View Full Version : Engineering/ Technical
  1. What is a good first project car?
  2. transmission, but case is cracked
  3. b series headers? other ?'s also
  4. Car Alarm Starter Disable?
  5. Help, quick question spark plug gap
  6. What do you think about this article?
  7. rear seat in a crx
  8. what else do I need for this B20 swap?
  9. fuel injectors
  10. h23/h22?
  11. axle problems...
  12. home-made tools
  13. Hybrid Revolution?
  14. custom gauge faces
  15. technical questions about oil loss on honda 1.5
  16. Was throwing just code 22. Now, 22 is gone and it's CEL code 21, Why?
  17. Metal vibration noise
  18. WTB oil catch can... where is a good place
  19. at home B16A swap?
  20. Engine bay, really really warm...
  21. HELP!!?? no fuel through Bosch ke jetronic fi distributor
  22. Light Weight Flywheels????
  23. are obx hi-flow cat really hollow?
  24. Best swap for 88 teg?
  25. getting B20 to 1.75 r/s
  26. B16A2 into a '95 Ex coupe
  27. Breather Filter
  28. A Good JDM engine Dealer
  29. H22A or B16a SirII????
  30. VAFC settings for Walbro 255lph
  31. Installing brake pads
  32. K24 vtec
  33. Non V Tec 2.2...help
  34. Is this the right harness for CEL diagnostic? Pics inside!
  35. how can i open door with button??
  36. cam gear bolts
  37. b16a 5th gear to LS?
  38. Hesitation nobody can figure out!!!!
  39. engine mounts B16A
  40. PS pump question
  41. Help! Wiring Problem
  42. jacobs icepack not working Help
  43. P30 Ecu???
  44. Torque settings on Head bolts and cam bolts
  45. New S-AFCII...more tuning pts!
  46. VTEC Quit!!!
  47. Shot peen B16A Rods...any troubles?
  48. car problem
  49. can it be done twin turbo for a 99 honda civic
  50. shaved trunk how to?
  51. Distributer HELP PLEASE!!
  52. TURBO for RSX Type-S
  53. Suspension Help
  54. d15b vtec Fuel Cutoff?
  55. WRX motor in Integra???
  56. hp racing header?
  57. Turbo? or Na
  58. Where did YOU tap in to wire the IAB (secondary intake solenoid) for vtec???
  59. Eg / GSR swap is almost complete! Few various Q's with pics inside!
  60. Cheapest place for JDM front clip
  61. 1999 civic ex vtec
  62. honda accord 94-95 trunk on a 1997?
  63. Fuel Gauge Problem!
  64. knocking????
  65. no power
  66. b18c1 or b18c5 and a smog question
  67. Dsm?
  68. Green harness under intake manifold on GSR motor?? IAB solenoid?? PICS inside!
  69. 1999 civic vtec damaged?
  70. Installing the "bitch pin" (shift linkage at tranny), Best way?
  71. Jdm Ecu
  72. Check this Honda out guys :)
  73. 4 wire o2 shock tower wire locations! Pics w/ detailed text!
  74. interchangable parts
  75. mini me swap dual carbs
  76. Exhaust smells like gas
  77. motor swap cost
  78. 92 honda accord
  79. vtec solenoid
  80. Look!! how do i solve rusted headers???
  81. new clutch ?
  82. notcing the block
  83. Seat Belt problem in Civic!
  84. Long block and Short block
  85. d15b head swap
  86. Tranny
  87. ECM help.....please
  88. 89 CRX Radiator Support
  89. H22s cheaper in canada?
  90. Plasma Booster??
  91. h23 specs
  92. vtec wiring HELP! Couple Q's and Pics!
  93. temp sending unit?
  94. Climate Control
  95. Chassis DYNO shops in So. Cal.
  96. need car buying stories
  97. 18'wheels
  98. synthetic oil
  99. Nopi...
  100. How do you adjust t.p.s
  101. twin scroll turbo...
  102. vtec
  103. just a girl, please help
  104. No Thanks...4 Stroke For Me Please!
  105. speedo is out!!!
  106. dumb lights
  107. difference in exhaust
  108. a20->b18 head swap???
  109. screwed up electrical parts bad help
  110. 94 Accord JDM Bumper lens
  111. Shaved doors...
  112. hmm...
  113. Alternator doesnt work right in rain, WHYYYY!!! PLZ Help
  114. 97 olds aurora
  115. 89 integra
  116. Valve Specs
  117. 4 Pt Safety Belt vs. Standard
  118. Looking For A B16a1
  119. Speedometer is stuck at 40
  120. Question on Intakes
  121. I Have Motor Questions!!!
  122. B20 vs B18c5
  123. PLEASE HELP P1457 emission code
  124. Anyone ever seen this????
  125. Snorkel Hood scoop and Ram Air.
  126. mini me question
  127. Major Newb: Exhausts
  128. d16z6 od d16y8 head???
