View Full Version : Engineering/ Technical
  1. suspension settingsTEIN
  2. Pronunciation of Mugen
  3. Engine Swap
  4. best head for b20
  5. Good Engine Swap
  6. Engine stalled while charging AC
  7. Electronics Problem
  8. Rev limiter??? Distributor???
  9. VOTE for your favourite classic Aussie coupe!
  10. b16a SIR 1 in a 98 civic
  11. VOTE for you're favourite Aussie muscle car!
  12. Compression Test on DOHC Vtec engines
  13. Need help please
  14. CTR headlights bulb designations HELP
  15. Need help with my civic
  16. swaps in nj
  17. Help with a 73 duster!!!!!!!!!!!!!!
  18. need help please
  19. JDM Type R
  20. throttle body size?
  21. Convertible Top Repair Myself
  22. anyone know how to install coilovers on a 97 accord?
  23. trueth about magnets on air and fuel hoses?
  24. Which Valve Angle to grind
  25. RB20DET/SR20DET for my 2000 Civic
  26. Coil
  27. Car Wont Start
  28. H22a Swap Question?
  29. To Swap or not to Swap
  30. Is it worth it to fix up an '85?
  31. Q. on Shift Problem
  32. Help me go faster
  33. head gasket swap
  34. 99% Noobie
  35. C32b
  36. i need help with a new decision
  37. muscle car quick trivia
  38. Question for ctr engine owners
  39. civic header question
  40. Blow Off Valve required?
  41. my b20 vtec
  42. b16a idle bouncing once warm
  43. b16a idle problems bouncing when warm
  44. Wheel and Tire sizes
  45. If you are a 95 Civic EX owner you might/need to know
  46. got a question and i gotta know soon! Garrett TA-51 turbo
  47. Valve Lash???
  48. K20A2 stock cams
  49. Fuel Cell Car Performance Specs
  50. Need help with switches, LEDs and fuses ...
  51. Please Help!!
  52. The Best 60's Pontiacs
  53. Anyone ever buy an engine online??????
  54. Welcome MuscleCarClub.com
  55. Rb26dett
  56. Rb26dett
  57. Fuel Injector Life Expectency
  58. CRVtec
  59. ebay chips
  60. 1979 Buick Roadhawk
  61. Yenko Vega Stinger
  62. Cable vs. hydraulic tranny
  63. body differences between 96-98 civic &99-00 civic
  64. D16a1 Swap
  65. was up
  66. Quiafe LSD
  67. teggy compression
  68. Pantera owners?
  69. tuning recommendations
  70. I need help with this decision
  71. first car- exhaust
  72. Separating Type R Tranaxle from Engine Block
  73. Header for Crx w/B16A
  74. Welcome!
  75. Welcome!
  76. Welcome
  77. Welcome!
  78. Lsd
  79. North Carolina Emission Laws?
  80. What type of car do you have?
  81. Low fuel indicator light
  82. Welcome Pontiac muscle car fans!
  83. Welcome Plymouth muscle car fans!
  84. Welcome Oldsmobile muscle car fans!
  85. Welcome Mercury muscle car fans!
  86. Welcome Ford muscle car fans!
  87. Welcome Dodge muscle car fans!
  88. Welcome Chyrsler muscle car fans!
  89. Welcome Chevrolet muscle car fans!
  90. Welcome Buick fans!
  91. Welcome AMC muscle car fans!
  92. Welcome! (A message from the moderator)
  93. EDM B16A1 engine
  94. Electrical Issues/troubleshooting
  95. No posts?
  96. 1970 buick GSX
  97. Own a B16B too
  98. So many motors? but what should i do
  99. Which engine would you recommend?
  100. Which engine do u prefer?
  101. check engine light on hELP!
  102. Tranny Troubleshooting
  103. Regain Performance On Beat Up Engine and Trans
  104. what head to put on b20?
  105. D-series engine swap
  106. fuel pressure riser (stillen)
  107. quick start question
  108. Check This Out
  109. quick question about torque converters. . .
  110. Diff intakes
  111. H22 in Civic
  112. jdm engine dealers
  113. Question about KYB AGX Shocks & Struts
  114. Performane Chip Questions
  115. new driver, new car
  116. Air intake for Integra
  117. power steering fluid replacement
  118. Power steering
  119. b16 NA
  120. The TORNADO
  121. ZC compression
  122. Which b16 engine do you recommend for a 5th gen. civic?
  123. H22 Swap .... info needed
  124. Small Dent Removal
  125. Could you ?
  126. Moonroof
  127. how to remove door panel from a 92 civic for speaker installation????
