinking.
  173. Diesel in a gas engine.
  174. Cruise Control adjustments?
  175. D Stroked 400Chev
  176. Header Bolts Vs. Studs
  177. power steering pump
  178. mustang project need advice
  179. cam duration
  180. Whats my Problem???
  181. Jumper cable question
  182. Wheelbase to Track width radio?
  183. Car Painting and sanding
  184. Car Security
  185. your opinion?
  186. 13" wide 18" rim tyre problem
  187. '96 bonneville windshield wiper motor
  188. What size fuse to use for a 4-port, DC Adapter?
  189. engine locked up
  190. Pulsating brakes..
  191. Fan belt comes off
  192. Car Lighting and HID
  193. engine swapping
  194. EFI Engines
  195. Engine bulb lights up for some days
  196. The knocking sound in engine is produced by which part?
  197. Best small pickup for...
  198. 3rd gear pop out
  199. Supercar design
  200. clutch question
  201. RPM vs speed vs torque
  202. Transmission thumping sound in forward gears
  203. !!! Any classic car unrestored!!! Click here
  204. Question about headlights
  205. car problems - PLEASE READ!!!
  206. Shop-Vac Turbo, WOULD IT WORK?
  207. Injector circuit open
  208. Jetta Diesel in a 70' Charger?
  209. built 400 problems
  210. Jump starting a car
  211. Brake line fittings
  212. 92 pathfinder overheats
  213. Overheating
  214. need tuning help with 06 corolla
  215. AC starts but no cold air blow out when engine is off
  216. The Official Automotive Artwork of Danny L Whitfield
  217. AMC artwork by Danny Whitfield,,
  218. Jugde my artwork please,
  219. 3'/4' JDM lowering kit
  220. transmission gurus
  221. Car shut off and won't start
  222. installing rear glass without weatherstripping?
  223. 4L30E Transmission
  224. questions that i would like answers to
  225. EXCELLENT Automotive Survey Site Mentioned on here
  226. My tranny is locked/jammed, I can't shift it out of gear. Help please!
  227. converting a V6 into V4
  228. PLEASE HELP! This is a life or death matter!
  229. Moderators please!!!!
  230. Steering torque
  231. Your Opinions: Caster Vs. SAI(kpi for the old-schoolers)
  232. 1980 firebird formula coolant leak, frost plug?
  233. machine shop question 3.1 gm
  234. Technical queries on tires
  235. Misfueling damage
  236. Fs: My stuff
  237. Is it.. the alternator?
  238. Re-promoting Adhesion On Double Sided Tape & Painted Metal
  239. Powder Coating
  240. Writer looking for quick fix engine problem
  241. URGENT!! Castrol GTX EVERYONE READ THIS!!!
  242. Ideas on GPS Tracking?
  243. Questions about car security
  244. More room, softer ride and better steering, is it possible?
  245. Question about rims
  246. 1998 Olds Intrigue - Radiator leaking
  247. Electric Power Steering Issues(Is This Common?)
  248. Engine Swap
  249. Painting The Rotor Hat
  250. Question about water pump tests