  129. Valves suck
  130. right hand drive conversion
  131. Wiring the Eg / GSR up! Pics inside! Help needed! *56k might get 0wn3d*
  132. 2.3cl swap for h22a
  133. I need some major help..
  134. Need second opinion for next mod
  135. 95 B16a in a 96 Civic Coupe?
  136. How to....
  137. cam shaft and cam gears in b16a
  138. Exhaust Headers
  139. oil question?
  140. H22 in an 88-91 CRX
  141. fuel cut-off at 3500 on new ZC motor!!! Anyone know why ??
  142. B20 with GSR head: Valve clearance problems
  143. Day 3 working on the Eg / GSR swap **56k stand back about 8 miles**
  144. power for my baby
  145. 87 non si swap
  146. prelude throttle body
  147. Piston to Valve clearance and CR questions.
  148. 99 B18C5 into 94 Civic EX
  149. Csrv
  150. Such thing as a 92-96 H22 Type-S???
  151. my ZC fuel cutoff is 3500, HELP
  152. Timing advance on a '96 Accord LX
  153. Internals
  154. hesitation
  155. Maybe the first new idea since nitrous...then again, maybe stupid
  156. stupid power steering question
  157. how to remove 96-98 civic dash?
  158. h22 in a civic hatch
  159. What Car?
  160. dohc valve cover
  161. engine parts????
  162. electrical stuff
  163. Should I go full synthetic?
  164. Motor Problem
  165. 98civic RearSection Exhaust bolt-on
  166. gsr into my crx?
  167. What is the best synthetic blend oil?
  168. 7th gen hondas
  169. h22a w/parts
  170. Seatbelts?
  171. tough question...
  172. vtec not working
  173. ARP head bolts?
  174. 91' prelude si
  175. A little B16 Buildup
  176. Honda Prelude help....please
  177. rotary
  178. Y-Pipe in Escort
  179. lookin at new engine for 2G lude and need some help
  180. Freeing stuck fuel sender float
  181. Steering wheel install
  182. e-brake handle
  183. z6 spark plug tube
  184. preachers daughters 318i is in big trouble
  185. differentials
  186. Auto Theft
  187. Is my Y1 trans LSD?
  188. check engine light
  189. ls nonvtec into lsvtec
  190. What's the difference between the 4cyl engines in the Accord?
  191. wut u guys think about droppin a b18c1 ina 94' civic hb?
  192. what to get
  193. Trip-clutch and double clutch...what are they?
  194. High flow cat and engine light
  195. f22b install costs
  196. electronic Load Detector Help
  197. wtb total zc swap
  198. O2 sensor gone bad?
  199. header question
  200. b16 block?
  201. head install ?
  202. need good shop in central jersey area!!!
  203. shift linkage question
  204. just got my car ..........................now what?
  205. help i need somebody
  206. d series into a drag car?
  207. Pistons/Rods for a B20VTEC
  208. Valve Lash?
  209. Best way to clean corrosion off brake system? Pics of my nasty brakes inside!
  210. 95 engine into 91
  211. Anything to consider with a 94 GSR tranny on a B20
  212. What's the max compression you should run on 91 gas
  213. B20/VTEC: What accessories to use
  214. 96 Civic?!?!?
  215. OBD Who?
  216. B18C1 motor buildup
  217. Completed H22 Swap: Shiftlinkage/Syncros Problem...
  218. Completed H22 Swap: Shiftlinkage/Syncros Problem...
  219. dust from vent
  220. Questions about my swap
  221. 2003 Civic DX/HX H22 Swap?
  222. Short Shifter
  223. Unichip
  224. igition system and hi flow cat
  225. Help me with my kart!
  226. B16a
  227. 98 civic EX/DX PLeasehelp
  228. DOHC ZC Head questions!
  229. motor mount - torque mount?????
  230. what the hell wire is this - need quick answer
  231. Question about what I should buy.
  232. Firebird Engine Swap
  233. Speed Density to MAF
  234. Superchargers
  235. how about an h22a? what will that do to my civics handling?
  236. Easy question, just need the "slang" name
  237. nitrous on a d16y8
  238. Engine Shudder
  239. Estimate cost to fix motormount on 2000 v6 accord
  240. Psi?
  241. b20/vtec hybrid questions
  242. LED Washer Help ???
  243. Wiring for a B20 VTEC in a 94 GSR
  244. Isuzu heater
  245. Sponsorship
  246. Strange grinding noise in 1st gear...
  247. Changing Timing Belt, d16y8
  248. Help Wrong Fuel!
  249. Direct Shifting Gearbox!
  250. I need a Quality Shop in MD,DC or VA HELP