  128. tranny
  129. information required
  130. Obd2 sample source code
  131. HKS Hiper Exhaust!
  132. possible bad alternator?
  133. 94 civic b18c5 swap?
  134. transmission swap from auto to manual????
  135. K20 Mugen ECU
  136. Drive axle question
  137. stripped altenator bots
  138. b20 turbo swap
  139. Need Suggestions on engine
  140. what's this noise i'm hearing??
  141. NAPA Exact Fit wiper blades
  142. engine width-wise
  143. Motor will not start.
  144. B18c into a 91 integra
  145. Need help passing MA emmissions test
  146. unorthodox racing Sc (street crank) pulley
  147. Problems with My 92 Cavalier
  148. b16a
  149. b16A3 or b18b1? Turbo or NA???????
  150. CE light after installing coldair intake
  151. Wastegates and BOV's
  152. adding horsepower
  153. 1 remote for multiple cars???Possible??
  154. my honda knocks more than I knock women
  155. info
  156. 90 Prelude motor swap
  157. engine swap for 91 integra rs
  158. Dual Ram air
  159. Jdm Front Integra
  160. where to get a civic si or gsr front clip
  161. installing side markers?
  162. i need a highly recommened site....
  163. b18c1 swap questions in a 5th gen civic
  164. new england tuner shops?
  165. what does octane booster do?
  166. catalyst - EURO2
  167. I had a wild idea
  168. JDM MAP Sensor
  169. jdm usdm?
  170. Engine Mod help.
  171. Need Transmission help
  172. Auto to stick swap
  173. Jdm Prelude
  174. torque converters
  175. Single Turbo on "V" engine...
  176. Transmission Question
  177. She's In!
  178. 2002 honda civic tach help
  179. ls/vtec
  180. B16A Help
  181. anyone with a crx with b16 in it?
  182. Injectors
  183. sport tuning suspension
  184. ignition problems
  185. Headlight Beam Adjustment
  186. Flush Radiator / Bleed Screws
  187. Grease fitting?
  188. Prelude
  189. SWAP FINALLY IN!!!! remember me from 3 months back!!!!
  190. b16a vs 94 LS
  191. obd2 software for pda
  192. Mini me question
  193. Is this clutch slipping?
  194. more power?
  195. yo guys i seriously need help w/ intake
  196. Summer Trailer towing with a 1992 Maxima SE
  197. DSM 450cc injectors into integra ls
  198. Gsr Performance
  199. emission law
  200. exhaust rattling! HELP!!!!
  201. Brakes Lights
  202. Engine for preludes
  203. Final Drive Gears for Cable tranny's????
  204. Help with engine code....
  205. Civic Cabriolet...???
  206. 3.2TL TypeS in a 2K Civic SE...Will it work?
  207. k20a swap
  208. I speared my convertible top
  209. Acceleration problems
  210. Direct Gas Injection
  211. gsr swap need help
  212. motor question..
  213. What does a B16B put down at the wheels?
  214. Newbie.....Help
  215. Clutch adjuster
  216. USDM vs JSM
  217. Exhaust dyno results
  218. B16B wiring harness
  219. Opinions neeed
  220. B16B wiring harness
  221. Starting engine for first time after parked 2 years
  222. N1 crank pulley
  223. I Just want a simple answer..What Kind Of CLUTCH do yall got??
  224. woohoooooo!
  225. h22a swap
  226. How can you tell if there was sugar in the gas tank?
  227. Whats Twin CAM?
  228. problems w/ jdm swap
  229. High Tech Suspensions systems
  230. engine swap
  231. Tubos and Superchargers
  232. Civic Got Towed
  233. Changing timing belt...
  234. edelbrock type-R throttle body.....
  235. For Sale B16B Type R engine + Tranny
  236. Any hope for a F22 engine?
  237. Blown Head Gasket? How to tell.
  238. Building Up A D16Y8
  239. B18C any good?
  240. car vibrations
  241. high-speed, high-power diesels
  242. drag tranny b series
  243. Tranny hybrid. Can this be done?
  244. timing belt/cover for DOHC ZC
  245. SKYLINE ENGINE into an MR2
  246. Wiring Harness Question
  247. What exactly is a B16
  248. new transmissions
  249. Need info on rhd conversion for my ek b16b hatch
  250. newbee question on H22A engines
